Vehicle sighting - 1968 AMC Javelin
by Number_35 - 05/27/20 04:22 PM
Looking for help on an old tiller
by BarryBl - 05/27/20 03:28 PM
is a larger alternator a no brainer?
by apollo18 - 05/27/20 03:02 PM
Rock Auto Code
by BAJA_05 - 05/27/20 01:42 PM
Considering 2019 VW Jetta
by KrisZ - 05/27/20 01:34 PM
Scheaffers moly worth it?
by mpgo4th - 05/27/20 10:50 AM
Flare wrenches
by hallstevenson - 05/27/20 10:43 AM
2000 Volvo S80 T6 Oil Recommendations
by MattV922 - 05/27/20 10:07 AM
2012 Mustang V6, 75w-140?
by RDY4WAR - 05/27/20 09:46 AM
03 WRX 203k miles P.P. 5w40 Euro
by TurboJW - 05/27/20 09:28 AM
13 Corolla U341E Filter
by AJB0009 - 05/27/20 09:19 AM
Brakes Pulsate when Hot
by artbuc - 05/27/20 08:57 AM
Castrol Magnatec Lexus DI application
by AzFireGuy79 - 05/27/20 08:31 AM
Wearing Mask Reinforced
by madRiver - 05/27/20 07:34 AM
2017 Nissan Titan SV 5.6
by ThrowinRocks - 05/26/20 11:30 PM
Need Some People to Do a Ping Test
by ZeeOSix - 05/26/20 10:22 PM
Dumb parking question.
by PhuongFU - 05/26/20 09:38 PM
spin on fuel filter
by mobilaltima - 05/26/20 09:36 PM
Peak Cool Orange no longer GM DEXCOOL Approved?
by Matt1980 - 05/26/20 08:10 PM
heikie, BarryBl, MattV922, Bruce_S, Rwogs
71540 Registered Users
95 registered members (4WD, aquariuscsm, 53' Stude, A310, 10WSmuckers, ABN_CBT_ENGR, 7 invisible), 2,503 guests, and 50 spiders.
Topics305,939
Posts5,283,333
Members71,540
Safe Jack Stand Recommendation #5433560 05/19/20 05:55 PM
T
TheLawnRanger Offline OP
T
I have two pairs of jack stands from HF. One pair has been recalled. Do you think I feel safe now using the identical pair that were not recalled just because there are different number written on them? Not a chance. What is a safe set of jack stands used by people who work under cars on a regular basis?
2011 Impala
2012 Colorado
Oil: 5w30 synthetic
Filters: Wix 51522 for both
Re: Safe Jack Stand Recommendation [Re: TheLawnRanger] #5433569 05/19/20 06:07 PM
supton Offline
I don't work on a regular basis but I often will grab a stack of cut 2x8's and use that as cribbage. Probably do that more often than jack stands. I feel that, wit ha larger base than can't sink into soft ground, and a larger contact point on the frame, it might be safer--under an axle though the stand might be better.
I have a couple sets of cheapo HF's and then a "big" set of American stands whose name escapes me.
2011 Toyota Camry, base, 2.5L/6MT, 205k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 159k, ours
1999 Toyota Camry LE, 2.2L/4AT, 225k, his
Re: Safe Jack Stand Recommendation [Re: supton] #5433578 05/19/20 06:16 PM
B
bbhero Online Content
Online Content
B
I use a 6 by 6 salt treated wood block and a 4 by 4 inch salt treated wood block too... Works very well.
Nissan Altima 3.5 Coupe
Cam2 Full synthetic 5w30 Carquest Blue 84356
"Treat your family like your friends and treat your friends like your family."
Re: Safe Jack Stand Recommendation [Re: TheLawnRanger] #5433579 05/19/20 06:17 PM
E
eljefino Online Content
Online Content
E
Do you know why it was recalled? If they had substandard material in the welds you'd never know by looking. Of course that swings both ways-- the "good" set may not have had its achilles heel discovered yet.
And it's not a brand or COO thing, they can all make a bad batch. Just be happy we're more litigious now than we were 40 years ago when we didn't think about such things, which makes recalls over "small things" more likely.
Re: Safe Jack Stand Recommendation [Re: TheLawnRanger] #5433581 05/19/20 06:18 PM
doitmyself Offline
Depending on your preference, ESCO and US Jack are good choices. Both units have come under quality control scrutiny every now and then over at garagejournal.com. shrug
Re: Safe Jack Stand Recommendation [Re: TheLawnRanger] #5433593 05/19/20 06:30 PM
O
OilReport99 Offline
O
US Jack for the win. Or jacks with pins.
2018 Ram 1500 - VME 5W-20
Re: Safe Jack Stand Recommendation [Re: eljefino] #5433596 05/19/20 06:34 PM
T
thescreensavers Offline
T
You can read the Recall Notices from NHTSA
https://static.nhtsa.gov/odi/rcl/2020/RCLRPT-20E027-9959.PDF
https://static.nhtsa.gov/odi/rcl/2020/RCLRPT-20E016-6561.PDF
Quote
it was determined that product quality was inconsistent due to aging of the tooling and inconsistent location indexing of the pawl armature hole.
Official Harbor freight info https://em.harborfreight.com/pub/cc...t13fkngc0uk504ge21dqqp3v6ac2f8l9ac03vj0
Quote
there is a potential, while under load and with a shift in weight, for the pawl to disengage from the extension lifting post, allowing the stand to drop suddenly.
[Linked Image]
2017 Camaro SS 1LE (Motul 8100 X-clean 5W40)
1997 Jeep XJ 4x4 (15W40 HDEO Maxlife)
Re: Safe Jack Stand Recommendation [Re: eljefino] #5433609 05/19/20 06:53 PM
A
ajchien Offline
A
IIRC, supposedly worn tooling caused the teeth on the ratcheting load bar To be too shallow to completely engage the pawl. I think it affected the HF 6 ton stands made during a certain period of time.
As for a “safer” jack stand, I have the double pawl US Jack 6 ton stands which are nice. A decade ago, the 6 ton stands were rated PER stand. However, more recently, I think they have converted to national standards, and have now labeled the same stands as PER PAIR (US JACK D-41610 6 Ton Garage Stands Made In USA https://www.amazon.com/dp/B00P248NYO/ref=cm_sw_r_cp_tai_VAhXEb92THC3D). Alternatively, I would consider the ratcheting jack stands with the secondary pin that can be inserted. (Something like this: Pro-LifT T-6906D Double Pin Jack Stand - 6 Ton, 1 Pack https://www.amazon.com/dp/B074R17GL4/ref=cm_sw_r_cp_tai_CuhXEbMWSBZC5 )There are multiple labels that do this now. Pin only engaged stands are usually beefier too. (Sunex 1210 10-Ton Low Height Pin Type Jack Stands, Pair https://www.amazon.com/dp/B0093NBQ7G/ref=cm_sw_r_cp_tai_szhXEb1WEQNHJ)
I’m any case, if I’m working under the car, there are usually 2 different sets of jack stands - the ones in use, and a backup pair (placed under say where the control arms join with the subframe just in case.
Last edited by ajchien; 05/19/20 07:16 PM. Reason: Cut unnecessary personal story, added link
2003 Honda CRV EX 290,000+ miles
2003 Honda Element EX 330,000+ miles
2018 Ford Transit XLT 27,000+ miles
Re: Safe Jack Stand Recommendation [Re: TheLawnRanger] #5433611 05/19/20 06:56 PM
L
Leo99 Offline
L
Thanks for posting this. I wasn't aware of the recall and just checked my jack stands and they are recalled. I'll probably get another set of HF stands.
Without data you're just another person with an opinion. W. E. Deming
2004 Corolla 125,000 miles
2004 Rav4 399,852 miles (RIP)
2015 Camry 101,000 miles
2020 Rav4 6,000 miles
Re: Safe Jack Stand Recommendation [Re: ajchien] #5433651 05/19/20 07:50 PM
A
ajchien Offline
A
I’m going to correct myself, there are both 3 and 6 ton stands included in the recall.
Re: Safe Jack Stand Recommendation [Re: TheLawnRanger] #5433657 05/19/20 08:01 PM
CELICA_XX Online Content
Online Content
I am looking at a pair of these for about $250
https://www.norcoindustries.com/images/products/large/81205.jpg
Norco 5-Ton Capacity Pin Type Jack Stands (part number: 81205)
They also make an identical model which is imported and considerably cheeper.
Same part number with an " i " at the end (81205i)
20 Toyota RAV4 Hybrid - factory 0w16
06 Acura MDX - M1 EP HM 5w30 SN+
02 Toyota ECHO - Valv MaxLife Syn 5w30 SN
97 Lexus LX450 - M1 EP HM 5w30 SN+
93 Lexus LS400 - M1 EP HM 5w30 SN+
Re: Safe Jack Stand Recommendation [Re: TheLawnRanger] #5433739 05/19/20 09:52 PM
GumbyJarvis Offline
2018 Ram 1500 5.7L SLT
Group 7 V2222 - Mobil 1 Truck & SUV 5w30
Re: Safe Jack Stand Recommendation [Re: TheLawnRanger] #5433743 05/19/20 10:00 PM
H
HangFire Offline
H
I have some 12x12x12 or larger wood chunks I made out of tree trunks I cut down. I toss them under there, on either side of me whenever I have to get under a car... so I use any old jack (in working condition) without fear.
But yes, if it was recalled, back it would go.
Various musings: http://hangfire.net
Re: Safe Jack Stand Recommendation [Re: TheLawnRanger] #5433751 05/19/20 10:19 PM
I
IveBeenRued Offline
I
I’ve had good luck with these:
https://m.northerntool.com/shop/tools/product_200756194_200756194
They are double-locking; I really like the security of having that pin in there on top of the locking pawl. Northerntool has had these for over a decade and now I see other companies with similar designs on Amazon. Don’t know who made them first, but they are a great design at a reasonable cost.
2020 Toyota RAV4 Limited Hybrid 5,000 miles
Super Tech 0W-16|Fram Ultra
2012 Subaru Impreza Sport Limited 137,000 miles
Pennzoil Platinum HM 0W-20|Fram Ultra
Re: Safe Jack Stand Recommendation [Re: TheLawnRanger] #5433801 05/20/20 12:32 AM
H
haggler Offline
H
I remember looking at these in person. The notch where the paw sits was narrow, decently more narrow than the one I now have. I have the torin 3 ton with the locking pin. They are pretty sturdy. I also have the 2 ton walmart ones, which are made by torin. I should have gotten the aluminum pin style. The esco was too expensive and the aluminum torin version had a narrow base IMO. Both have good reviews though.
2019 MX-5 Soft Top Miata - Soul Red Crystal - M1 EP 0w20 - M1 EP 108a Filter
2020 Chevrolet Equinox - Factory Fill/Filter
