Originally Posted by Traction
I despise those spline drive lug nuts, unless that is all that will fit an aftermarket wheel. The socket is very thin, and will get destroyed with an impact, plus if you break it, you are SOL. At least with a 3/4 hex you could easily find help. Also addressing an earlier post finding 99 cent lug nuts, they will work if you don't mind rusty nuts a couple years later after the chrome falls off, and you have to pound the socket on those too.
Yeah, I don't ever use impact wrenches on my lug nuts. 1/2" drive ratchet and torque wrench only. The spline drive socket doesn't appear that it would stand up to impact drivers as it is very thin. The lug nuts themselves are an aluminum alloy (Duraluminumâ„¢?) or something.
