Originally Posted by HorseThief
Why not by a short extension? Also be careful with some of the cheap ring terminals. Some factories that make these don't understand that connectors are supposed to be wired a specific way (fused positive wire is female on vehicle side connector so that the live positive is protected from shorting to ground). I've seen quite a few cheap Chinese chargers, solar panels, and charge controllers that have incorrectly wired power sources and connectors that work only with that device, but will cause magic smoke and blown fuses if you tried to use them with a Battery Tender or similar reputable charger. It's so prevalent it's the main reason Noco chose to use a proprietary connector on their chargers and lots of Amazon and eBay vendors sell polarity changers so that their incorrectly wired products will work with properly wired charge leads.
Just what I learned. You can also just use the wrong connector, and flip it on the battery. In other words put black ring terminal on batt positive. Red ring terminal to batt negative etc.
