2016 Lexus RX350 Oil Change change
by Toros - 06/02/20 12:43 PM
Tire Mobility Kits
by wings&wheels - 06/02/20 12:06 PM
Worst accident you've witnessed
by Dave Sherman - 06/02/20 12:04 PM
Shock Fluid
by splinter - 06/02/20 11:21 AM
Michelin X-Ice 4 North for Canada ...
by odie - 06/02/20 11:03 AM
Rockauto code expires 8/2
by gallydif - 06/02/20 08:19 AM
The worst job you ever had?
by Chris142 - 06/02/20 08:04 AM
P218F on my Ford PSD
by Donald - 06/02/20 06:34 AM
Kudos to Griot's
by Egg_Head - 06/02/20 05:43 AM
Exide Battery files for bankruptcy
by Randol - 06/02/20 04:34 AM
Just one more wax question.
by rrretiree7 - 06/02/20 01:49 AM
Removing stuck bolts- interesting technique
by rubberchicken - 06/02/20 12:47 AM
Unless it is a misprint?
by 340_Magnum - 06/01/20 10:25 PM
Raymond Weil 5590 Watch Battery Replacement
by maverickfhs - 06/01/20 09:22 PM
Echo SRM 230 idling high
by CDX825 - 06/01/20 08:40 PM
Walmart in Canada closing Lube and Tire Express
by Snagglefoot - 06/01/20 08:26 PM
2012 Sonic - LCA puck bushing
by Number_35 - 06/01/20 06:44 PM
NewMex, RandyN11049, bbrtuning, chapys, DaaBoss
71593 Registered Users
83 registered members (2015_PSD, 390pi, 4WD, 14Accent, 87sammy, 4 invisible), 2,322 guests, and 60 spiders.
Topics306,058
Posts5,286,611
Members71,593
Supertech 5w30 Syn, 4283 miles, 2014 Hyundai SFS, 2.0T GDI #5433059 05/19/20 07:51 AM
R
Robster Offline OP
R
This was from my son's Hyundai Santa Fe. . . the oil ran through the past winter and he short-trips every day for work. No oil added or consumed during OCI. I think it did pretty well as compared to the previous test which was Pennzoil Platinum (circa 2015). Other than the TBN, it seemed to perform as well as the Pennzoil. I have no plans to run ST much beyond 4000 miles in this vehicle. NOTES: oil filter was a Fram XG9688; 3800 miles is my target OCI for this vehicle.
Attached PDF document
2017 RAM 1500 Big Horn 5.7L:Valvoline AFS 5w-20, Fram TG10060
2019 Hyundai Santa Fe Ultimate AWD 2.4L:Valvoline AFS 5w-20 / OEM filter
2013 Victory Cross Country:Valvoline 4T syn 10w-40, NAPA Gold
Re: Supertech 5w30 Syn, 4283 miles, 2014 Hyundai SFS, 2.0T GDI [Re: Robster] #5433080 05/19/20 08:30 AM
I
incognito_2u Offline
I
Thanks for sharing........
2006 Jeep Commander 3.7 V6 -116k (M1EP5W30/XG3600)
2006 Toyota Corolla 1.8 VVTi -88k (M1EP5W30/XG3600)
1999 Toyota Corolla 1.8 -92k (PUP5W30/XG4386)
1998 Toyota Corolla 1.8 -68k (VME5W30/XG3600)
Re: Supertech 5w30 Syn, 4283 miles, 2014 Hyundai SFS, 2.0T GDI [Re: Robster] #5433139 05/19/20 09:40 AM
P
Polyalphaolefin Offline
P
I'd say its poor quality oil due to loss of viscosity and poor fuel quzality (hi sulphur) due to low TBN remaining. I wouldnt use that oil again. Here in EU oil change intervals are 30.000Km for those engines, and your sample is less than 8.000 Km.
Car: KIA Ceed JD 1.4 MPI
OIL: 5w30 ACEA A5 / A3; 5w40 ACEA A3; 0w40 ACEA A3
Re: Supertech 5w30 Syn, 4283 miles, 2014 Hyundai SFS, 2.0T GDI [Re: Robster] #5433181 05/19/20 10:20 AM
dave1251 Offline
Looks good and boring.
don't use.
Re: Supertech 5w30 Syn, 4283 miles, 2014 Hyundai SFS, 2.0T GDI [Re: Polyalphaolefin] #5433183 05/19/20 10:22 AM
dave1251 Offline
This car was not used in Europe.
don't use.
Re: Supertech 5w30 Syn, 4283 miles, 2014 Hyundai SFS, 2.0T GDI [Re: Robster] #5433215 05/19/20 10:58 AM
R
rob1715 Offline
R
ST oil has a higher than normal NOACK so for a GDI engine, I'd stick with lower NOACK PP or PUP which I use in my 2019 Sorento GDI. For non - GDI engines, ST is just fine and will do the job oil is intended to do.
Re: Supertech 5w30 Syn, 4283 miles, 2014 Hyundai SFS, 2.0T GDI [Re: Robster] #5433261 05/19/20 12:03 PM
wemay Offline
Thanks Robster,
Looks just fine for a 5K mile run in our SFS turbo.
2019 Volkswagen Passat Wolfsburg TSI: OE VW508.00 0W-20, OE filter
2013 Hyundai Santa Fe Sport 2.0T: RGT 5W-30, OE oil filter
Re: Supertech 5w30 Syn, 4283 miles, 2014 Hyundai SFS, 2.0T GDI [Re: rob1715] #5433797 05/20/20 12:17 AM
dave1251 Offline
NOACK? ST synthetic is a DEXOS certified lube it's better than it needs to be.
don't use.
Re: Supertech 5w30 Syn, 4283 miles, 2014 Hyundai SFS, 2.0T GDI [Re: Robster] #5433856 05/20/20 05:59 AM
M
Matagonka Offline
M
Yeah, viscosity was low but 5k miles is probably good for this car.
2018 Mazda 3 Touring HB 2.5
2020 Hyundai Palisade
Re: Supertech 5w30 Syn, 4283 miles, 2014 Hyundai SFS, 2.0T GDI [Re: Robster] #5435538 05/22/20 12:00 AM
ChrisD46 Offline
One of my new favorite synthetic oils for any GDI engine : Valvoline Advanced 5W30 synthetic D1 / G2 rated : Low NOACK , low VII's and a great add pack .
'17 Hyundai Sonata 2.4L GDI 5W30 PUP / Fram Ultra #9688
'10 Hyundai Elantra 2.0L 5W30 (50%) / 5W20 (50%) QSUD / Fram Ultra #9688
'07 Kia Sedona 3.8L 5W30 Castrol EP / Fram Ultra #9999
Re: Supertech 5w30 Syn, 4283 miles, 2014 Hyundai SFS, 2.0T GDI [Re: Robster] #5435764 05/22/20 10:36 AM
Z
Zaedock Offline
Z
Thanks for the report. I've used ST syn 5W30 in my wife's SXL. I have the Oil Change interval set at 4800 miles.
I just sampled the 9339 mile interval of Castrol Edge EP 5W30 that she ran during Covid. My wife is in early and out late (front line med) so I haven't had a chance to change until this week. The Castrol EP advertised 20K changes on DI turbo engines, so we'll see how it holds up to Hyundai/Kia.
2019 Escape EB AWD/2016 KIA Optima SXL 2.0L Turbo/2012 F150 Ex-cab 5.0L
1992 YJ "The Heep"/2015 Chrysler 200 Limited
1975 Ford Bronco/1959 Willys CJ5/Tube Rock crawler
Re: Supertech 5w30 Syn, 4283 miles, 2014 Hyundai SFS, 2.0T GDI [Re: Matagonka] #5435840 05/22/20 12:11 PM
dave1251 Offline
No it wasn't. Why do members act like oils shouldn't shear?
don't use.
Re: Supertech 5w30 Syn, 4283 miles, 2014 Hyundai SFS, 2.0T GDI [Re: Robster] #5435855 05/22/20 12:26 PM
J
JustinH Offline
J
Folks this is $14.96 for 5 quarts motor oil. I'd call it a great report in a turbo GDI application.
'16 Ford Escape
'11 Scion XB
Re: Supertech 5w30 Syn, 4283 miles, 2014 Hyundai SFS, 2.0T GDI [Re: Robster] #5435954 05/22/20 02:31 PM
H
haggler Offline
H
The visc and tbn loss is probably mostly from the fuel. No more than 4-5k on this oil. If the motor is ok to run with Xw-20, should not be a problem.
2019 MX-5 Soft Top Miata - Soul Red Crystal - M1 EP 0w20 - M1 EP 108a Filter
2020 Chevrolet Equinox - Factory Fill/Filter
Re: Supertech 5w30 Syn, 4283 miles, 2014 Hyundai SFS, 2.0T GDI [Re: haggler] #5435963 05/22/20 02:46 PM
K
kschachn Offline
K
Interesting, how does fuel dilution cause a drop in the TBN?
1994 BMW 530i, 252K
1996 Honda Accord, 288K
1999 Toyota Sienna, 434K
2000 Toyota ECHO, 284K
