Rockauto code expires 8/2
by gallydif - 06/02/20 08:19 AM
The worst job you ever had?
by Chris142 - 06/02/20 08:04 AM
P218F on my Ford PSD
by Donald - 06/02/20 06:34 AM
Kudos to Griot's
by Egg_Head - 06/02/20 05:43 AM
Exide Battery files for bankruptcy
by Randol - 06/02/20 04:34 AM
Just one more wax question.
by rrretiree7 - 06/02/20 01:49 AM
Removing stuck bolts- interesting technique
by rubberchicken - 06/02/20 12:47 AM
Unless it is a misprint?
by 340_Magnum - 06/01/20 10:25 PM
Raymond Weil 5590 Watch Battery Replacement
by maverickfhs - 06/01/20 09:22 PM
Echo SRM 230 idling high
by CDX825 - 06/01/20 08:40 PM
Walmart in Canada closing Lube and Tire Express
by Snagglefoot - 06/01/20 08:26 PM
2012 Sonic - LCA puck bushing
by Number_35 - 06/01/20 06:44 PM
Rotate mags?
by marine65 - 06/01/20 06:40 PM
Re-using good coolant?
by Jarpin - 06/01/20 06:21 PM
Best entry level riding mower
by UncleDave - 06/01/20 03:02 PM
2015 Pilot LX
by madRiver - 06/01/20 03:01 PM
NewMex, RandyN11049, bbrtuning, chapys, DaaBoss
71593 Registered Users
95 registered members (3turbodiesels, AbbyMaster, aaronc7, 86cutlass307, 53' Stude, 830Lee, 4 invisible), 2,199 guests, and 37 spiders.
Topics306,053
Posts5,286,541
Members71,593
Idiot moment - Mixed Honda Dual Pump and ATF #5433112 05/19/20 09:03 AM
J
JoeK Offline OP
J
Last evenings project was to change the ATF in my Honda CRV and also the rear differential fluid with Honda Dual pump fluid bop
You can probably guess where this is going. Changed the rear diff fluid with Honda Dual Pump fluid as I've done in the past, then moved on to the ATF project.
I've changed this CRV transmission fluid yearly by doing a double drain and fill process. Since I do it yearly, I only do the procedure twice, each time draining approximately 3 quarts, running the vehicle, and then draining 3 quarts and repeating. Following this procedure, we are technically refreshing the fluid since only around half of it is drained out and replaced with each fill.
The screw-up occurred when I mistakenly grabbed a quart of dual pump and poured it into the transmission during the first drain and fill procedure. I didn't realize it until I went to do the second drain and fill and realized I had an extra quart of ATF, and an extra empty bottle of Dual Pump fluid.
IF I'm doing the match correctly, since I added a quart of dual pump and then drained the transmission again, I still have 1/2 quart of dual pump in the transmission.
Does anyone know the properties of the Dual Pump Fluid and what effect this could have on the transmission. I've ordered more ATF and will drain and fill at least 1 more time, or possibly 2 or 3 more times to eliminate as much of the incorrect fluid as possible. Any thoughts by the experts who know what fluid this is, if 1 more drain or fill will be adequate or if I should keep doing it repeatedly. Obviously drains and fills are expensive, but damage to the tranny is more expensive.
Any suggestions are appreciated.
Re: Idiot moment - Mixed Honda Dual Pump and ATF [Re: JoeK] #5433123 05/19/20 09:19 AM
slacktide_bitog Offline
If you used the wrong fluid, do at least 3-4 drain and fills to get all of it out smile
Re: Idiot moment - Mixed Honda Dual Pump and ATF [Re: JoeK] #5433124 05/19/20 09:21 AM
B
blufeb95 Offline
B
2009 Honda CRV EX-L Diffferential with VOA Added I
The VOA seems to show that it's fairly similar to DW-1/Z-1, I wouldn't be too bothered by having a small amount of it diluted in DW-1.
Re: Idiot moment - Mixed Honda Dual Pump and ATF [Re: JoeK] #5433125 05/19/20 09:22 AM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
The dilution ratio is based upon the total quantity in the system, not just how much you drain out. I dont know how much is in the system total.
Seems like a good idea to do one drain to get some of it out and dilute it. In reality, its somewhere between say, 10-20% of the overall system fluid. It may not be enough to make a huge difference in protection or driveability.
How different are the two fluids? If its like two different more or less ATF-like fluids I wouldnt much worry. If its like ATF and gear oil, Id be a bit more worried.
In the end, Im not sure there is much you can truly do but get some mixing, drain, dilute. "dilution is the solution to pollution"
Re: Idiot moment - Mixed Honda Dual Pump and ATF [Re: JoeK] #5433133 05/19/20 09:31 AM
B
blufeb95 Offline
B
In general looking up several model years of CRV on Amsoil's website the transmissions seem to be the typical Honda design, the pan holds about 33-40% of the system capacity, so when you drain you'll be left with approx 2/3qt of the dual pump, then the next DnF you'll be left with just under half a quart, the transmissions seem to hold around 7qts, so that's less than 10%, I wouldn't sweat it, I wouldn't fill a whole transmission with dual pump fluid, but it appears similar enough that having 5-10% of it in there shouldn't be a problem.
Re: Idiot moment - Mixed Honda Dual Pump and ATF [Re: JoeK] #5433143 05/19/20 09:42 AM
T
tcp71 Offline
T
Anything that goes into a differential could cause havoc with the clutches or friction requirements in a transmission, CVT or otherwise. I would get it professionally flushed and not so much as turn the ignition on before that moment.
2016 F150 Eco: Edge 0w40
2005 Sienna 3.3: PP 5w30 syn. (varies)
Re: Idiot moment - Mixed Honda Dual Pump and ATF [Re: JoeK] #5433162 05/19/20 09:56 AM
J
JoeK Offline OP
J
Thanks for the advice guys.
The fluid analysis information helped a bit with my concern. The wife had to drive the car today about 15 miles for work, and I've been very concerned about it, but having her miss work wasn't an option.
The dilution numbers and capacity given above were pretty accurate. Honda suggests a 4 time DnF with each time replacing a percentage of the total capacity with fresh fluid. They don't publish the total capacity but it is around 7 quarts and they say 2.7 drains out, but I usually get closer to 3.
If I assume 1/3 is drained and refilled, the percentage of old after each Dnf would be below
First change 33/67%
2nd change 55/45%
3rd change 70/30%
4th change 80/20%
Using 40% as the percentage drained, the numbers look a lot better
First change 40/60%
2nd change 64/36%
3rd change 79/21%
4th change 87/13%
So if I put 32 ounces of Dual Pump fluid initially and changed it once before she drove it, there would have been around 20 ounces of Dual Pump Fluid in the tranny.
I'll change it a couple more times and should be able to get the total amount of incorrect fluid down under 8 ounces at which point, the cost of changing it becomes high compared to ounce or two of bad fluid I'm getting out at each change. Furthermore, the fluid analysis shows the material is not completely unlike an ATF and hopefully I've caused no long term damage.
Re: Idiot moment - Mixed Honda Dual Pump and ATF [Re: tcp71] #5433174 05/19/20 10:04 AM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
Believe the VOA posted higher up indicates otherwise. I had the same concern - if one is like gear oil with a sulfur based add pack, and the other was more like an ATF, they may not jive. But my interpretation is that this is not the case. Still prudent to flush a time or three.
Re: Idiot moment - Mixed Honda Dual Pump and ATF [Re: JHZR2] #5433177 05/19/20 10:12 AM
B
blufeb95 Offline
B
Consider Honda diffs used to be spec'd to use Z1 ATF, then when DW-1 came along they said to use DW-1 in transmissions and Dual Pump II in Diffs. So wouldn't surprise if Dual Pump is more ATF life than gear oil like.
Re: Idiot moment - Mixed Honda Dual Pump and ATF [Re: JoeK] #5433182 05/19/20 10:21 AM
G
Gebo Offline
G
Assuming you get 3 qts out of a 7 qt capacity, 4 drain and fills would put you at 90% new fluid. I got this "super duper" excel chart.
Since you have only 14% of the wrong fluid to begin with (1 qt in 7 total qts) I don't know how far to go with drain and fills.
At first change you will have 43% new fluid so you got rid of 43% of the bad qt
At 2nd change you will have 67% new fluid so you got rid of 67% of the bad qt
At 3rd change you will have 81% new fluid so you got rid of 81% of the bad qt
At 4th change you will have 89% new fluid so you got rid of 89% of the bad qt
At 5th change you will have 94% new fluid so you got rid of 94% of the bad qt
May math may not be the best but it should be close.
'98 LEX LS400 310K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 75K
Shell Gas and Truck 5w-30
Amsoil OE 10w-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: Idiot moment - Mixed Honda Dual Pump and ATF [Re: JoeK] #5433189 05/19/20 10:28 AM
J
JeffKeryk Offline
J
Can you remove a transmission-to-radiator cooler line and flush the fluid?
Say, 2 quarts at a time?
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: Idiot moment - Mixed Honda Dual Pump and ATF [Re: Gebo] #5433256 05/19/20 11:50 AM
J
JoeK Offline OP
J
Thanks for the calculations. Also to clarify, the Drain n Fill is the only method to change fluid. Flushing or feed and bleed through the cooler lines is not recommended.
After everyone's comments, and out of an abundance of caution, I just came back from purchasing 6 more quarts of fluid from a local dealership parts department at their inflated price and will D n F it twice more tonight for a total of 3 changes since my bonehead move spank
After the 3rd change, following the math above, I will have around 6 ounces of the bad fluid left which will be diluted with 7 quarts of proper fluid which knowing now that the fluids are somewhat compatible, I'll sleep a little better.
I'll allow the car to be driven again and after the case of fluid I ordered online at a discount comes in next week, I'll do one more D n F.
Thanks again for the advice Cheers2
Re: Idiot moment - Mixed Honda Dual Pump and ATF [Re: JoeK] #5433267 05/19/20 12:11 PM
J
JimPghPA Offline
J
OP, What year is your CR-V and is it front wheel only drive or all 4?
With that information, accurate information about the total system capacity can be found on the Amsoil web site.
Boy will I be happy when ALL vehicles on public roads are autonomous.
JimPghPa
Re: Idiot moment - Mixed Honda Dual Pump and ATF [Re: JoeK] #5433270 05/19/20 12:16 PM
J
JimPghPA Offline
J
OP, thanks for sharing your mistake. If I ever do the CVT fluid and rear-end fluid the same day in the future I will know to be sure to keep the fluids separate. Your sharing the information about the possibility of this mix-up may save others from making the same mistake.
JimPghPa
Re: Idiot moment - Mixed Honda Dual Pump and ATF [Re: JimPghPA] #5433584 05/19/20 06:22 PM
A
ammolab Offline
A
He was changing the rear diff and used rear diff fluid in his tranny... Seems like he has a 4 wheel drive CR-V, right?
1998 Jeep Cherokee
2011 BMW R1200R
2005 Kaw Ninja 250
1994 Jeep Wrangler 2.5L
2016 Chevy SS Sport Sedan
