Motorcycle rear shock rebuild
by Reddy45 - 06/02/20 12:45 PM
2016 Lexus RX350 Oil Change change
by Toros - 06/02/20 12:43 PM
Tire Mobility Kits
by wings&wheels - 06/02/20 12:06 PM
Worst accident you've witnessed
by Dave Sherman - 06/02/20 12:04 PM
Shock Fluid
by splinter - 06/02/20 11:21 AM
Michelin X-Ice 4 North for Canada ...
by odie - 06/02/20 11:03 AM
Rockauto code expires 8/2
by gallydif - 06/02/20 08:19 AM
The worst job you ever had?
by Chris142 - 06/02/20 08:04 AM
P218F on my Ford PSD
by Donald - 06/02/20 06:34 AM
Kudos to Griot's
by Egg_Head - 06/02/20 05:43 AM
Exide Battery files for bankruptcy
by Randol - 06/02/20 04:34 AM
Just one more wax question.
by rrretiree7 - 06/02/20 01:49 AM
Removing stuck bolts- interesting technique
by rubberchicken - 06/02/20 12:47 AM
Unless it is a misprint?
by 340_Magnum - 06/01/20 10:25 PM
Raymond Weil 5590 Watch Battery Replacement
by maverickfhs - 06/01/20 09:22 PM
Echo SRM 230 idling high
by CDX825 - 06/01/20 08:40 PM
Walmart in Canada closing Lube and Tire Express
by Snagglefoot - 06/01/20 08:26 PM
NewMex, RandyN11049, bbrtuning, chapys, DaaBoss
71593 Registered Users
88 registered members (2010Civic, 69Torino, 2015_PSD, 390pi, 4WD, 14Accent, 6 invisible), 2,337 guests, and 66 spiders.
Topics306,058
Posts5,286,611
Members71,593
Connecting battery tender to battery cables? #5433842 05/20/20 04:42 AM
dlundblad Offline OP
Would there be any issues with connecting a battery tender to the battery cables at the starter and ground as opposed to the battery posts themselves?
03 Jeep WJ 4.0 208k
02 Volvo S60 2.4T 199k
97 Chevy Blazer 4.3 175k
04 Audi A4 3.0 210k
Re: Connecting battery tender to battery cables? [Re: dlundblad] #5433848 05/20/20 05:05 AM
ctechbob Offline
Should be just fine.
2008 Acura TL Type S-170k
2003 Honda Accord V6-222k
Oil-Havoline HM 5W30
Filter-Partsmaster 61334
Trans-Idemitsu H+
Re: Connecting battery tender to battery cables? [Re: dlundblad] #5433880 05/20/20 06:30 AM
Astro14 Offline
If the connections are clean and tight, probably not, but any extra resistance will mess up the measurement of voltage, and hence, charging.
32 Packard 15W40
01 Volvo V70 T5 0W30 AMSOIL SS
02 Volvo V70 T5 0W30 Edge
02 Volvo V70 XC 0W40 Edge
05 MB S600 0W40 M1
Re: Connecting battery tender to battery cables? [Re: dlundblad] #5434032 05/20/20 10:37 AM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
No. Just make sure it is a constant hot direct connection.
I used the main connection to a distribution/fuse box underhood on my truck out of convenience (side terminals). My BMW has the battery in the trunk, but I connected the charger leads underhood to the main cables. It has worked great for years.
Re: Connecting battery tender to battery cables? [Re: dlundblad] #5434052 05/20/20 10:56 AM
J
joekingcorvette Offline
J
No problem. My 2014 has the battery underneath the passenger seat however there are posts under the hood to hook up cables if needed. I never had to mess with it.
2005 Chevrolet Corvette
2014 Ford F-150 4x4 supercrew
2014 Jeep Grand Cherokee Limited (wifes)
2012 Honda Civic 4 door (my daily driver)
2007 Lund Tyee Grand Sport Mercury 115HP 9.8HP
Re: Connecting battery tender to battery cables? [Re: dlundblad] #5434068 05/20/20 11:25 AM
Dave9 Offline
No but if that's going to be a pain to get access to, then I'd run wire to make a remote access point where it is more convenient, and for low maintenance level current, I'd consider using a DC barrel jack/plug combo instead of a clamp to post setup.
Re: Connecting battery tender to battery cables? [Re: dlundblad] #5434212 05/20/20 02:11 PM
DBMaster Offline
I added length to the two wires on one of these connectors and connected them to the battery posts. I have the connector tucked behind one of the vertical grill supports on the bumper. It's out of sight until I reach in and pull it out. It connects directly to the Battery Minder charger/desulfator I use. After "restoring" a three year old battery that was weak enough to be replaced I started connecting the charger to it any time I wasn't using the car. Now, I just connect it once a week. Nine months later the battery still reads 12.7V and does not drop below 11V when starting the car. The desulfation process is very slow, but I've read about batteries lasting at least double their normal lives by doing this. Some of those anecdotes were from this site.
[Linked Image]
Re: Connecting battery tender to battery cables? [Re: Astro14] #5434753 05/21/20 04:08 AM
Ouch. So this would definitely be a no go on a car with the battery in the trunk like a P2 Volvo then?
03 Jeep WJ 4.0 208k
04 Audi A4 3.0 210k
Re: Connecting battery tender to battery cables? [Re: dlundblad] #5434890 05/21/20 08:35 AM
Astro14 Offline
I’ve got the cables on three cars, the 2001 V70, the 2002 V70 and the S600.
All three have the battery in the trunk. I attached the ring connectors to the battery clamps. No resistance. No loss.
I’ve got to back the car into the driveway to make the connection. But they work great.
I wouldn’t connect the ring connectors to the jump points under the hood. I think the Battery Tender directions tell you to connect directly to the battery.
32 Packard 15W40
05 MB S600 0W40 M1
Re: Connecting battery tender to battery cables? [Re: Astro14] #5434953 05/21/20 09:47 AM
Do you shut the tender wire in the trunk or just go through the battery vent hole?
03 Jeep WJ 4.0 208k
04 Audi A4 3.0 210k
Re: Connecting battery tender to battery cables? [Re: Astro14] #5435052 05/21/20 11:51 AM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
They generally say to connect the negative to chassis, positive to battery.
As none of these are charging at appreciable rates, the resistive drop is sufficiently low that the conductor length doesnt matter much. One of the reasons to connect to the battery is because it wont work if connected to a switched source. BMW sold a trickly charger that went through the cigarette lighter port - it was a relabeled battery tender!
Re: Connecting battery tender to battery cables? [Re: dlundblad] #5435084 05/21/20 12:45 PM
Astro14 Offline
I close the trunk/hatch on the battery tender cable. It’s an extension cable, relatively thin gauge, and easily replaceable. No gasket damage from that thin cable.
32 Packard 15W40
05 MB S600 0W40 M1
