Blackstone Lab Question
by klt1986 - 05/31/20 08:19 PM
Fram oil filters at Advance Auto
by Electromotive - 05/31/20 08:02 PM
The Last Coat 2?
by tbm5690 - 05/31/20 07:33 PM
Can a car have too much battery?
by wings&wheels - 05/31/20 07:13 PM
Oil Extractor Pump Problem
by tc1446 - 05/31/20 07:11 PM
Tacoma fuel filter cut open
by funflyer - 05/31/20 06:53 PM
Electronic Octane Testers on eBay
by smonska - 05/31/20 05:35 PM
0W-8 is here: JASO GLV-1
by Gokhan - 05/31/20 05:26 PM
2010 Corolla What oil ??
by GMguy84 - 05/31/20 05:19 PM
Knock While Cruising, None While In Boost
by gathermewool - 05/31/20 04:11 PM
Replaced Golf Sportwagen with an Alltrack
by dareo - 05/31/20 03:27 PM
TW Ceramic Spray First Time
by Toros - 05/31/20 02:49 PM
The perfect tractor oil
by Chris142 - 05/31/20 02:42 PM
5.7 HEMI Lifter/cam failure cause
by Skippy722 - 05/31/20 02:38 PM
Battery 2013 4Runner 4WD
by Gebo - 05/31/20 02:29 PM
Supermarket Heroes 500 at Bristol
by bdcardinal - 05/31/20 01:55 PM
More M1 changes
by Flashlightboy - 05/31/20 01:49 PM
Car Reviewers
by borgward - 05/31/20 01:43 PM
Final charge global extender
by mker - 05/31/20 01:15 PM
Haywood, ToOliwer, AbbeyRoad, RPF, Rayi
71586 Registered Users
101 registered members (azjake, 55hambone, andyd, ammolab, Alain2, 8 invisible), 2,230 guests, and 35 spiders.
Topics306,108
Posts5,286,548
Members71,586
11 Traverse Water pump #5431945 05/17/20 10:52 PM
B
Blang Offline OP
B
I get coolant leaks from below where the water pump is after short trips (~1 mile one way). When it's driven on extended trips it's dry as a bone. No leaking whatsoever even after it's sat for a few days. It went two months without leaking and then leaked again when a couple short trips happened again. Replace the water pump?
03 Cavalier 243k M1HM 5w30
01 K1500 4.8 190k M1HM 5w30
11 Traverse 106k M1 5w30
Acdelco filters
Re: 11 Traverse Water pump [Re: Blang] #5431964 05/17/20 11:30 PM
dishdude Online Content
Online Content
Replace ASAP. It could fail catastrophically and it will happen at the most inconvenient time.
2018 Challenger SRT 392 PUP 0w-40 Wix 57899XP
2018 GTI M1 Euro 0w-40 Wix WL10024
2019 Tiguan Castrol Edge Pro 0w-20
Re: 11 Traverse Water pump [Re: Blang] #5431967 05/17/20 11:40 PM
slacktide_bitog Offline
Yes, replace it!
Water pumps are one of the few things that actually give you a warning before they fail, so take advantage of that smile
Rock Auto carries the actual OE water pump for your Traverse
Re: 11 Traverse Water pump [Re: Blang] #5432068 05/18/20 06:38 AM
J
Jimzz Online Happy
Online Happy
J
Probably a seal starting to go out. When warm expands just enough but those short cooler trips allow it to leak out a little and not dry from short trip.
Not to hard. Hardest part is getting the pulley off/on. Pump only has 6 bolts holding it on
yup
Re: 11 Traverse Water pump [Re: Blang] #5432096 05/18/20 07:09 AM
Donald Offline
Well its not going to fix itself. So it needs to be replaced assuming its coming from where you think it is.
2015 Ford F-250 w/Powerstroke
Re: 11 Traverse Water pump [Re: Blang] #5432124 05/18/20 07:47 AM
L
ls973800 Offline
L
Water pumps were a weak point on the earlier Traverse, Enclave, and Acadia models (Saturn Outlook also) My new at the time 2010 went bad after only 2 years. GM extended the warranty on them for 10 years/120000 miles BUT I think only through the 2010 model year. Check with a dealer to find out for sure and read Post#2 of this link for more information.
GM Extended Water Pump Warranty
You can change it going through the wheel well if I recall. Just check some of the Traverse/Enclave/Acadia forums for more information.
2019 Honda Pilot Touring AWD
Re: 11 Traverse Water pump [Re: Blang] #5432202 05/18/20 09:40 AM
B
Blang Offline OP
B
Thanks for the comments/advice everyone. I'll get the pump ordered. I'll likely do the thermostat too while I'm at it.
Sadly it looks like mine doesn't fall under the extended warranty.
Acdelco filters
