Inside of new windshield fogs up
by mclasser - 06/06/20 02:51 PM
Oil considerations Duratec 3.0 V6, 85k miles
by 97tbird - 06/06/20 02:22 PM
Best way to charge and maintain a battery?
by Avery4 - 06/06/20 02:10 PM
HM oils vs HM oils
by aquariuscsm - 06/06/20 12:37 PM
Confusion: oil grades, yellow metal, vintage
by LouK2 - 06/06/20 12:21 PM
New Rad needed Nissens vs APDI
by Bluestream - 06/06/20 11:58 AM
Oil filter cap wrench suggestions.
by RichR - 06/06/20 11:55 AM
AC Woes
by artbuc - 06/06/20 11:44 AM
Part source Canada TOTAL QUARTZ 9000 50% no tax
by Bluestream - 06/06/20 11:18 AM
Pressure washer foam gun
by Donald - 06/06/20 10:50 AM
Pentastar oil changes
by 4WD - 06/06/20 10:25 AM
Oil Pan Plug Problem
by 2015_PSD - 06/06/20 10:14 AM
Continentals out of balance
by wolf_06 - 06/06/20 10:04 AM
2017 Toyota Sienna AWD
by 92saturnsl2 - 06/06/20 09:33 AM
Wix 57045
by electricmarquis - 06/06/20 08:42 AM
VW GTI
by greenjp - 06/06/20 08:25 AM
Mower Engine Got Drenched With Oil
by viscous - 06/06/20 08:19 AM
Mobil 1 versus Motul for a 2020 Camry 0w16
by Amkeer - 06/06/20 05:52 AM
Slowest lap ever...but legal...
by Shannow - 06/06/20 05:15 AM
viscous, Roamingtxn, 3Dperf, LouK2, Michael328i
71618 Registered Users
72 registered members (4WD, 762fermeandyou, 86cutlass307, 55hambone, Astro14, aquariuscsm, 1 invisible), 2,032 guests, and 34 spiders.
Topics306,299
Posts5,289,806
Members71,618
15 Forester - Symptom of rear spring going out? #5432035 05/18/20 05:49 AM
M
MoneyJohn Offline OP
M
My wife is the primary driver of this vehicle. She was complaining about tire air pressure being low. So I thought of filling the air up. When I went to the car, I noticed that the rear wheel well is much smaller and the car looks like suspensions are shot, just from the outside. Usually, the space between the tire and the well wall is about 5 inches. This is little over an inch.
We have received the rear spring recall letter but I have not scheduled appt. Thought I will just let this COVID thing settle down, esp when we are in a hotspot.
I just want to confirm that this is the symptom of rear springs going out. If it is safe to drive to the dealership, about 3 miles from my place?
[Linked Image from i.postimg.cc]
Thanks in advance
Re: 15 Forester - Symptom of rear spring going out? [Re: MoneyJohn] #5432069 05/18/20 06:45 AM
Z
Zaedock Offline
Z
Internet troubleshooting yields nothing but guesses. A broken piece of spring could be touching the inside of the tire. Is it safe for 3 miles? No one here can really tell.
I would jack up the that side and take a look with a flashlight. Its the only way to be sure.
2019 Escape EB AWD/2016 KIA Optima SXL 2.0L Turbo/2012 F150 Ex-cab 5.0L
1992 YJ "The Heep"/2015 Chrysler 200 Limited
1975 Ford Bronco/1959 Willys CJ5/Tube Rock crawler
Re: 15 Forester - Symptom of rear spring going out? [Re: MoneyJohn] #5432084 05/18/20 07:00 AM
M
Miller88 Offline
M
There is a recall on those for broken springs.
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: 15 Forester - Symptom of rear spring going out? [Re: MoneyJohn] #5432113 05/18/20 07:32 AM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
Be careful. I had a broken spring on my Saab it broke in my driveway. Couldn’t really move it. When we got it out, the tire was ruined as the spring had stabbed it..
Given that you have multiple hints that something is wrong, I wouldn’t push your luck. Good news is it’s on the rear, so if something bad happened, it might not be as dire as the front... but get it fixed immediately. I would consider smooth surface streets around town if she has been driving it recently, but nothing more than to the dealer.
Re: 15 Forester - Symptom of rear spring going out? [Re: JHZR2] #5432146 05/18/20 08:10 AM
M
M
This is exactly what I am worried about. What if the spring is on its last leg and a minor bump and BAM, the car literally sits down and doesn't move it even breaks the strut. (Is this possible?) I have scheduled the appt now in 12 days (nothing available immediately and I do not want to go to the town away dealership for the above reason). Until this is fixed, Forester will be parked and she will use the other car.
My question is if this is a hint to something else too? Should I get it checked by our mechanic before heading to the dealership to avoid surprises? I don't think I am qualified enough to figure out if something is not right.
Re: 15 Forester - Symptom of rear spring going out? [Re: MoneyJohn] #5432163 05/18/20 08:28 AM
A
ARCOgraphite Offline
A
If its broken have it towed. If not just drive carefelly since its only 3 miles.
You not moving the space shuttle to the launch pad here smile
If it's sitting that low on ONE side it' s likely already broken.
heres a bad one:
[Linked Image]
My VW had a rear coil spring recall too.
The Replacements were WORSE then the original - too soft and car sits low in the rear with a load
(me).
2019 VW Jetta S 6MT OCI#2 7378mi-MOTUL Specific VW508.00+VW Service Filter; '17 Subaru Crosstrek CVT OC#9 70254mi-Rotella
Gas Truck 5W20 + Fram Ultra 7317 Filter
Re: 15 Forester - Symptom of rear spring going out? [Re: MoneyJohn] #5432200 05/18/20 09:39 AM
The Critic Offline
There is a recall on 13-18 Foresters for rear coil springs and I think it was specifically intended to address situations such as this one.
2011 Toyota Prius 1.8L - 207K - Valvoline Premium Blue Restore 10W-30
2007 Honda Accord 2.4L - 146K - Valvoline Premium Blue Restore 10W-30
Re: 15 Forester - Symptom of rear spring going out? [Re: MoneyJohn] #5432208 05/18/20 09:46 AM
A
A
In the picture above about the tech mentioned that the pigtail on the bottom of the spring broke and then the spring dropped off the lower perch. Its NOT supposed to be sitting on the lower wishbone.
This should be double wishbone rear suspension design, so that is not a "strut" in the classic definition - just a coil -over shock. as it perform no location (camber and caster positioning ) of the rear knuckle and hub assembly.
Re: 15 Forester - Symptom of rear spring going out? [Re: ARCOgraphite] #5432230 05/18/20 10:14 AM
M
M
heres a bad one:
(me).
Thank you for the image.
Can you clarify where is it 'broken'? I see it is not centered and scraping the rubber.
I just tried to check but this is on the passenger rear. The area is not clearly visible due to the exhaust muffler. I will try to jack up later and try to see it. Hopefully, I will be able to take a picture and post it here.
And yes, it is low on one side only.
Re: 15 Forester - Symptom of rear spring going out? [Re: MoneyJohn] #5432277 05/18/20 11:16 AM
CT8 Offline
Bring the car to a shop.
2015 F150 2.7
2018 F350 6.2
Re: 15 Forester - Symptom of rear spring going out? [Re: MoneyJohn] #5432278 05/18/20 11:16 AM
slacktide_bitog Offline
Since you know there is a recall on it, schedule the appt. Dealer service departments are still open smile
Three miles shouldn't be a problem
Re: 15 Forester - Symptom of rear spring going out? [Re: MoneyJohn] #5432347 05/18/20 12:41 PM
Dave9 Offline
The perch is that horizontal disc about 3" below the rubber/plastic boot in the pic. The bottom of the spring is supposed to be sitting on it, not wrapping around and continuing below it. Compare to your other rear side.
[Linked Image]
Re: 15 Forester - Symptom of rear spring going out? [Re: CT8] #5432353 05/18/20 12:44 PM
M
madRiver Offline
M
More like have the car taken to a shop. Eg tow truck.
Re: 15 Forester - Symptom of rear spring going out? [Re: Dave9] #5432440 05/18/20 02:04 PM
M
M
Thank you.
The other side is perfect, the lower side I will check when I jack the car. Thanks again.
Re: 15 Forester - Symptom of rear spring going out? [Re: madRiver] #5433109 05/19/20 08:59 AM
A
A
It's only 3 miles. It should be OK.
Depending. smile
On second thought, have it towed smile
