Moving up to 5w30. How thick is too thick?
by BTLew81 - 06/03/20 11:15 PM
Renting UHaul Truck to Tow Your Own Trailer?
by Miller88 - 06/03/20 09:40 PM
First Oil Change Recommendation
by gtpimp - 06/03/20 09:20 PM
GM 10L80 Issues
by shimps1 - 06/03/20 08:26 PM
Brake/Carb cleaner issue.
by Jarpin - 06/03/20 07:27 PM
sharp oil pressure drop-off > 130C
by bbrtuning - 06/03/20 06:48 PM
Warranty work
by t1snwrbrdr12 - 06/03/20 06:10 PM
AC Flashing Light
by artbuc - 06/03/20 05:13 PM
Watches
by Passport1 - 06/03/20 03:57 PM
best budget tire
by VQLT - 06/03/20 03:33 PM
Castrol EDGE turns black/red FAST
by Silver - 06/03/20 03:20 PM
Our van feels "Darty" or twitchy" on the highway
by 1911CHAMPION - 06/03/20 02:55 PM
You guys who pile the miles up weekly on your ride
by Speak2Mountain - 06/03/20 02:22 PM
'19 + '20 Kicks w/C.V.T. : Any owners or know
by odie - 06/03/20 01:38 PM
Securing rubber hose to metal tubing?
by joshuawesl - 06/03/20 01:15 PM
Extremely rare Honda
by wings&wheels - 06/03/20 12:36 PM
Shuffle Dancing
by BlueOvalFitter - 06/03/20 12:19 PM
Do you practice a vegan-keto diet?
by Ed_Flecko - 06/03/20 12:08 PM
Digitizing Photos and Slides
by Snagglefoot - 06/03/20 12:04 PM
rorty, Ghosty, zmann96, yetti96, weekendwally
71602 Registered Users
55 registered members (Ag76, 10WSmuckers, bdcardinal, BlakeB, Aero540T, 3 invisible), 1,359 guests, and 30 spiders.
Topics306,113
Posts5,287,769
Members71,602
Any motorcycle seat upholstery gurus here? #5432411 05/18/20 01:39 PM
IMSA_Racing_Fan Offline OP
This Corbin seat is less than $90 shipped but has a couple of small tears and one big one along the seat edge. Is it possible to repair at home while remaining presentable? Any tricks of the trade appreciated.
Re: Any motorcycle seat upholstery gurus here? [Re: IMSA_Racing_Fan] #5432432 05/18/20 01:55 PM
Donald Offline
Its worn out. You will fix some and new ones will appear. Needs to be redone by a upholstery place.
2015 Ford F-250 w/Powerstroke
Re: Any motorcycle seat upholstery gurus here? [Re: IMSA_Racing_Fan] #5432443 05/18/20 02:07 PM
B
BigCahuna Offline
B
A place that does car upholstery should be able to replace the foam to your liking, and redo the leather. Cost ?.,,,
Re: Any motorcycle seat upholstery gurus here? [Re: IMSA_Racing_Fan] #5432445 05/18/20 02:08 PM
K
Kawiguy454 Offline
K
It has a Corbin sticker on it ...If you like the way it feels ship to them for a new cover or a rebuild. Any good upholstery place can replicate the cover by ripping the seams and using the pieces as templates for a new one. I would get the foam done while you're in there. A good seat foam should be 2 layers or more with higher densities on the bottom and softer on top. Good seats spread weight out over large area to avoid pressure points.
Re: Any motorcycle seat upholstery gurus here? [Re: IMSA_Racing_Fan] #5432596 05/18/20 04:57 PM
Thanks for the advice, I'm going to pass and have the OEM seat recovered. I wish I still lived in San Diego, a shop in Tijuana redid the seat on my 750F while I drank Coronas in a bar down the street. Cost $50 and was great.
Re: Any motorcycle seat upholstery gurus here? [Re: IMSA_Racing_Fan] #5432783 05/18/20 07:59 PM
BusyLittleShop Offline
Manufactures must think that a riders butt is made out of titanium the way some stock saddles are
equipped... well if we can send astronauts to the moon why can't we ride in comfort??? you can
thanks to NASA's Temper Foam...
"Temper FoamĀ® is a temperature sensitive foam which gets softer and more malleable when warmed
and firmer when cooled. Similar to a liquid gel, becoming firmer upon impact, yet feeling soft and fluid
to the touch. It is a visco- elastic material ideal for orthopaedic and prosthetic applications. With its
firm elastic flow and non-stick properties it eliminates soreness and pain caused by long periods of
pressure."
Mr.RC45's shinny black board called a race saddle...
[Linked Image from vfrdiscussion.com]
I laid the stock seat pan over a 3 inch block of T47 extra firm...
I cut the basis shape using a electric carving knife...
I glued the foam to the plastic pan with 3M Weather Strip or Gorilla
Snot if you will... next I shaped the foam with a air driven sander...
Behold... I went from a 30 minute seat to a 12 hour seat... old guys
know comfort and know how to get it too...
Larry L
Have a Wheelie NICE day
94 RC45 #2 58,000 on 30 Grade, Currently Mobil 1 5W30 SN
2002 Camaro Mobil 1 5W30
1952 De Havilland Chipmunk
Re: Any motorcycle seat upholstery gurus here? [Re: BusyLittleShop] #5432837 05/18/20 09:09 PM
Awesome tip!
In all fairness to the RC45 that is a road racing bike with a license plate.
Re: Any motorcycle seat upholstery gurus here? [Re: BusyLittleShop] #5432839 05/18/20 09:10 PM
Then use a hair dryer to stretch vinyl over it and staple? More pics if you have please.
Re: Any motorcycle seat upholstery gurus here? [Re: IMSA_Racing_Fan] #5432929 05/19/20 12:11 AM
Originally Posted by IMSA_Racing_Fan
Awesome tip!
True... engineer by HRC to go around a corner faster than you ever dared in your life and my wallet is full of appearance notices to prove it also it keeps good company...
[Linked Image from farm3.staticflickr.com]
Larry L
Re: Any motorcycle seat upholstery gurus here? [Re: BusyLittleShop] #5432932 05/19/20 12:18 AM
I test road one while working as a service tech for Joe Harrison Honda (now Powersports) after changing brake pads and other service, oil change, chain adjustment, maybe it was long ago. Easiest bike to ride fast I've ever experienced. Also those brakes, I was heat cycling them on an access road and gave the lever a hard squeeze at a stoplight. Locked it up with a howl in front of a gas station. Scared the #### out of me.
Re: Any motorcycle seat upholstery gurus here? [Re: IMSA_Racing_Fan] #5432969 05/19/20 03:26 AM
W
wagsrk08 Offline
W
2020 Subaru Forester Premium 2.5L AWD CVT
2012 Toyota Tacoma 2.7L 5-Speed Manual 4WD
2016 Harley-Davidson FLHTK Ultra LImited
Re: Any motorcycle seat upholstery gurus here? [Re: IMSA_Racing_Fan] #5433309 05/19/20 12:51 PM
02SE Offline
I've re-covered one motorcycle seat. I watched some videos on youtube to get some idea of what techniques could be used, ordered the material off Amazon, and then did it. It turned out just fine.
Re: Any motorcycle seat upholstery gurus here? [Re: IMSA_Racing_Fan] #5433812 05/20/20 01:30 AM
P
Panzerman Offline
P
I ve recovered many atv and dirt bike seats. You can buy the fabric and do it yourself. The precut seat covers on eBay are really easy to install. Lay then in the sun so they get hot and stretch them tight. It's not as bad as you think. Like I said I ve done lots now and they come out pretty nice.
I had to buy a new seat for my Canam Spyder. The stocj seat was awful. Makes me mad that a motorcycle seat costs as much as a couch.
2006 Dodge Ram 2500 Hemi 4x4
2016 Dodge Challenger Scat Pack
Re: Any motorcycle seat upholstery gurus here? [Re: IMSA_Racing_Fan] #5434116 05/20/20 12:25 PM
R
ragtoplvr Offline
R
Cough, cough,Bicycle seat. You will never complain about a motorcycle seat again
