KIA TYPE 4 (M) ATF
by flinter - 05/28/20 08:49 PM
My new Henry 22 Magnum rifle
by tig1 - 05/28/20 08:45 PM
Mobil 1 M-102 for 3 6000km oil changes?
by pktrkt - 05/28/20 08:33 PM
1/2 75W-90 1/2 75W-110 Can you mix equal parts
by jrommelt - 05/28/20 08:22 PM
Mazda b4000 to the junkyard
by HyundaiAbuser - 05/28/20 08:20 PM
2017 RAM 2500 6.4 Hemi AMSoil and PUP
by Gondul - 05/28/20 07:50 PM
Nail in tire, what would you do?
by Brybo86 - 05/28/20 07:44 PM
Any decent lap tops for $200.00 or less?
by BAJA_05 - 05/28/20 06:49 PM
New PW with Honda 190 engine - Ethanol treatment?
by DirtyApe - 05/28/20 06:38 PM
What size tube should a 110/50-6.5 Tire use?
by taztheman - 05/28/20 06:14 PM
C&P Allison Transmission Filter - 27k miles, 3 years
by shibby6600 - 05/28/20 05:51 PM
XG9100 - 7k miles - 9 months - filter magnet
by shibby6600 - 05/28/20 05:47 PM
2017 Audi A4 PCV Valve replacement
by dbias - 05/28/20 05:23 PM
Audi E-Tron Technik
by OVERKILL - 05/28/20 05:12 PM
Deer 1....My Avalon 0
by ZZman - 05/28/20 03:21 PM
Auto Dealers Supplies?
by cknight49090 - 05/28/20 03:09 PM
interesting video reg vs premium
by raaizin - 05/28/20 02:55 PM
Discount Tire Direct FLASH SALE
by Mr Nice - 05/28/20 02:42 PM
2021 Acura TLX Sports
by buster - 05/28/20 01:36 PM
Kboggs, oldcodger, cwllams1, Danwrig, DanielR
71558 Registered Users
102 registered members (830Lee, 4WD, agarb, Alfred_B, 10WSmuckers, ammolab, 10 invisible), 2,257 guests, and 44 spiders.
Topics305,996
Posts5,284,323
Members71,558
Page 1 of 3 1 2 3
I found my 3.5 liter Ecoboost oil...Chevron Delo 5W40 CK4 #5433228 05/19/20 11:14 AM
N
Navi Offline OP
N
As some here might know the 3.5 liter Ecoboost engine has some problems such as dilution or shearing the stock 5W30 Semi Synthetic down to 5W20. It has things like cold start rattle and a list of different things. Another key thing is the engine seemingly running too hot sometimes over 220 degrees F!
I just dont believe the Motorcraft 5W30 Semi Synthetic is appropriate for this monster. So I looked around on the internet to find other turbo guys facing similar problems and were successfully using 5W40 HDEO most notably Rotella T6. I took note but I wanted to be cautious and didnt use T6 because its not rated for gas engines.
So I turned to Mobil 1 Turbo Diesel Truck 5W40 and Mobil Delvac 1 5W40 ESP. I had great results. The engine seemed to run a little cooler with both, ran smoother and the Blackstone lab reports came back with superior results and praise from the Blackstone people.
However I wanted to give Chevron Delo 5W40 CK4 a shot. The Delo is about 20% thicker and is API SN Plus and not just API SN like the Mobil variety. Chevron assures us its truly mixed fleet and will work in whatever you pour it into. Gives some of us more assurance that its good to pour into the crank unlike Rotella T6 where where when you email Shell they give you a resounding No for gas engine use.
So far the engine is the quietest its been and smooth. Temperature control is superior and I can easily cruise around under 200 degrees F. When I jump on it there isnt the temperature spikes Ive seen with the 5W30 where quite suddenly Im pushing 220+. Its been a lot steadier.
In the future I plan on testing the oil through Blackstone to determine which is the better oil...Delvac or Delo.
[Linked Image]
Re: I found my 3.5 liter Ecoboost oil...Chevron Delo 5W40 CK4 [Re: Navi] #5433244 05/19/20 11:30 AM
T
tcp71 Offline
T
I run Castrol 0w40. Have since the 500 mile mark. Temperature spikes are caused by the location of the thermostat, at the coolant intake to the engine and the location the the temperature sensor, at the coolant exit of the engine. There also a junction near the thermostat where coolant is split to the engine and turbos so it’s not as easy a flow into the engine for cooling.
Notice how quickly the temperature drops when you get out of boost. Gen 1 or gen 2 eco both have this characteristic. Your oil temperature doesn’t fluctuate nearly as quickly.
2016 F150 Eco: Edge 0w40
2005 Sienna 3.3: PP 5w30 syn. (varies)
Re: I found my 3.5 liter Ecoboost oil...Chevron Delo 5W40 CK4 [Re: Navi] #5433277 05/19/20 12:26 PM
X
xyxptlx Offline
X
Are you talking coolant temperature or oil temperature? How are you measuring it, with the dash instruments?
Re: I found my 3.5 liter Ecoboost oil...Chevron Delo 5W40 CK4 [Re: Navi] #5433286 05/19/20 12:34 PM
DavidJones Offline
You will run your 3.5 for a few hundred thousand miles to gauge the new oils effectiveness vs the Motorcraft?
My garage.....2012 Toyota Highlander (wife's), 2016 Ford 2.7EB F150(mine), 1969 Pontiac GTO, 2005 Double cab Tundra(son), 2015 Honda Accord EX(son).
Re: I found my 3.5 liter Ecoboost oil...Chevron Delo 5W40 CK4 [Re: Navi] #5433291 05/19/20 12:37 PM
IMSA_Racing_Fan Offline
Good on you. Your engine thanks you too.
Re: I found my 3.5 liter Ecoboost oil...Chevron Delo 5W40 CK4 [Re: Navi] #5433302 05/19/20 12:46 PM
Cujet Offline
Very good choice. I regularly suggest more viscosity and more frequent oil changes for 3.5EB owners. One thing is very clear, good maintenance practices are needed on the EB engines.
Re: I found my 3.5 liter Ecoboost oil...Chevron Delo 5W40 CK4 [Re: Navi] #5433311 05/19/20 12:53 PM
4WD Online Confused
Online Confused
Seems 50% of the T6, T6, T6, bumps you’re going to see here all day never even consider Delo/Delvac …
The other half are just questionable recommendations …
Re: I found my 3.5 liter Ecoboost oil...Chevron Delo 5W40 CK4 [Re: Navi] #5433334 05/19/20 01:19 PM
L
loneryder Offline
L
Just be aware that it has a lot less zinc and phos than TDT. I won't run it in my MB v6 diesel.
Re: I found my 3.5 liter Ecoboost oil...Chevron Delo 5W40 CK4 [Re: Navi] #5433338 05/19/20 01:24 PM
stockrex Offline
My 3.5 has fuel dilution issues, so it does not matter what I run, I stick to a 5w30 syn and drop it 4k to 5k miles.
Ridgeline, Dmax, Ford 3.5
Oil Whisperer!*Fear the DINO*
Re: I found my 3.5 liter Ecoboost oil...Chevron Delo 5W40 CK4 [Re: Navi] #5433354 05/19/20 01:42 PM
I
IndyFan Offline
I
I may give this a try. My Ecoboost has run fine on Mobil 1 EP or AP 5w30 for 10k, but it has the cold weather noise, for sure. I'm going to do a Blackstone report on the current M1 EP run at 10k and see what it shows. I may throw some of this in for a run and get it analyzed, too.
My Ecoboost is starting to get some miles on it, but it runs perfectly. I do love this engine. It is shocking how it moves our big Transit with authority and can still easily get 19mpg on the highway with 12 people in it.
18 Jeep JLUR Wrangler 3.6 31k
15 Ford Transit 129k, Reman 3.5 @85k
17 Jeep Renegade 2.4 29k
08 Jeep Wrangler 3.8 141k
04 Jeep Grand Cherokee 4.7 111k
99 Mercedes E430 Sport 90k
Re: I found my 3.5 liter Ecoboost oil...Chevron Delo 5W40 CK4 [Re: IndyFan] #5433373 05/19/20 02:02 PM
4WD Online Confused
Online Confused
Yeah … my son just got a Mustang with the 2.3L eB … nobody told that motor it’s small 🧐
Re: I found my 3.5 liter Ecoboost oil...Chevron Delo 5W40 CK4 [Re: Navi] #5433403 05/19/20 02:35 PM
N
Navi Offline OP
N
The jury is still out on Delo since I havent had it in that long. However I do l l know that both Turbo Diesel Truck 5W40 and Delvac worked well in the Ecoboost. Blackstone reports came back very well. I would like to do another round with the Mobil 1 TDT for a complete comparison against Delvac.
Delo is a competitor to Delvac and this is their newest and greatest formula. So lets see how it goes.
Comparing Blackstone VOAs found on the internet and the oil product data sheets Delo is a bit thicker with a [email protected] in mid to high 15s while Delvac is low to mid 13s. Delvac probably has higher quality base stock and possibly group 4. Delo is known as a group IIi oil.
In any event any of the oils mentioned here will do well with Ecoboost engines. If you have fuel dilution like mine I believe it came back in the high 11s/low 12s after 5000 miles for both TDT and Delvac.
Nope not going to put that 5W30 semisynth back in. BTW TDT and Delo are Walmart shelf oils. Delvac I got from Summit Racing at the best price. I think you can order Delvac on the Walmart website.
Re: I found my 3.5 liter Ecoboost oil...Chevron Delo 5W40 CK4 [Re: Navi] #5433418 05/19/20 02:53 PM
I
IndyFan Offline
I
Thanks for posting this. Can you throw your Delvac UOA on here? I'd love to see it. I'll be watching for when you do one on the Delo. I've still got a ways to go, but I'll post up a UOA for the current run of M1EP when I change the oil and get the results.
Re: I found my 3.5 liter Ecoboost oil...Chevron Delo 5W40 CK4 [Re: Navi] #5433420 05/19/20 02:54 PM
4WD Online Confused
Online Confused
The Delvac 1 gear oil tends to be a best deal at Summit too …
free shipping at $100 so I have tossed in spark plug wires etc …
Re: I found my 3.5 liter Ecoboost oil...Chevron Delo 5W40 CK4 [Re: Navi] #5433431 05/19/20 03:12 PM
N
Navi Offline OP
N
Both columns are Mobil Delvac 5W40 ESP.
[Linked Image]
Page 1 of 3 1 2 3
