Date code on Mighty Engine Guard II? Air Filter
by blufeb95 - 06/05/20 01:01 AM
My poor Jetta can't catch a break.
by FordBroncoVWJeta - 06/05/20 12:22 AM
Bought a truck finally, warning no Ford content
by bdcardinal - 06/04/20 11:31 PM
Got a septoplasty today....
by daves66nova - 06/04/20 10:44 PM
2020 330i xDrive Loaner
by MCompact - 06/04/20 10:02 PM
Appliance repair?
by motor_oil_madman - 06/04/20 09:44 PM
Glad we got a seasonal RV site
by Pat in Speedway - 06/04/20 09:19 PM
Mobil 1 AP Clearance at Wal-Mart
by KeithS_NW_Ohio - 06/04/20 09:07 PM
Recent experience with a Michelin Defender
by FordSVTGuy - 06/04/20 08:46 PM
music quality of speakers in the 70's vs now
by raaizin - 06/04/20 08:15 PM
pressure washer care
by raaizin - 06/04/20 08:06 PM
Watch Forums?
by maverickfhs - 06/04/20 07:53 PM
Who has a media/sand blast cabinet?
by spasm3 - 06/04/20 07:39 PM
Why isn't Polyethylene Glycol standard?
by RamFan - 06/04/20 06:37 PM
Motorcraft GF-6 at Quick Lane.
by Gene K - 06/04/20 06:29 PM
OEM Honda wiper blade curvature
by mclasser - 06/04/20 06:24 PM
GDI vs. MPFI OCI's
by LubricatusObsess - 06/04/20 06:19 PM
Mobil “full synthetic”
by 53' Stude - 06/04/20 06:01 PM
1992 Ford Ranger Brake Fluid Type
by yeehaw1960 - 06/04/20 04:21 PM
Of 0w-20 oils, which have highest VI
by Bill_W - 06/04/20 03:44 PM
stubby73, Polkaman, Ramboagain, tekfire07, Kernal
71608 Registered Users
20 registered members (Delta, FordBroncoVWJeta, Char Baby, doolah02, ctechbob, BlakeB, 1 invisible), 698 guests, and 38 spiders.
Topics306,228
Posts5,288,629
Members71,608
Briggs and Stratton Auto Choke on Toro Problem #5434241 05/20/20 02:53 PM
K
Kevinmcc2 Offline OP
K
Hello, I have a problem with a Toro Timemaster Model #: 20199 with a briggs 190cc #121S020130F1 engine.
This only happens after I engage the blades and on a cold mower.
The mower when it is cold runs horrible. I noticed that the auto choke linkage and arm on the carb flaps and flutters back and forth very fast and violently. This linkage goes to a thermostat on that muffler to the carb. If I hold the linkage in the choke OFF position the mower runs great and has good power but when i dont hold it the choke flap opens and closed at a very fast rate like its flapping in the wind.
Could this be a faulty thermostat, linkage, carb?
https://streamable.com/nar4by
https://streamable.com/6od3rb
It seems like when I engage the blades the one plastic piece rotates and thats when the choke starts to flap. the second video shows it a lot better.
I have tried a new choke return spring, and also cutting it to shorten it to apply more spring tension to help it hold the choke butterfly but nothing. Also, I have checked the govenor by removing the crank case cover and still all there.THis o
Re: Briggs and Stratton Auto Choke on Toro Problem [Re: Kevinmcc2] #5434245 05/20/20 02:55 PM
M
mk378 Offline
M
The thermostat is a bimetal coil-- either cold or hot it should apply some definite force on the arm and push rod. If it flaps back and forth it is broken inside.
Re: Briggs and Stratton Auto Choke on Toro Problem [Re: mk378] #5434250 05/20/20 03:00 PM
K
K
There is some force on that thermostat and it pushes open when fully warmed up. When cold tho it seems the plastic linkage doesnt touch the choke linkage at all until it is hot? Do you think the spring inside the thermo is weaked to a point it should be touching the choke linkage at all times?
I just reread your post and It answered my question, gonna order a new thermostat,
Re: Briggs and Stratton Auto Choke on Toro Problem [Re: Kevinmcc2] #5434265 05/20/20 03:16 PM
K
K
After looking at the linkage again how can the thermostat push the choke linkage? Maybe the linkage is missing something or not correct?
Re: Briggs and Stratton Auto Choke on Toro Problem [Re: Kevinmcc2] #5434268 05/20/20 03:19 PM
K
K
Re: Briggs and Stratton Auto Choke on Toro Problem [Re: Kevinmcc2] #5434294 05/20/20 03:43 PM
M
MasterSolenoid Offline
M
Could you be missing a Spring on the part that's vibrating ?
I would guess it would be a very small Coil Spring.
Look for a Hole or Tab that a spring could hook on to.
Then look in a Manual showing your Carb and any Springs.
My Toro with Auto Choke was giving me problems starting. Took 12 pulls.
Because of rigorous cleaning, I knocked the small spring off.
Once the spring was replaced, it starts on the second pull.
2002 Ford Ranger / bought new
2 Wheel Drive
3.0 Liter Engine
Four basic premises of writing:
Clarity, Brevity, Simplicity, and Humanity.
Re: Briggs and Stratton Auto Choke on Toro Problem [Re: MasterSolenoid] #5434359 05/20/20 04:28 PM
K
K
I replaced the spring on the choke that is vibrating, was the firs thing I did since it was cheap and and figured that would be the problem. Sadly it didnt. I have had this problem over a month now and its a big mystery lol. Should I just bite the bullet and throw a thermostat on it? Its around 25 bucks.
Re: Briggs and Stratton Auto Choke on Toro Problem [Re: Kevinmcc2] #5434522 05/20/20 07:15 PM
Q
Quest Offline
Q
I own a couple of auto-choked B&S mowers, and none of them levers should be flapping/vibrating back and forth when cold (shortly after cold starts).
If you experience that and granted that the carb is not an issue, then you may have to consider replacing the choke mechanism.
Q-TD
"Internet discussion boards act as echo chambers for conspiracy dittoheads" A.Allen
Re: Briggs and Stratton Auto Choke on Toro Problem [Re: Kevinmcc2] #5435405 05/21/20 08:17 PM
sweezy722 Offline
I am probably the only one to think this way but I would try to put a manual choke on it. Cheap and reliable.
Re: Briggs and Stratton Auto Choke on Toro Problem [Re: Kevinmcc2] #5436105 05/22/20 06:19 PM
A
andyd Offline
A
Only if it came with one, Sweezy grin2
Thick oil is better grin2
Re: Briggs and Stratton Auto Choke on Toro Problem [Re: Kevinmcc2] #5436300 05/22/20 10:30 PM
K
K
So just ordered a cheap $14 carb from amazon and put it on just now. Fired right up and choke works perfectly...
Tried to examine and compare the two to see if the oem had a missing or broken linkage or anything but looked exactly the same.
Maybe something internally broke on the oem carb? So strange.
Now I’m gonna debate buying a new Briggs oem carb for 45 or just rock the cheapo!
