Motorcycle rear shock rebuild
by Reddy45 - 06/02/20 12:45 PM
2016 Lexus RX350 Oil Change change
by Toros - 06/02/20 12:43 PM
Tire Mobility Kits
by wings&wheels - 06/02/20 12:06 PM
Worst accident you've witnessed
by Dave Sherman - 06/02/20 12:04 PM
Shock Fluid
by splinter - 06/02/20 11:21 AM
Michelin X-Ice 4 North for Canada ...
by odie - 06/02/20 11:03 AM
Rockauto code expires 8/2
by gallydif - 06/02/20 08:19 AM
The worst job you ever had?
by Chris142 - 06/02/20 08:04 AM
P218F on my Ford PSD
by Donald - 06/02/20 06:34 AM
Kudos to Griot's
by Egg_Head - 06/02/20 05:43 AM
Exide Battery files for bankruptcy
by Randol - 06/02/20 04:34 AM
Just one more wax question.
by rrretiree7 - 06/02/20 01:49 AM
Removing stuck bolts- interesting technique
by rubberchicken - 06/02/20 12:47 AM
Unless it is a misprint?
by 340_Magnum - 06/01/20 10:25 PM
Raymond Weil 5590 Watch Battery Replacement
by maverickfhs - 06/01/20 09:22 PM
Echo SRM 230 idling high
by CDX825 - 06/01/20 08:40 PM
Walmart in Canada closing Lube and Tire Express
by Snagglefoot - 06/01/20 08:26 PM
NewMex, RandyN11049, bbrtuning, chapys, DaaBoss
71593 Registered Users
85 registered members (2015_PSD, 4WD, 390pi, 2010Civic, 69Torino, 9 invisible), 2,382 guests, and 62 spiders.
Topics306,059
Posts5,286,616
Members71,593
Ford Ranger - Throttle Cable #5432290 05/18/20 11:42 AM
M
MasterSolenoid Offline OP
M
Recently I noticed my Throttle Cable was frayed and ordered an OEM replacement from local Ford Dealer.
Original Pt. No. is unknown and (I believe) no longer available.
Replacement from Dealer is 4L5Z-9A758-AA (and reconfirmed after purchase using VIN #)
Concern #1 - Cable is 12 inch longer than original. Dealer said "THAT is the replacement"
OK, I could make that work just by anchoring it down.
Concern #2 - The replacement has a Coil Spring that goes up against Gas Pedal / lacking on 'original'
Question - Anybody know what this Spring does ?
I would hate to be a 'hack' and cut it off, but that's an option (after confirming it's useless).
The Throttle Body itself has two Springs on that end of Cable.
I have NO Cruise Control
I have found some OEM Sellers that say "this is the correct part No." and others that say "it WILL NOT fit".
[Linked Image]
Fits - Same Part No. as Dealer
[Linked Image]
Doesn't Fit - Same Part No. as Dealer …. Oh, the confusion
[Linked Image]
Any suggestions would be appreciated.
Thank you.
2002 Ford Ranger / bought new
2 Wheel Drive
3.0 Liter Engine
Four basic premises of writing:
Clarity, Brevity, Simplicity, and Humanity.
Re: Ford Ranger - Throttle Cable [Re: MasterSolenoid] #5432323 05/18/20 12:19 PM
J
joegreen Offline
J
I own a 98 Ford ranger and I have that spring on my throttle cable. It's there so when the throttle body is 100% open but the gas pedal has not bottomed out on the floor yet the spring acts as a buffer so you are not putting your whole leg force on the throttle cable when it's at max throttle.
1978 Chevrolet k20
Engine: Delo 10w30xle
Transmission: Castrol transmax dex/merc
1984 Mercedes-Benz 300 turbo diesel
Engine: Delo 400 15w40le
Re: Ford Ranger - Throttle Cable [Re: MasterSolenoid] #5432340 05/18/20 12:34 PM
N
nobb Offline
N
I've had to replace that throttle cable before because the way it's mounted on the 3.0 makes it easy to break if you're leaning over working on the engine. I don't think the total overall length matters, as long as the length of the exposed ends match. I definitely don't remember the spring part being on my original part. The junkyard replacement part I got also didn't have that spring.
Re: Ford Ranger - Throttle Cable [Re: joegreen] #5432377 05/18/20 01:05 PM
M
M
That would make sense and could be the new & improved Cable for my truck.
But only if the Gas Peddle was on the 'left' side of the Spring (in photo) / then the Spring would compress as the Gas-Pedal goes to the floor (preventing the Cable from stretching).
I believe that's the answer (and reasoning) I was looking for.
Thank you.
Another way of looking at it:
The Spring replaces Cable-Ties people are adding (you-tube mods) to take up slop when the Cable stretches.
2 Wheel Drive
3.0 Liter Engine
Re: Ford Ranger - Throttle Cable [Re: MasterSolenoid] #5432613 05/18/20 05:17 PM
bdcardinal Offline
From Ford's part info remarks screen
HAS PROTECTIVE SLEEVE FOR CONTACT WITH BRAKE BOOSTER
2 STUD THREADS. EH
3 3.0L,2L5Z-AA R/B 4L5Z-AA,SAME AS 2L5Z-CA W/PROTECTIVE COVER
4 111113 **********
5 111113 2L5Z-AA(16")R/B 2L5Z-CA(29")R/B 4L5Z-AA(29")(WPTSE11399835)
6 111113 (16"TO 29")REDUCE CONTACT W/BOOSTER&HOSE;(WPTSE11545833000)
7 82015 REFER TO WORKSHOP MANUAL,MY2004 RANGER,FOR CABLE ROUTING.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: Ford Ranger - Throttle Cable [Re: MasterSolenoid] #5433375 05/19/20 02:02 PM
M
M
OP here,
I installed the new (longer) Throttle Cable and all is well.
There is a slight amount of slack in the Cable.
- The connecting ends were a perfect match
- I can see that the Coil Spring in question is to prevent the Cable from stretching (while gunning it) but I drive more like an old man anyway.
2 Wheel Drive
3.0 Liter Engine
