Rockauto code expires 8/2
by gallydif - 06/02/20 08:19 AM
The worst job you ever had?
by Chris142 - 06/02/20 08:04 AM
P218F on my Ford PSD
by Donald - 06/02/20 06:34 AM
Kudos to Griot's
by Egg_Head - 06/02/20 05:43 AM
Exide Battery files for bankruptcy
by Randol - 06/02/20 04:34 AM
Just one more wax question.
by rrretiree7 - 06/02/20 01:49 AM
Removing stuck bolts- interesting technique
by rubberchicken - 06/02/20 12:47 AM
Unless it is a misprint?
by 340_Magnum - 06/01/20 10:25 PM
Raymond Weil 5590 Watch Battery Replacement
by maverickfhs - 06/01/20 09:22 PM
Echo SRM 230 idling high
by CDX825 - 06/01/20 08:40 PM
Walmart in Canada closing Lube and Tire Express
by Snagglefoot - 06/01/20 08:26 PM
2012 Sonic - LCA puck bushing
by Number_35 - 06/01/20 06:44 PM
Rotate mags?
by marine65 - 06/01/20 06:40 PM
Re-using good coolant?
by Jarpin - 06/01/20 06:21 PM
Best entry level riding mower
by UncleDave - 06/01/20 03:02 PM
2015 Pilot LX
by madRiver - 06/01/20 03:01 PM
NewMex, RandyN11049, bbrtuning, chapys, DaaBoss
71593 Registered Users
80 registered members (97prizm, 830Lee, ABN_CBT_ENGR, 4WD, 55hambone, 555, 6 invisible), 2,077 guests, and 34 spiders.
Topics306,053
Posts5,286,514
Members71,593
C3 and A5/B5 compatibility with older cars #5432232 05/18/20 10:15 AM
M
M119 Offline OP
M
I must say i have a hard time understanding these ACEA ratings. For a lot of cars i prefer to use a 5W-30 however is has become impossible to source an A3/B4 oil locally or even for a good price on the internet.
What kind of 5W-30 should be used in olders cars ? I am talking 90s/early 00s regular gas engines calling for something like API SG/SH/SL or ACEA A3/B3. Let's take my own car, the C180 as an exemple but this includes various Renaults, PSAs as well as some japanese and american cars.
I will take these two oils as an exemple as they are some of the most popular. What should be used and why ?
Total Quartz INEO Long Life 5W-30
Total Quartz 9000 Future NFC 5W-30
1998 Mercedes W202 C180 - 155K kms (Daily)
1995 Mercedes S124 E250 Diesel - 480K kms
1994 Pontiac Trans Sport V6 3.8 - 280K miles
Re: C3 and A5/B5 compatibility with older cars [Re: M119] #5432482 05/18/20 02:46 PM
J
Jetronic Offline
J
Get Total quartz 9000 energy. All 3 can run on that without issue and it's not expensive.
AR Giulietta 2.0 JTDM-2 -- Total Quartz 9000 Energy 0w30
Hankook Ventus V12 evo2 235/45R17
Re: C3 and A5/B5 compatibility with older cars [Re: Jetronic] #5432511 05/18/20 03:34 PM
M
M119 Offline OP
M
Which oil in particular are you talking about ? I did not find it in 5W-30, i know it exists in 0W-30 but way to expensive.
Re: C3 and A5/B5 compatibility with older cars [Re: M119] #5432527 05/18/20 03:50 PM
K
Kamele0N Offline
K
I rember you and your dilema a year ago.....
Since you are from France.....Leclerk has nice oil stash..for cheap ( Its most probably repacked Shell...)
ex Extralube.....a.k.a Tech9 nowadays
5w30 C3 504/507 (see my sig)
or 5w40 (or even in 10w40)
https://www.e-leclerc.com/catalogue/marques-distributeurs/tech9/auto/entretien-auto/huile-moteur/huile-moteur-5w40-diesel-2l-tech9--,41009
https://www.e-leclerc.com/catalogue/marques-distributeurs/tech9/auto/entretien-auto/huile-moteur/huile-moteur-5w30-filtre-a-particules-c3-2l-tech9-,41013
I (personally) would not use oils with HTHS lower than 3.5 in "old" cars.....ie Acea A5/B5 A1/B1...C2...C1 no-no
2008 Toyota Yaris 1ND-TV 1.4 D4-D Tech9 (Shell?) 5W30 C3 VW 504/507
1997 Toyota Landcruiser KZJ95 3.0 TD Shell Rimula R6M 10W-40
Re: C3 and A5/B5 compatibility with older cars [Re: M119] #5432548 05/18/20 04:12 PM
M
M119 Offline OP
M
Thank you ! Tech9 is usually what i buy when i need a 5W-40, it is Avia oil. So C3 is the closest to A3/B3/B4 ?
Re: C3 and A5/B5 compatibility with older cars [Re: M119] #5432555 05/18/20 04:19 PM
K
Kamele0N Offline
K
https://www.oilspecifications.org/acea.php
Look on C3 as on a DPF/GPF oriented version of A3/B4....
Avia? didnt know that.....saw Avia petrol stations when I was driving trough F and D.....dont have them here smile
