2 cycle with catalyst - carb settings?
by cjolson140 - 06/02/20 01:22 PM
Scam: Ghana $+2 - US $-2
by pandus13 - 06/02/20 01:09 PM
Motorcycle rear shock rebuild
by Reddy45 - 06/02/20 12:45 PM
2016 Lexus RX350 Oil Change change
by Toros - 06/02/20 12:43 PM
Tire Mobility Kits
by wings&wheels - 06/02/20 12:06 PM
Worst accident you've witnessed
by Dave Sherman - 06/02/20 12:04 PM
Shock Fluid
by splinter - 06/02/20 11:21 AM
Michelin X-Ice 4 North for Canada ...
by odie - 06/02/20 11:03 AM
Rockauto code expires 8/2
by gallydif - 06/02/20 08:19 AM
The worst job you ever had?
by Chris142 - 06/02/20 08:04 AM
P218F on my Ford PSD
by Donald - 06/02/20 06:34 AM
Kudos to Griot's
by Egg_Head - 06/02/20 05:43 AM
Exide Battery files for bankruptcy
by Randol - 06/02/20 04:34 AM
Just one more wax question.
by rrretiree7 - 06/02/20 01:49 AM
Removing stuck bolts- interesting technique
by rubberchicken - 06/02/20 12:47 AM
Unless it is a misprint?
by 340_Magnum - 06/01/20 10:25 PM
Raymond Weil 5590 Watch Battery Replacement
by maverickfhs - 06/01/20 09:22 PM
Echo SRM 230 idling high
by CDX825 - 06/01/20 08:40 PM
NewMex, RandyN11049, bbrtuning, chapys, DaaBoss
71593 Registered Users
96 registered members (4WD, 97prizm, ammolab, 55hambone, ABCarr, alarmguy, 10 invisible), 2,593 guests, and 38 spiders.
Topics306,061
Posts5,286,646
Members71,593
Timing chain guide wear #5433495 05/19/20 04:39 PM
V
vavavroom Offline OP
V
This is just a general question in regard to timing chain guides and not related to any particular engine. Timing chain guides are known to wear out and or break eventually. When does a timing chain actually make contact with the chain guide? Does that happen only once a chain tensioner has gone too soft or are there other conditions that result in the chain contacting the chain guides, such as a rapid load change resulting in chain slap?
Re: Timing chain guide wear [Re: vavavroom] #5433527 05/19/20 05:18 PM
B
bbhero Offline
B
I may well be wrong... But in some engines like my VQ the timing chain contacts the guides quite a lot.... The guide material what it is made of matters a fair amount in terms of how well the guides actually hold up in service. And that is a big factor in timing chain guide life... Wrong material for timing chain guides are going to fail much, much sooner than ones with a well matched timing chain guide material.
Nissan Altima 3.5 Coupe
Cam2 Full synthetic 5w30 Carquest Blue 84356
"Treat your family like your friends and treat your friends like your family."
Re: Timing chain guide wear [Re: vavavroom] #5433528 05/19/20 05:23 PM
Cujet Offline
As a general rule, the tension side of the chain has a straight shot to the camshaft. The guide on the tension side is there to stop or reduce any "chain slap" (unnecessary chain movement). The tensioner is on the slack side and simply applies enough pressure to remove any play in the system. The tensioner itself is designed to keep modest pressure on the guide.
Re: Timing chain guide wear [Re: vavavroom] #5433557 05/19/20 05:52 PM
B
benjy Offline
B
a xxw30 oil is said to be better for chain guides, i always use a 10-30 fake synthetic year around in pa
Re: Timing chain guide wear [Re: vavavroom] #5433565 05/19/20 06:02 PM
W
WobblyElvis Offline
W
The chain guides in my old GM ecotec contacted the chain constantly and remarkably lasted over 230,000 miles with very low wear. It appeared to me the chain and guides would last over 300,000 miles easily but I lost the car to an accident.
Re: Timing chain guide wear [Re: vavavroom] #5433580 05/19/20 06:17 PM
V
V
This all sounds like chain guides are a lot more in contact with the chain than I expected. That makes the chain guides wear parts.
Re: Timing chain guide wear [Re: vavavroom] #5433587 05/19/20 06:25 PM
B
bbhero Offline
B
True I believe...
The chain guide material is a big factor in how well they hold up....
Re: Timing chain guide wear [Re: vavavroom] #5433608 05/19/20 06:52 PM
Chris142 Offline
The guides guide the chain. The 2 are constantly rubbing when the engine is running.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Timing chain guide wear [Re: vavavroom] #5433721 05/19/20 09:24 PM
U
UncleDave Offline
U
Yup - some set ups worse than others.
Typically a nylon type material in constant contact with the chain.
UD
Uncle Dave
Cat 3126/2 MB3500/Titan/RX400H/17 Ridgeline
700HP V10/ 725HP BBC/ Raptor 700/ KFX450/ YZ250/Onan 8K/ Cat3011C
Re: Timing chain guide wear [Re: vavavroom] #5433744 05/19/20 10:00 PM
StarCaller Offline
Quote
why would that be?
the heavier the better?
so a xxw40 would be even better?
Re: Timing chain guide wear [Re: StarCaller] #5434628 05/20/20 09:17 PM
B
bulwnkl Offline
B
That principle can NOT be extended to infiniti.
I use speech recognition frequently. Please excuse any consequent grammatical or typographical errors.
Re: Timing chain guide wear [Re: vavavroom] #5434741 05/21/20 02:46 AM
R
Redright9 Offline
R
My 5.7l Hemi the tensioner is in constant contact with the chain. So far its doing well, I was able to peek at it recently, the engine has 170k + miles and doing well.
Re: Timing chain guide wear [Re: vavavroom] #5439881 05/27/20 05:51 AM
W
WyrTwister Offline
W
I have read some engines have a lot more chain / guide problems , than others . In those cases , I also read , such repairs , can be pretty expensive ? I also read HIGH quality synthetic oil is preferred ? ( In any case , which will not hurt anything . )
A timing belt may be preferred ? Do not know . Our Sonic 1.8l is the first car we have owned that had a timing belt . It has not reached the recommended mileage to replace . And , as far as I know , we have not owned a car that has timing chain guides ? Although RA shows a timing dampener . Maybe that is similar ?
https://www.rockauto.com/en/catalog/buick,2006,lacrosse,3.8l+v6,1432026,engine,timing+damper,5740
Wyr
God bless
Re: Timing chain guide wear [Re: WyrTwister] #5439920 05/27/20 07:26 AM
T
tbm5690 Online Content
Online Content
T
Most prefer chains due to the maintenance-free aspect (mostly). Chains do slack over time, and belts are not only quieter but also usually not terribly expensive to replace at intervals of 80-100k plus.
2014 Acura MDX Tech SH-AWD
2014 Nissan Maxima SV Sport & Tech
2007 Honda Shadow Spirit VT1100C
