Eezox vs Prolix?
by Gebo - 06/03/20 11:49 AM
Walmart closing all Tire and Lube Express in Canada
by tenderloin - 06/03/20 10:38 AM
Seeking Exterior Home Aesthetic Advice (UPDATE!)
by DriveHard - 06/03/20 10:22 AM
Do you have your home HVAC system maintained?
by E150GT - 06/03/20 09:21 AM
Mixing vavoline & mobil
by ThePCMasterRace - 06/03/20 09:03 AM
Pre-Oiler?
by AJB0009 - 06/03/20 09:02 AM
1992 Acura NSX, Red Line 10W-30, ~1400 miles/1 year
by robertcope - 06/03/20 06:37 AM
Rural telephone boxes along road
by dlundblad - 06/03/20 05:06 AM
Mobil1 12 quart $30 at Walmart
by wkcars - 06/03/20 12:58 AM
"The Bright Knight"
by GumbyJarvis - 06/03/20 12:35 AM
Pennzoil Axle oil with LSA.
by Snagglefoot - 06/02/20 10:03 PM
Replaced the plugs on the bike: HUGE improvement!
by 14Accent - 06/02/20 09:26 PM
Accord Trans Case crack (bad casting?)
by redhat - 06/02/20 08:38 PM
Replacement SLA Battery for Clore Jumper
by SubLGT - 06/02/20 08:34 PM
ABS codes
by 2010Civic - 06/02/20 08:02 PM
Tie rod ends - which manufactures ok?
by jdw1222 - 06/02/20 07:40 PM
Who makes their own seltzer water?
by JLawrence08648 - 06/02/20 07:23 PM
boathead, Digital_Dad, RobertChapmant, NewMex, RandyN11049
71596 Registered Users
75 registered members (aquariuscsm, 2011335d, ABN_CBT_ENGR, 830Lee, Alfred_B, 2_Tall_Mitchell, 6 invisible), 2,111 guests, and 77 spiders.
Topics306,090
Posts5,287,245
Members71,596
What oil? #5433068 05/19/20 08:21 AM
I
IvanPletex Offline OP
I
Hi, what oil would be the best for the small diesel engine with chain as timing belt?
For now I am using shell helix ultra diesel 5w40, but that oil has low viscosity at 40°C and 100°C compared to the others( Selenia WR 5w40, Total quartz 9000 energy etc.)
Should I use oil with higher viscosity index and viscosity at 40°C, 100°C ?
Does higher viscosity means more protection and shear stability or not?
What would you recommend?
Re: What oil? [Re: IvanPletex] #5433106 05/19/20 08:55 AM
CT8 Offline
What specs does the owners manual recommend for that particular engine?
2015 F150 2.7
2018 F350 6.2
Re: What oil? [Re: CT8] #5433113 05/19/20 09:03 AM
I
I
SAE 5w40, ACEA B4
Re: What oil? [Re: IvanPletex] #5433195 05/19/20 10:33 AM
CT8 Offline
That is a common spec. Oils from the major oil companies would be a safe bet.
2015 F150 2.7
2018 F350 6.2
