Fleet Farm Rotella T6 Sale + Shell Rebate
by shibby6600 - 05/29/20 01:26 PM
QS Ultimate Durability 5W-30
by js1956 - 05/29/20 12:51 PM
KPVD Eerily Deserted
by wings&wheels - 05/29/20 12:24 PM
BMW N55 Recommendations
by BSchmidt25 - 05/29/20 10:21 AM
Castrol / Mobil 1 blend?
by mbres2000 - 05/29/20 09:40 AM
My Henry 22 Magnum Rifle (pics)
by tig1 - 05/29/20 09:04 AM
overfilled my crankcase by 3/10 of a liter - problem?
by tom in boise - 05/29/20 08:49 AM
Espresso
by buster - 05/29/20 08:34 AM
I didn't believe there were fake spark plugs.
by JustinH - 05/29/20 08:14 AM
New Tire Selection
by artbuc - 05/29/20 07:44 AM
Well question
by supton - 05/29/20 07:11 AM
Cable Modem Thoughts/Recommendat
ions?
by alarmguy - 05/29/20 07:10 AM
Tire choice 2016 Lexus es 350
by Toros - 05/29/20 06:20 AM
Infineum trends: Passenger vehicles (2019)
by Gokhan - 05/29/20 05:11 AM
Another story from the service bay
by clinebarger - 05/29/20 12:11 AM
KIA TYPE 4 (M) ATF
by flinter - 05/28/20 08:49 PM
My new Henry 22 Magnum rifle
by tig1 - 05/28/20 08:45 PM
Mobil 1 M-102 for 3 6000km oil changes?
by pktrkt - 05/28/20 08:33 PM
1/2 75W-90 1/2 75W-110 Can you mix equal parts
by jrommelt - 05/28/20 08:22 PM
Kboggs, oldcodger, cwllams1, Danwrig, DanielR
71558 Registered Users
103 registered members (2015_PSD, 55hambone, ABN_CBT_ENGR, 555, 2004tdigls, 1978elcamino, 8 invisible), 2,465 guests, and 29 spiders.
Topics306,014
Posts5,284,837
Members71,558
Question about temperature #5432389 05/18/20 01:11 PM
Sportage333444 Offline OP
Up to what ambient temperature AMSOIL 10w30 oil will be okay with a Honda engine. I am asking because the service book cannot read the temperature correctly. Will the temperature of 30 degrees Celsius be still good for this viscosity or will the 10w40 viscosity be better?
Thank you for the information.
Re: Question about temperature [Re: Sportage333444] #5432424 05/18/20 01:48 PM
sloinker Offline
That is only 86F. Is that the real temperature you are worried about? What engine? What viscosity does the manufacturer advise?
'16 Tiguan TSI Vaico 5W40
'15 VW Golf TDI Red Line 5W30 Euro
'15 VW Golf Sportwagen TDI M1 ESP 5W30
'14 Dodge Grand Caravan 3.6 Valvoline 5W20 Semi Synthetic
'64 Plymouth Fury440 Pending
Re: Question about temperature [Re: Sportage333444] #5432442 05/18/20 02:07 PM
This is Honda Goldwing Valkyrie 2014. The manufacturer recommends a 10w30 viscosity and 10w40 higher temperatures. Only the chart is illegible to me.
Re: Question about temperature [Re: Sportage333444] #5432462 05/18/20 02:25 PM
blupupher Offline
It is a water cooled bike, synthetic 10w-30 is fine as long as the cooling system is working.
Only time it may even be an issue is if you are sitting in bumper to bumper traffic for an hour in 100°F.
Your body would have issues before the oil would.
'18 Santa Fe: PP 10W-30/OEM
'18 Soul: Synpower 5W-30/ProGuard
'12 xB: M1 EP 0W-20/CQ Blue
'10 Santa Fe: Synpower 5W-30/D+
'04 F150: Magnatec 10W-30/ST
'02 F150: PP 0W-20/M1
'94 VT1100: Peak 15W-40/Wix
Re: Question about temperature [Re: Sportage333444] #5432489 05/18/20 02:52 PM
G
Gebo Offline
G
I had 2 GW's. Not as new as yours. I always ran 10w-40 but that is only worth 2 cents. High summer temp usually in the 90's.
'98 LEX LS400 310K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 75K
Shell Gas and Truck 5w-30
Amsoil OE 10w-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: Question about temperature [Re: Sportage333444] #5432590 05/18/20 04:55 PM
Z
ZeeOSix Offline
Z
Upload a snap shot or photo of the chart.
Re: Question about temperature [Re: Sportage333444] #5432598 05/18/20 05:00 PM
[Linked Image]
Re: Question about temperature [Re: Sportage333444] #5432626 05/18/20 05:29 PM
B
bulwnkl Offline
B
That must’ve come from the Honda Service Manual. It says you can use either 10w30 or 10w40 at any (all) temp.
I use speech recognition frequently. Please excuse any consequent grammatical or typographical errors.
Re: Question about temperature [Re: Sportage333444] #5432727 05/18/20 07:06 PM
BusyLittleShop Online Content
Online Content
If there is one thing a rider has control of its the viscosity of
their oil... chemically speaking either the 30 or 40 will meet and
exceed your mileage expectations... BUT according to Honda it is best
to use the freer flowing 30 over the slower flowing 40... engineer
tested the freer flowing 30 lubricates and cools critical engine
components better than slower flowing 40 oils can. Freer flowing oils
reduce bearing temperatures and sump temperatures compared to slower
flowing 40. Freer flowing 30 can also help increase horsepower and
miles per gallon.
I run a 30 grade all year because it gives the right flow at the
normal engine operating temperature of 212ºF and that would be the
viscosity of 10 at operating temps... so that means for every 1000
rpms increase of oil pressure increases another 10 psi... a 30 grade
flows more oil at higher rpms which flows more oil between the
critical bearings which carries away more heat and I'm not wasting HP
just pumping oil through the blow off valve... 40 grade builds pressure
at the expense of flow and I wastes HP by blowing oil through the
pressure relief valve...
30w psi
1000 10
2000 20
3000 30
4000 40
5000 50
6000 60
7000 70
8000 80
9000 90
10000 99
11000 99 blow off by the pressure relief valve
40w psi
1000 12
2000 24
3000 36
4000 48
5000 72
6000 84
7000 96
8000 99 blow off by the pressure relief valve
9000 99
10000 99
11000 99
RC45 coolant 203F oil 10 psi
[Linked Image from i.imgur.com]
Larry L
Have a Wheelie NICE day
94 RC45 #2 58,000 on 30 Grade, Currently Mobil 1 5W30 SN
2002 Camaro Mobil 1 5W30
1952 De Havilland Chipmunk
Re: Question about temperature [Re: Sportage333444] #5432775 05/18/20 07:51 PM
B
Bonz Offline
B
Quote:. "BUT according to Honda it is best
to use the freer flowing 30 over the slower flowing 40...".
Is this from a conversation with a Honda engineer for your bike or with a Honda engineer for the Valkyrie in question?
With respect I disagree with your analysis of the situation.
I think the graph speaks for itself with a bit of common sense applied...
The chart shows 10w30 as being a preferred oil at the lower temperatures but still fine for higher temperatures. By the same token, the chart also shows 10w40 as being more preferred for higher temperatures however because it's the same weight on the bottom it is no different than 10w30 in that regard.
Honda is saying use either one but it is false to read that they prefer 10w30 simply because it is on the left and the 10w40 is on the right side of the spectrum, which is the only way to come about that statement as I see it.
If this came about from a conversation with a Honda engineer, then that would be a different subject, however I don't believe anyone here has talked to a Honda engineer about Honda's oil recommendation for this bike.
To the OP: You have started a number of threads about this bike and the oil choice. Be assured you are safe with either one.
Re: Question about temperature [Re: Sportage333444] #5432985 05/19/20 05:15 AM
P
Panos Offline
P
My 2011-2013 Honda CBR 600F specifies 10w30 Jaso MA oil only. No other choices given no temperature charts, nothing.
Ford Fiesta 1.6 '05 - Motul specific 913D/Motul Gear 300 180K+ Kms
Kawasaki Ninja 250R '08 - Shell Advance Ultra 4T 10w40 75K+ Kms
Honda CBR600F pc41 '14 - Motul 7100 10w30 25K+ Kms
Re: Question about temperature [Re: Sportage333444] #5433662 05/19/20 08:11 PM
Online Content
Flow is in... manufactures are trending towards recommending a single
viscosity of a free flowing 30 weigh for all their bikes... there will
come a day when they will not even mention the option of a 40...
Any one of 30 grade 100% synthetic motorcycle specific or not oils will meet
and exceed your mileage expectations...
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
My current favorite...
[Linked Image]
Larry L
Re: Question about temperature [Re: Sportage333444] #5433781 05/19/20 11:46 PM
Z
ZeeOSix Offline
Z
[Linked Image]
Where are you located ... and how cold would it ever be when you take a ride? If you're not riding in super cold climate, I'd be choosing the 10W-40.
Re: Question about temperature [Re: Sportage333444] #5433799 05/20/20 12:26 AM
I usually drive to an ambient temperature of 85-90 F.
Re: Question about temperature [Re: Sportage333444] #5433938 05/20/20 07:54 AM
A
alarmguy Offline
A
Without question then, choose the 10/40.
There really isnt anything to think about. Forget out the thread, Honda is telling you what you can run.
14 Road King (current)
08 VStar 1300 Tourer
07 Suzuki C50
