Rockauto code expires 8/2
by gallydif - 06/02/20 08:19 AM
The worst job you ever had?
by Chris142 - 06/02/20 08:04 AM
P218F on my Ford PSD
by Donald - 06/02/20 06:34 AM
Kudos to Griot's
by Egg_Head - 06/02/20 05:43 AM
Exide Battery files for bankruptcy
by Randol - 06/02/20 04:34 AM
Just one more wax question.
by rrretiree7 - 06/02/20 01:49 AM
Removing stuck bolts- interesting technique
by rubberchicken - 06/02/20 12:47 AM
Unless it is a misprint?
by 340_Magnum - 06/01/20 10:25 PM
Raymond Weil 5590 Watch Battery Replacement
by maverickfhs - 06/01/20 09:22 PM
Echo SRM 230 idling high
by CDX825 - 06/01/20 08:40 PM
Walmart in Canada closing Lube and Tire Express
by Snagglefoot - 06/01/20 08:26 PM
2012 Sonic - LCA puck bushing
by Number_35 - 06/01/20 06:44 PM
Rotate mags?
by marine65 - 06/01/20 06:40 PM
Re-using good coolant?
by Jarpin - 06/01/20 06:21 PM
Best entry level riding mower
by UncleDave - 06/01/20 03:02 PM
2015 Pilot LX
by madRiver - 06/01/20 03:01 PM
NewMex, RandyN11049, bbrtuning, chapys, DaaBoss
71593 Registered Users
73 registered members (1978elcamino, alchargo, aquariuscsm, AndyB, akh, 53' Stude, 9 invisible), 1,938 guests, and 27 spiders.
Topics306,053
Posts5,286,477
Members71,593
ATF double benefit???? #5432847 05/18/20 09:27 PM
J
Jarpin Offline OP
J
I just changed my PS fluid feeder and return hose because of a slow leak. I vaguely remember my 17+ year MASTER Toyota mechanic once told me to just to dump Dexron/Mercon in the power steering resevoir instead of pouring fluid specifically labeled for power steering. What makes the ATF properties so similar to it? Is there a downside to this???
Thanks.
Re: ATF double benefit???? [Re: Jarpin] #5432858 05/18/20 09:36 PM
B
blufeb95 Offline
B
ATF and PS fluid are both basically hydraulic fluids, many manufacturers allow DEXIII fluid to be used as PS fluid.
Re: ATF double benefit???? [Re: Jarpin] #5432862 05/18/20 09:47 PM
B
bbhero Offline
B
It's likely that Dexron III is actually the "correct" power steering fluid for your Toyota...
My lady's 98 Camry is specd for Dexron III for the power steering fluid..
Nissan Altima 3.5 Coupe
Cam2 Full synthetic 5w30 Carquest Blue 84356
"Treat your family like your friends and treat your friends like your family."
Re: ATF double benefit???? [Re: Jarpin] #5432904 05/18/20 10:57 PM
MolaKule Offline
Global Moderator
Global Moderator
Most ATF's can be used in power Steering units except for the Honda PS fluids.
However, do not put specific fluids labeled as Power Steering fluids into an automatic transmission because of the different additive components.
"As engineers [and scientists] we are wired to solve problems and to create new things, to challenge the status quo and push the limits..." Ken Hurt, Embry-Riddle University, Class of '97.
Re: ATF double benefit???? [Re: Jarpin] #5433002 05/19/20 06:17 AM
J
Jimzz Offline
J
Use to be most steering fluids were just ATF without the color, friction modifiers, and maybe some other stuff. Basically a very basic and cheap hydraulic fluid.
I prefer ATF as its easier to find and seems to quite some steering systems better.
yup
Re: ATF double benefit???? [Re: Jarpin] #5433013 05/19/20 06:42 AM
B
BMWTurboDzl Offline
B
Thanks.
As long as the seals are compatible with ATF there's no problem. However, PS fluid is superior for cold weather performance (never an issue in Texas) and systems which spec PS fluid may have seal issues if ATF is used in its place. A lot of older German makes spec'd Pentosin PS fluid (ex, CH11s, CH7.1) for their steering and suspension systems.
435i
Re: ATF double benefit???? [Re: Jarpin] #5433108 05/19/20 08:56 AM
K
Kira Online Content
Online Content
K
SIMPLY HAVE TO ADD THIS
Someone opened the hood of my neighbor's 2010 Honda Accord 4 cyl. and BRIMMED the PS reservoir.
The steering was making noise when I got the car 5 days ago for a round of routine maintenance.
Completely TBSed (Turkey Baster Sucked) the reservoir and filled to split the MIN and MAX marks with new Honda fluid.
Back to normal.
Re: ATF double benefit???? [Re: Kira] #5433153 05/19/20 09:48 AM
J
Jarpin Offline OP
J
Totally man! I've done that before too. Turkey baster works! If you can find one at a medical supply store, you could also use a 60ml syringe to aspirate with a piece of windshield washer hose.
Thanks guys, I just ended up putting in some leftover Mercon V fluid to refill the reservoir. I'm hoping any remaining PS fluid blends properly with the new ATF. Seems to drive ok.
