Do you have your home HVAC system maintained?
by E150GT - 06/03/20 09:21 AM
Mixing vavoline & mobil
by ThePCMasterRace - 06/03/20 09:03 AM
Pre-Oiler?
by AJB0009 - 06/03/20 09:02 AM
1992 Acura NSX, Red Line 10W-30, ~1400 miles/1 year
by robertcope - 06/03/20 06:37 AM
Rural telephone boxes along road
by dlundblad - 06/03/20 05:06 AM
Mobil1 12 quart $30 at Walmart
by wkcars - 06/03/20 12:58 AM
"The Bright Knight"
by GumbyJarvis - 06/03/20 12:35 AM
Pennzoil Axle oil with LSA.
by Snagglefoot - 06/02/20 10:03 PM
Replaced the plugs on the bike: HUGE improvement!
by 14Accent - 06/02/20 09:26 PM
Accord Trans Case crack (bad casting?)
by redhat - 06/02/20 08:38 PM
Replacement SLA Battery for Clore Jumper
by SubLGT - 06/02/20 08:34 PM
ABS codes
by 2010Civic - 06/02/20 08:02 PM
Tie rod ends - which manufactures ok?
by jdw1222 - 06/02/20 07:40 PM
Who makes their own seltzer water?
by JLawrence08648 - 06/02/20 07:23 PM
Slight Tire Bulge
by coopns - 06/02/20 06:13 PM
gm 6.2l cylinder 8 misfiring only at idle
by apollo18 - 06/02/20 04:59 PM
Ford flex
by Micahmcmeen - 06/02/20 03:42 PM
boathead, Digital_Dad, RobertChapmant, NewMex, RandyN11049
71596 Registered Users
92 registered members (Bluebullet, azjake, BlueOvalFitter, Blkstanger, 2015_PSD, 87sammy, 7 invisible), 1,831 guests, and 67 spiders.
Topics306,086
Posts5,287,129
Members71,596
Predator 212/420 durability #5433959 05/20/20 08:31 AM
Deveak Offline OP
Just got an idea and had some questions. I live off grid with free natural gas. My NG is free but the well has limits and if I use to large of a generator, it sucks water out of the well and pressure drops. I have an excellent high efficiency inverter charger that handle some pretty huge loads. I don't much care for high rpm generators or even inverter generators because of the possible finicky electronics. I have a 24 volt 300 amp military niehoff alternator. Weighs about 60-70 lbs so I am pretty sure its a true 300 amps continuous. I plan on running it at a lower speed and only using around 140 amps tops. Does anyone know how long a predator 212/420 will last at a lower rpm? I've seen people on youtube saying they have over 3000 hours on the generator so i figure 1800-2000 rpm should be a breeze for the engine. Most likely will be a steady state 1800-2000 rpm. Any modification I can do to help engine life? I may put a K&N filter on it and remove the smog box filter and replace with just a regular filter for it so no nasty crankcase air going in. Extra zinc? 120/300 bucks right now but the long it lasts, the lower the running costs. I might put a big old box fan or blower on it to make it cool. I will remove the gas tank as well since i won't need it. I would prefer pressure lubricated so I could put a external oil cooler with thermostat in and a bypass of some kind. I just can't justify something that expensive though that might not last. v twins costs as much as rebuilt car engines. Most of these modifications can be reused if the engine nukes itself. Thoughts?
Re: Predator 212/420 durability [Re: Deveak] #5433964 05/20/20 08:41 AM
I
ironman_gq Offline
I
I'd run it as it comes out of the box. Under light load they won't get hot, you will want the larger motor. Do not put a K&N filter on it, they're actually really crappy at filtering out fine dust which is what will kill your rings in the long run. Change the oil every 1-200 hours after the first 2-3 50hr changes and use a good HD oil. When the motor eventually dies they're cheap enough to just stick a new one in and being that you left it stock it'll be that much easier and quicker to do so. I'd want filtering on the fuel source for sure, NG can get kinda dirty. Definitely a moisture trap at a minimum.
Re: Predator 212/420 durability [Re: ironman_gq] #5433966 05/20/20 08:44 AM
Deveak Offline OP
I was thinking about the K&N because its reusable and lowers long term costs. I will be using this a LOT. most likely 1000+ hours a year. I do have a moisture trap but is there a way to passively filter the well gas?
Re: Predator 212/420 durability [Re: Deveak] #5433981 05/20/20 09:06 AM
Z
Zaedock Offline
Z
I don't know about exact longevity, but I installed a Predator 212 on my log splitter 3 years ago and it's been working great.
It starts on one pull in summer, and maybe 2-3 pulls in the dead of winter. We burn for heat. I don't have an hour meter, but it gets used often.
At about $100.00, it's been a great replacement engine.
You could probably fab additional air filtration. The fan inside the pull start seems to cool the unit just fine. You could test running conditions with an IR gun if you have one. I think HF sells those too.
2019 Escape EB AWD/2016 KIA Optima SXL 2.0L Turbo/2012 F150 Ex-cab 5.0L
1992 YJ "The Heep"/2015 Chrysler 200 Limited
1975 Ford Bronco/1959 Willys CJ5/Tube Rock crawler
Re: Predator 212/420 durability [Re: Deveak] #5434117 05/20/20 12:26 PM
spasm3 Offline
I think the predator engines are straight shaft, a lot of generators need a tapered shaft. Investigate your generator head before you buy an engine.
13 elantra 84k 5w30 synpwr
17 mazda cx-5 19000 miles m1 0w30
Re: Predator 212/420 durability [Re: Deveak] #5434174 05/20/20 01:23 PM
slacktide_bitog Online Content
Online Content
Replace the spark plug with a Denso W20TT
Re: Predator 212/420 durability [Re: spasm3] #5434208 05/20/20 02:06 PM
J
jeepman3071 Online Content
Online Content
J
+1
1998 Jeep Wrangler Sahara 4.0L/5MT (157k) - PHM 10w30, Wix 51085
2009 BMW 328i N51 (61k) - Liqui Moly 5w40, MANN HU816X
Re: Predator 212/420 durability [Re: Deveak] #5434220 05/20/20 02:19 PM
K
Kamele0N Offline
K
Loncin/Predator engines come with variety of shafts...
G200F-W..... G200F-C.... And so on...
Example (for a generator) : https://www.opara.si/horizontalni-4...-ELEKTROAGREGAT-KONICNI-IZHOD-GREDI.html
2008 Toyota Yaris 1ND-TV 1.4 D4-D Tech9 (Shell?) 5W30 C3 VW 504/507
1997 Toyota Landcruiser KZJ95 3.0 TD Shell Rimula R6M 10W-40
Re: Predator 212/420 durability [Re: Deveak] #5434237 05/20/20 02:49 PM
M
mk378 Online Content
Online Content
M
24 volts at 140 amps is 3.4 kWe, which would require at least 4.4 hp from the engine assuming 100% conversion efficiency. This proposed "light load" is actually near the rating of that little engine, so expect to run it to rated rpm.
Re: Predator 212/420 durability [Re: Deveak] #5434262 05/20/20 03:14 PM
sloinker Offline
Run a hit and miss possibly or magneto low rpm one lunger from the 1920-1940s off of the natural gas and use the flywheel to spin a generator 24/7. Go to some old tractor or equipment show and see what's out there.
'16 Tiguan TSI Vaico 5W40
'15 VW Golf TDI Red Line 5W30 Euro
'15 VW Golf Sportwagen TDI M1 ESP 5W30
'14 Dodge Grand Caravan 3.6 Valvoline 5W20 Semi Synthetic
'64 Plymouth Fury440 Pending
Re: Predator 212/420 durability [Re: spasm3] #5434447 05/20/20 05:48 PM
Deveak Offline OP
I am going to belt drive it, its a 28 volt alternator, not a generator head. spline shaft, will take some adapting.
Re: Predator 212/420 durability [Re: sloinker] #5434454 05/20/20 05:51 PM
Deveak Offline OP
Yeah thats why I am leaning more towards the 420. The alternator I have should be higher efficiency, I think around 70-80% instead of the usual 50-60%.
I call it a light load because 99% of the time its going to be 1 kw or less.
I thought about that but its likely to cost 3-4x as much, I will have no idea how to service it and parts availability is non existent.
Re: Predator 212/420 durability [Re: Deveak] #5435353 05/21/20 07:10 PM
Deveak Offline OP
I bought the engine today for 400. I got the two year warranty for 10 bucks. Not sure if its any good but I might be able to run the dog [censored] out of it in two years and see what happens. I got a hold of the alternator manufacturer. Its a niehoff N1375. 2000 rpm is peak efficiency, 75-76% efficient which is actually a lot higher than I was expecting. Probably from the fact that its a 6 phase alternator. I think I can do a 1:1 connection than. I can't find torque curves for the motor but its a clone of the gx 390 with slightly more displacement and it lists the torque at 18.4 ft lbs of torque at 2000 rpm. The predator is listed at a peak of 18.4 at 2500 so I think they should be pretty close if not the same.
