Vehicle sighting - 1968 AMC Javelin
by Number_35 - 05/27/20 04:22 PM
Looking for help on an old tiller
by BarryBl - 05/27/20 03:28 PM
is a larger alternator a no brainer?
by apollo18 - 05/27/20 03:02 PM
Rock Auto Code
by BAJA_05 - 05/27/20 01:42 PM
Considering 2019 VW Jetta
by KrisZ - 05/27/20 01:34 PM
Scheaffers moly worth it?
by mpgo4th - 05/27/20 10:50 AM
Flare wrenches
by hallstevenson - 05/27/20 10:43 AM
2000 Volvo S80 T6 Oil Recommendations
by MattV922 - 05/27/20 10:07 AM
2012 Mustang V6, 75w-140?
by RDY4WAR - 05/27/20 09:46 AM
03 WRX 203k miles P.P. 5w40 Euro
by TurboJW - 05/27/20 09:28 AM
13 Corolla U341E Filter
by AJB0009 - 05/27/20 09:19 AM
Brakes Pulsate when Hot
by artbuc - 05/27/20 08:57 AM
Castrol Magnatec Lexus DI application
by AzFireGuy79 - 05/27/20 08:31 AM
Wearing Mask Reinforced
by madRiver - 05/27/20 07:34 AM
2017 Nissan Titan SV 5.6
by ThrowinRocks - 05/26/20 11:30 PM
Need Some People to Do a Ping Test
by ZeeOSix - 05/26/20 10:22 PM
Dumb parking question.
by PhuongFU - 05/26/20 09:38 PM
spin on fuel filter
by mobilaltima - 05/26/20 09:36 PM
Peak Cool Orange no longer GM DEXCOOL Approved?
by Matt1980 - 05/26/20 08:10 PM
heikie, BarryBl, MattV922, Bruce_S, Rwogs
71540 Registered Users
82 registered members (ABN_CBT_ENGR, 10WSmuckers, Al, 53' Stude, 2015_PSD, 4WD, 8 invisible), 2,534 guests, and 43 spiders.
Topics305,939
Posts5,283,310
Members71,540
Best grease for puller (conical part) #5434247 05/20/20 02:58 PM
L
LucasDK Offline OP
L
Hi,
What is the best type of grease for the conical tip/part of a puller in order to avoid damage to both the conical part and its counterpart (part of the mechanical assembly). Picture for reference:
[Linked Image from tenaquip.com]
Or is there a better method such as slipping a small piece of thin guage brass sheet metal between the parts?
Lucas
Toyota Hiace 2,4D (2L engine)
Toyota Corolla AE92, (4A-FE engine)
Ford Model A (3,4 liter engine)
Re: Best grease for puller (conical part) [Re: LucasDK] #5434248 05/20/20 02:59 PM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
I’d use moly paste.
Re: Best grease for puller (conical part) [Re: LucasDK] #5434298 05/20/20 03:47 PM
ABN_CBT_ENGR Online Content
Online Content
Originally Posted by LucasDK
Hi,
Lucas
Neither,
Use a shaft protector between it and the shaft and use anti-seize as the lubricant. No grease known will maintain a significant film when its turning under load and you will need the metal ( preferably nickel but moly will work ) for the lubricity when really putting force on it
Same for the threads.
Re: Best grease for puller (conical part) [Re: ABN_CBT_ENGR] #5434400 05/20/20 05:07 PM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
Youre implying that Ni in anti seize is more lubricious than an MoS2 paste?
Also need to be very specific that youre implying Ni Anti-Seize if that's the case, as intitially its just stated generically.
Re: Best grease for puller (conical part) [Re: JHZR2] #5434420 05/20/20 05:24 PM
Online Content
Should have been stated better but I didn't think it mattered at the technician level but you caught it so others will do.
This actually comes from tests done in conjunction with OTC on pullers for a project. We actually tested numerous lube and protector configurations back then.
There are two parts to that screw- the physical loading ( the puller thread is a compromise between screw and ACME) and then the puller being harder than most shafting so it grinds in.
Moly is the superior lubricant as solid films lubricants go but under those loads and galling (not to mention a proper shaft protector should split under the loading) the nickel gets impregnated (almost gilding) ans has superior performance.
It should have been better stated that is on ISO press fits Moly would be excellent and probably be smoother that anything else.
You get into heavy ISO interference fits then moly will go boundary real quick ( so will the nickel too) but then it matters.
Not specific to the puller illustrated but on the posi-lock puller, moly is recommended for the OEM end cap protector but its at the same hardness as the screw whereas a shaft protector isn't.
Re: Best grease for puller (conical part) [Re: LucasDK] #5434579 05/20/20 08:24 PM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
Interesting... Thanks.
Had curiousity for two other reasons:
1) I made a tool to press subframe bushings into my 82 300CD last weekend. I used moly paste on the 5/8" threaded rod, and didnt even use a washer between the cast iron pipe of my "tool" and the nut... and it spun easily and really well.
2) I have a Klann spring compressor for old MB diesel long front springs. Its the only kind that works well and safely. it must have a 20mm threaded rod in it. And it recommends moly...
Thus why my curiosity was peaked... If there's something better, its always good, especially if its something that I have, like Ni anti seize (which Im sure has graphite and moly in it too).
Re: Best grease for puller (conical part) [Re: JHZR2] #5434767 05/21/20 05:19 AM
Online Content
To add a point of clarification (I need to remember to refresh my memory before commenting on parts of very old projects)
This was about damage to the thread/nut connection ( the nut is 3-5% harder than the thread to pull tension) and under load/shaft deflection and all that.
Also the contact geometry ( different countersink angles on shafts and the hardened point ( which is why the shaft protector is softer so it will "mold' to the drill point)
We basically did oils, greases and anti-seized for performance, safety, load reduction studies.
The moly we used was a grease.
If you were using a branded product like Bostic "blue moly" which has moly but nickel and is designated as an anti galling compound- that would have been considered a nickel anti seize in our tests because we were not commissioned to test individual brands.
That could be a distinction with a difference based on our design of experiment
sorry for any confusion.
Re: Best grease for puller (conical part) [Re: LucasDK] #5434949 05/21/20 09:45 AM
Online Content
Had some questions on the above example- we were commissioned as a result of an incident involving an injury and this study was a requirement of litigation.
The purpose was to develop the approved pullers for specific tasks and work processes and job plans etc. It was not testing various lubricants (in terms of performance) or specific pullers ( we tested all types the facility used which was pretty much every one that exists) and the key thing was establishing a force estimate that determined what was acceptable to what level so we did destructive testing for the high threshold.
It wasn't "product testing" in terms of performance or quality in the traditional sense- sorry if that misled anyone.
Re: Best grease for puller (conical part) [Re: LucasDK] #5436288 05/22/20 10:19 PM
clinebarger Offline
I use Anti Seize on the forcing screws of all my pullers.
2001 Chevy Camaro L92/4L80E
Re: Best grease for puller (conical part) [Re: LucasDK] #5436321 05/22/20 11:17 PM
Dave9 Offline
?? I've never bothered, just use any random lithium based grease on the threads.
Trying to slip some softer buffer material between them, or any goop to make it more slippery, seems like a real pain and fiddly thing that makes it harder to do the work. I want the tip planted and to stay put, not have some shim that can cause it to fly off in some direction. The key to that may be to use a decent quality puller with a sufficiently hardened screw. Besides, if the tip doesn't stay super sharp, what did it matter if you were effectively dulling the contact area anyway with the shim?
