Australia Energy Costs
by Y_K - 06/06/20 12:17 AM
Total Repair Costs over 200,000 miles
by Palut - 06/06/20 12:08 AM
Vredestein will start making American-market specific tires
by slacktide_bitog - 06/05/20 11:33 PM
Fried plantain question
by aquariuscsm - 06/05/20 11:08 PM
Castrol Edge LL IV 0w20, not majority PAO
by wemay - 06/05/20 09:08 PM
Fram Titanium 20k mile oil filters at AAP....
by bbhero - 06/05/20 09:04 PM
D-Day 🇺🇸
by kstanf150 - 06/05/20 08:57 PM
Husqvarna 5.2 ounce 2 stroke oil .39 ymmv
by maintenanceMan - 06/05/20 08:53 PM
Mobil 1 Permazone
by maverickfhs - 06/05/20 07:47 PM
2 stroke oil
by opus - 06/05/20 06:19 PM
McKinney Falls State Park - Austin, TX
by wwillson - 06/05/20 05:22 PM
Gen 5 Rams (2019+)
by The Critic - 06/05/20 05:03 PM
CarQuest R95140 Cut Open
by HX520W - 06/05/20 04:47 PM
2012 Tacoma steering very stiff?
by wagsrk08 - 06/05/20 04:44 PM
"Quick change" sabotage episode
by Kira - 06/05/20 04:40 PM
Two Motorcraft FL400S Filters Cut Open
by HX520W - 06/05/20 04:36 PM
VIN character that designates engine
by grampi - 06/05/20 04:35 PM
Two WIX 57356XP Filters Cut Open
by HX520W - 06/05/20 04:17 PM
3Dperf, LouK2, Michael328i, tyman, Knot_A_Mekanik
71616 Registered Users
59 registered members (4WD, blufeb95, bbhero, BlakeB, bamorris2, 5 invisible), 1,158 guests, and 65 spiders.
Topics306,273
Posts5,289,387
Members71,616
Page 1 of 3 1 2 3
Playing with Electricity. #5433481 05/19/20 04:26 PM
H
hatt Offline OP
H
I've done all sorts of stuff. Remodeled houses, built furniture, rebuilt engines,and so on. One thing I've never fooled with was electrical wiring. Always a little scared of it. My big garage came with several different weird outlets I didn't use. I don't know what all they were doing in there. I've been wanting to convert my air compressor and table saw to high voltage for years. Had an odd 30 amp 250V outlet. I did some research. The results were popping out the breaker to replace with 20 amp and adding a 6-20 receptacle. Put a new plug on the air compressor and reconfigured the motor. Success! Freed up the 125V 20A outlet in the area. Next project is replacing an unused 125V 30A outlet with a 125V 20A GFCI. I already replaced the 30 amp breaker with a 20 amp while I was in the panel.
2013 F150 5.0, Delo 400 SD 15W-30, Wix 57502
2010 Camry 2.5, PP 10W-30, Mobil1 M1C-251A
Re: Playing with Electricity. [Re: hatt] #5433485 05/19/20 04:29 PM
E
eljefino Offline
E
So does it run faster now?
Re: Playing with Electricity. [Re: eljefino] #5433488 05/19/20 04:31 PM
H
hatt Offline OP
H
No but it runs at half the amps.
Re: Playing with Electricity. [Re: hatt] #5433500 05/19/20 04:44 PM
KJSmith Offline
Half the amps at twice the voltage cost the same.
Re: Playing with Electricity. [Re: hatt] #5433502 05/19/20 04:45 PM
E
exranger06 Offline
E
What is the HP rating of the motor?
2006 Ford Ranger Sport
1992 Honda Accord EX
2013 Toyota Sienna XLE AWD
1994 Ford Bronco XLT (project)
2011 Cadillac Escalade ESV (wife's)
Re: Playing with Electricity. [Re: KJSmith] #5433503 05/19/20 04:46 PM
V
VetteElite Offline
V
Theoretically, yes, but in reality it would cost (slightly) less because it's more efficient.
Re: Playing with Electricity. [Re: exranger06] #5433508 05/19/20 04:51 PM
H
hatt Offline OP
H
Don't remember what the fake rating on the compressor is. Probably 15 HP or something. LOL
The motor says 125v 15A or 250V 7.4A.
Re: Playing with Electricity. [Re: hatt] #5433511 05/19/20 04:53 PM
J
JimPghPA Online Content
Online Content
J
What are you intending to run on the 125V 20 A GFCI? Some things do not play well with GFCI. Water heaters are notorious for being electrically leaky to the point that they can be impossible to run on a GFCI, and some motors are also bad. GFCI can save someones life when they prevent them from being electrocuted, but there are some applications where they just do not work.
If you have a particular appliance in mind to run on a GFCI it would be nice to know in advance if it can be ran on a GFCI before you want to use it.
Boy will I be happy when ALL vehicles on public roads are autonomous.
JimPghPa
Re: Playing with Electricity. [Re: JimPghPA] #5433515 05/19/20 04:59 PM
H
hatt Offline OP
H
125V 20A GFCI is just a regular old outlet. GFCI required in sheds. All the other outlets are 125V 20A GFCI so I'm going to keep it consistent.
Re: Playing with Electricity. [Re: JimPghPA] #5433534 05/19/20 05:29 PM
W
Wolf359 Online Content
Online Content
W
If you're going to put a dedicated appliance on it, you don't need a GFCI. I think I looked it up in the code book. Inspector wanted me to put a GFCI in a laundry room where there wasn't even a sink and claimed that the cold and hot for the washer were enough. But I ended up putting in a single outlet dedicated to the washer so I wouldn't have to do the GFCI. There are things you don't want on a GFCI like a refrigerator. Wouldn't want that to accidentally trip and then have all your food spoil.
Re: Playing with Electricity. [Re: hatt] #5433536 05/19/20 05:30 PM
Number_35 Offline
120 V x 15 A = 1800 W. 1 HP = 746 W, so in theory the motor would be almost 2-1/2 HP. However, that's assuming a perfect motor, that would convert the entirety of the input energy into rotational power out, with no losses. In practice, I think it would be 2 HP at best, and likely less.
Re: Playing with Electricity. [Re: hatt] #5433543 05/19/20 05:39 PM
H
hatt Offline OP
H
I was able to find made in USA plates, receptacle, and plugs so that was nice. Not sure where the Square D breakers are made but I didn't have any choice in that matter. I forget to look at the breaker to see if it said anything.
Re: Playing with Electricity. [Re: hatt] #5433586 05/19/20 06:24 PM
B
bbhero Online Content
Online Content
B
You know the saying from Clint Eastwood...
"Every man has got to know his limitations".
LOL
Sounds like you did a good job.
Nissan Altima 3.5 Coupe
Cam2 SuperproMax 5w30 Wix Gold 57356
"Treat your family like your friends and treat your friends like your family."
Re: Playing with Electricity. [Re: hatt] #5433590 05/19/20 06:29 PM
F
Farnsworth Offline
F
Was the wiring #10 to the 30a outlets? On my house I found a 30 amp breaker from long ago protecting #14 wire. If #10 four wire you could put in a small subpanel.
Re: Playing with Electricity. [Re: bbhero] #5433594 05/19/20 06:32 PM
H
hatt Offline OP
H
LOL
My neighbor was laughing at me so I figured it was time to get some basic household electrical knowledge.
Page 1 of 3 1 2 3
