Rockauto code expires 8/2
by gallydif - 06/02/20 08:19 AM
The worst job you ever had?
by Chris142 - 06/02/20 08:04 AM
P218F on my Ford PSD
by Donald - 06/02/20 06:34 AM
Kudos to Griot's
by Egg_Head - 06/02/20 05:43 AM
Exide Battery files for bankruptcy
by Randol - 06/02/20 04:34 AM
Just one more wax question.
by rrretiree7 - 06/02/20 01:49 AM
Removing stuck bolts- interesting technique
by rubberchicken - 06/02/20 12:47 AM
Unless it is a misprint?
by 340_Magnum - 06/01/20 10:25 PM
Raymond Weil 5590 Watch Battery Replacement
by maverickfhs - 06/01/20 09:22 PM
Echo SRM 230 idling high
by CDX825 - 06/01/20 08:40 PM
Walmart in Canada closing Lube and Tire Express
by Snagglefoot - 06/01/20 08:26 PM
2012 Sonic - LCA puck bushing
by Number_35 - 06/01/20 06:44 PM
Rotate mags?
by marine65 - 06/01/20 06:40 PM
Re-using good coolant?
by Jarpin - 06/01/20 06:21 PM
Best entry level riding mower
by UncleDave - 06/01/20 03:02 PM
2015 Pilot LX
by madRiver - 06/01/20 03:01 PM
NewMex, RandyN11049, bbrtuning, chapys, DaaBoss
71593 Registered Users
88 registered members (830Lee, 55hambone, 1978elcamino, 2015_PSD, 64bawagon, 97prizm, 11 invisible), 2,124 guests, and 89 spiders.
Topics306,053
Posts5,286,496
Members71,593
Motorcraft Parts Are The Best #5434253 05/20/20 03:01 PM
BlueOvalFitter Offline OP
It's that time to do a trans filter and fluid change. The local auto parts stores want on average $6.99 per qt. of Mercon V trans fluid. And, a MC trans filter $23.99. I sure am glad that my son works for a Ford dealership.
2007 F150, 4.2 V6
Havoline PRO DS 5W20, M1-209A
"One Filter, One OCI!"
"One Box, One OCI!"
Re: Motorcraft Parts Are The Best [Re: BlueOvalFitter] #5434267 05/20/20 03:17 PM
L
Lolvoguy Offline
L
Except when they are fakes
Fake Motorcraft parts
no-no
06 Lexus IS350- Wife
88 BMW 325is- Mistress
Say "no" to Turbo!
Re: Motorcraft Parts Are The Best [Re: BlueOvalFitter] #5434277 05/20/20 03:26 PM
L
LubricatusObsess Offline
L
Wholesale "account", eh? wink
Elastohydrodynamic Lubrication makes the world go 'round!
2017 Ram 2500 - PUP 0W-40, Fram XG
2011 Chev Traverse - PUP 5W-30, Fram XG
2005 Chev Kodiak C5500 - PUP 10W-30, Fram XG
Re: Motorcraft Parts Are The Best [Re: LubricatusObsess] #5434295 05/20/20 03:43 PM
I don't take advantage of my son and his employee discount. If I need major parts I usually get them from Rock Auto. But when trans fluid is almost $2 more per qt. than what he can get it for, it's good that he works for Ford.
What I do is drain 4 qts. of fluid every 30K miles. Every 60K miles I drop the pan, change the filter, and add 4 qts. of Mercon V thans. fluid. I have been doing this since my truck was new (6 miles).
In 10K miles it will be time to do a rear differential fluid change. I use ST 75W140 synthetic fluid and a Fel-Pro gasket (RDS-55341).
thumbsup
2007 F150, 4.2 V6
"One Box, One OCI!"
Re: Motorcraft Parts Are The Best [Re: Lolvoguy] #5434300 05/20/20 03:48 PM
no-no
Are you saying that Ford sells fake MC parts? ???
2007 F150, 4.2 V6
"One Box, One OCI!"
Re: Motorcraft Parts Are The Best [Re: BlueOvalFitter] #5434302 05/20/20 03:49 PM
R
Reddy45 Offline
R
Why not just get Supertech Mercon V which is $4.82/qt at WM? My understanding is that for a fluid to be labeled Mercon V, the mfr has to formulate it exactly per Ford's spec so the performance is going to meet Motorcraft.
There's also Maxlife which is compatible with Mercon V and is well tested among the group here.
Re: Motorcraft Parts Are The Best [Re: BlueOvalFitter] #5434319 05/20/20 04:00 PM
H
hatt Offline
H
Filter is $1.50 cheaper on Amazon. Mercon V for $5.67/qt by the case. Wholesale accounts at Ford don't get you much.
2013 F150 5.0, Delo 400 SD 15W-30, Wix 57502
2010 Camry 2.5, PP 10W-30, Mobil1 M1C-251A
Re: Motorcraft Parts Are The Best [Re: BlueOvalFitter] #5434321 05/20/20 04:01 PM
H
hatt Offline
H
Double tap
Re: Motorcraft Parts Are The Best [Re: BlueOvalFitter] #5434325 05/20/20 04:04 PM
L
Lolvoguy Offline
L
no-no
Anything is possible.
Say "no" to Turbo!
Re: Motorcraft Parts Are The Best [Re: Lolvoguy] #5434374 05/20/20 04:43 PM
bdcardinal Offline
no-no
We don't. All of our parts come from Ford or a FAD (Ford Authorized Distributor). You have to use FADs for certain parts like batteries. Other parts it is easier to get from them, like you can buy spark plugs individually from a FAD, where from Ford they are sold in a case of 96. There are places that sell Motorcraft parts that are not FADs though, we don't use them.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: Motorcraft Parts Are The Best [Re: hatt] #5434389 05/20/20 04:59 PM
Then there's shipping cost. You come out even, or ahead getting them from Ford.
And, I don't have to wait on them coming in the mail and getting damaged.
Oh, and I'm getting the trans fluid for $5.30 per qt.
popcorn
2007 F150, 4.2 V6
"One Box, One OCI!"
Re: Motorcraft Parts Are The Best [Re: BlueOvalFitter] #5434390 05/20/20 05:02 PM
dave1251 Offline
My wife had a preferred mechanic. When he said he had problems putting on Motorcraft pads and rotors because they are Chinese quality, I made the decision he will no longer be used by this house.
don't use.
Re: Motorcraft Parts Are The Best [Re: dave1251] #5434446 05/20/20 05:47 PM
bdcardinal Offline
Some are and the way the labeling is done can be confusing. There are the old blue label brake pads/rotors that are now relabeled Motorcraft which most of the time come from not China. Those would be the ones with a base number of 2001, 2200, 1125, 1102, and 2C026 with a short number beginning with BRF and BRRF. Then there are the Motorcraft value ones that are made to compete with the Autozones of the world that are 2V001, 2V200 etc base numbers with the short numbers beginning with BR and BRR.
Re: Motorcraft Parts Are The Best [Re: BlueOvalFitter] #5434576 05/20/20 08:18 PM
sloinker Offline
If it's a Ford like the muffstain GT below it will get only the appropriate level parts installed on it. Chinese parts are too good. Maybe Pakistan or Bangladesh sourced.
[Linked Image]
'16 Tiguan TSI Vaico 5W40
'15 VW Golf TDI Red Line 5W30 Euro
'15 VW Golf Sportwagen TDI M1 ESP 5W30
'14 Dodge Grand Caravan 3.6 Valvoline 5W20 Semi Synthetic
'64 Plymouth Fury440 Pending
Re: Motorcraft Parts Are The Best [Re: BlueOvalFitter] #5434605 05/20/20 08:47 PM
J
Jarpin Offline
J
I just started using a motorcraft FL-400S filter on my 1MZ-FE Toyota. It's 1/3 longer than the specified Toyota filter. Thanks FoMoCo's Vulcan V6 from the nineties Tauruses!!! thumbsup
