Forums Migration
Please read this thread
Seafoam fuel injector cleaner
by hardcore302 - 07/11/20 01:02 AM
EP additive?
by CCI - 07/10/20 11:06 PM
Kawa FR600V Oil
by Propflux01 - 07/10/20 10:34 PM
Dexron VI for 700R4.
by jakewells - 07/10/20 10:22 PM
Picked Up the DeWalt Mid Range Impact
by Fringe - 07/10/20 09:42 PM
Checking out neighbours lawn mower
by Snagglefoot - 07/10/20 09:19 PM
TV help needed
by ffhdriver - 07/10/20 09:00 PM
FS Solar panels PU only 250w $80
by BeerCan - 07/10/20 08:29 PM
Ford Easy Fuel
by buck91 - 07/10/20 08:27 PM
Oil for the track
by lowon - 07/10/20 07:34 PM
Bought a grapple
by Ausfahrt - 07/10/20 06:30 PM
What is this charger for?
by CharlieJ - 07/10/20 05:58 PM
World War II movie Greyhound
by skyactiv - 07/10/20 05:48 PM
GC for Fuel Dilution - Accuracy
by Gene K - 07/10/20 05:21 PM
How Do I Get This On?
by Gebo - 07/10/20 05:08 PM
Creativity Suggestions?
by maverickfhs - 07/10/20 03:18 PM
3.5 Ecoboost Oil, I've decided.
by Gene K - 07/10/20 02:07 PM
Mopar Extended Warranty with 100% Refund Option
by The Critic - 07/10/20 12:46 PM
SUmeme22, DaveCaddell, SharkNC, Puckster02, TurbodogTodd
71907 Registered Users
24 registered members (Black_Thunder, 97prizm, bmod305, alchargo, AnthemBassMan, 2015Corolla, 2 invisible), 625 guests, and 28 spiders.
Topics307,709
Posts5,316,217
Members71,907
Page 1 of 3 1 2 3
I wonder sometimes..... #5432938 05/19/20 12:37 AM
clinebarger Offline OP
2011 Honda Pilot, J35 VCM with 123,xxx miles, Compliant.......A/C blowing warm air.
Went out to get the vehicle & upon start-up a loud rattle/knocking noise was coming from the engine. I immediately shut it down & checked the oil level....It was within operating range & fairly clean looking.
Left it where it was & called the customer to ask about the noise....."Yeah, That's been there for a while" crzy I asked if he would like that looked at? He said "Sure, I guess, But it runs fine"
Thought about it being a rocker arm, But the noise wasn't "In Time" with the valvetrain. My long screwdriver to the ear pinpointed it to the timing belt area. Tore the covers off & found what I thought was a collapsed tensioner.
Called the customer & quoted a timing belt kit, valve adjustment, & a A/C clutch relay, Customer declined the valve adjustment.
Turns out the tensioner was still sound hydraulically, But was worn down or the ram snapped off at the pin hole. Didn't find the tip of the ram anywhere. The tensioner pulley arm had quite a bit of wear as well. He's lucky it didn't jump time, I'm amazed he was more concerned about the A/C!
[Linked Image from i.imgur.com]
2001 Chevy Camaro L92/4L80E
Re: I wonder sometimes..... [Re: clinebarger] #5432940 05/19/20 12:38 AM
Here's the new tensioner for reference...
Re: I wonder sometimes..... [Re: clinebarger] #5432944 05/19/20 12:47 AM
O
oldhp Offline
O
Luck. Some guys could drop a 3/8" bolt down the valve cover and it would bounce thru the engine landing perfectly into the bottom of oil pan damaging nothing. Me? I could drop a "micro-atom" in the valve cover and it would wipe out the entire engine.
He has the "luck".
"None of us are getting out here alive...drink that beer...eat that pizza...drive that Hot Rod"
"When others cut you down, remember where they came from."
"I don't run...........I just quietly wait"
Re: I wonder sometimes..... [Re: clinebarger] #5432946 05/19/20 12:54 AM
T
The_Nuke Offline
T
If it were July or August, I would NOT be surprised that someone in Texas was more worried about the A/C than something not-A/C on their car.
But to do so in May when it hasnt even approached sweltering yet, yes, that’s a little strange.
2012 Charger Pursuit aka "The Bacon Hauler"
- 5.7L + NAG1 (A5) + 3.07 (215mm)
Re: I wonder sometimes..... [Re: clinebarger] #5432953 05/19/20 01:54 AM
daves87rs Offline
Wow.....
2020 Chevrolet Trax LS
2019 Chevrolet Equinox LS
2006 Chevrolet Cobalt LS
2004 Chevrolet Cavalier (project)
Re: I wonder sometimes..... [Re: clinebarger] #5432954 05/19/20 01:58 AM
W
WyrTwister Offline
W
Are most of the tensioners spring loaded or hydraulic / engine oil pressure ?
Wyr
God bless
Re: I wonder sometimes..... [Re: clinebarger] #5432966 05/19/20 02:44 AM
02SE Offline
I got that tensioner in two Aisin T-belt and water pump kits in a row, for a 5VZ-FE. I think someone at Aisin wasn't qualified to assemble the kits.
Re: I wonder sometimes..... [Re: clinebarger] #5432982 05/19/20 05:07 AM
IMSA_Racing_Fan Offline
Declined valve adjustment? My question is why does Honda make a utility daily driver engine that requires valve adjustments?
Re: I wonder sometimes..... [Re: clinebarger] #5433036 05/19/20 07:21 AM
Chris142 Offline
I am not amazed at all. I have a van in the shop with 9+ year old Firestone tires that are dry rotted and cracked. They want the AC fixed for their trip to AZ. I mentioned the tires and they are not concerned.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: I wonder sometimes..... [Re: clinebarger] #5433039 05/19/20 07:26 AM
4WD Offline
Well Chris … he was driving what is normally a modern quiet engine sounding like a 1939 tractor …
Nuff said.
Re: I wonder sometimes..... [Re: clinebarger] #5433052 05/19/20 07:41 AM
J
joekingcorvette Offline
J
With 123,000 on the clock I would have the valves adjusted too.
2005 Chevrolet Corvette
2014 Ford F-150 4x4 supercrew
2014 Jeep Grand Cherokee Limited (wifes)
2012 Honda Civic 4 door (my daily driver)
2007 Lund Tyee Grand Sport Mercury 115HP 9.8HP
Re: I wonder sometimes..... [Re: clinebarger] #5433063 05/19/20 08:16 AM
B
Barkleymut Offline
B
It starts and gets him from A to B. It works in his mind.
The AC is not blowing cold, so it does not work.
If only life were this simple, we would all be much happier!
09 Vue 2.4L 4spd AT/ 09 Flex 3.5L / 96 F150 5.0 5speed / 07 Mustang GT auto
Re: I wonder sometimes..... [Re: Chris142] #5433065 05/19/20 08:18 AM
SeaJay Offline
Not everyone is a fan, but annual state mandated safety inspections have their place.
Re: I wonder sometimes..... [Re: clinebarger] #5433101 05/19/20 08:48 AM
M
MarkM66 Offline
M
Did A/C relay fix the A/C?
Re: I wonder sometimes..... [Re: IMSA_Racing_Fan] #5433102 05/19/20 08:48 AM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
The longest lasting passenger car engines I'm familiar with (OM616/617 series Mercedes Diesels) require an adjustment every 15-20k miles.
The Honda requires it what? Once per timing belt swap at 100k?
Think something might have worn just slightly in 100k to justify checking it out and seeing if anything should be adjusted? Valves tighten as they wear. Self-adjusting hydraulic lifters do clog and stop working as well as they did originally.
Seems like sound practice regardless of manufacturer. I recall that our Toyota Previa (which was another super-long lasting and robust engine) had an optional valve adjustment as best practice once in a very long while.
Timing belts that routinely last past 100k arent a bad thing. Getting into the engine once every 100k isnt a bad thing. Looking at valves, which is super easy on a 4 cyl (which is most of what Honda makes) isnt a bad thing. And lest we go down the path of some superiority for chains, they do break, their tensioners and guides do fail, and a chain should be tested for wear in a process that aligns the cam and the crank, to look for number of degrees misalignment. That should be fixed by a new chain or at minimum, offset woodruff keys. The fact that nobody adheres to this as a general rule doesnt make them right.
Page 1 of 3 1 2 3
