Originally Posted by Farnsworth
Was the wiring #10 to the 30a outlets? On my house I found a 30 amp breaker from long ago protecting #14 wire. If #10 four wire you could put in a small subpanel.
In a prior home I tried to figure what breaker a light was on and turned off every breaker one by one. Off then back on, Light never went off. Then I discovered two different circuits fed the same light. So I had to turn off 2 breaker. Who ever did the wiring was lucky (50/50 chance) that both circuits were the same leg of 220V.
