KIA TYPE 4 (M) ATF
by flinter - 05/28/20 08:49 PM
My new Henry 22 Magnum rifle
by tig1 - 05/28/20 08:45 PM
Mobil 1 M-102 for 3 6000km oil changes?
by pktrkt - 05/28/20 08:33 PM
1/2 75W-90 1/2 75W-110 Can you mix equal parts
by jrommelt - 05/28/20 08:22 PM
Mazda b4000 to the junkyard
by HyundaiAbuser - 05/28/20 08:20 PM
2017 RAM 2500 6.4 Hemi AMSoil and PUP
by Gondul - 05/28/20 07:50 PM
Nail in tire, what would you do?
by Brybo86 - 05/28/20 07:44 PM
Any decent lap tops for $200.00 or less?
by BAJA_05 - 05/28/20 06:49 PM
New PW with Honda 190 engine - Ethanol treatment?
by DirtyApe - 05/28/20 06:38 PM
What size tube should a 110/50-6.5 Tire use?
by taztheman - 05/28/20 06:14 PM
C&P Allison Transmission Filter - 27k miles, 3 years
by shibby6600 - 05/28/20 05:51 PM
XG9100 - 7k miles - 9 months - filter magnet
by shibby6600 - 05/28/20 05:47 PM
2017 Audi A4 PCV Valve replacement
by dbias - 05/28/20 05:23 PM
Audi E-Tron Technik
by OVERKILL - 05/28/20 05:12 PM
Deer 1....My Avalon 0
by ZZman - 05/28/20 03:21 PM
Auto Dealers Supplies?
by cknight49090 - 05/28/20 03:09 PM
interesting video reg vs premium
by raaizin - 05/28/20 02:55 PM
Discount Tire Direct FLASH SALE
by Mr Nice - 05/28/20 02:42 PM
2021 Acura TLX Sports
by buster - 05/28/20 01:36 PM
Kboggs, oldcodger, cwllams1, Danwrig, DanielR
71558 Registered Users
100 registered members (830Lee, agarb, 4WD, aquariuscsm, AndyB, Alfred_B, 10 invisible), 2,158 guests, and 48 spiders.
Topics305,997
Posts5,284,338
Members71,558
Do timing chain engines have cam and crank seals? #5431743 05/17/20 06:16 PM
J
Jeff8820 Offline OP
J
Was just curious, since a timing chain cover is bathed in oil would there be any purpose for those 2 seals?
Re: Do timing chain engines have cam and crank seals? [Re: Jeff8820] #5431746 05/17/20 06:21 PM
K
ka9mnx Offline
K
Crank seal only. It's the only thing that projects from the timing cover (for a normal push rod engine). Over head cams have a camshaft seal.
2005 Ranger 3.0 - SuperTech Syn 0w-20/Motorcraft
2000 4Runner 3.4 - SuperTech Syn 5w-30/Toyota
1997 B2500 Van 3.9 - M1 HM 10w-30/Mopar
1993 F150 4.9 - SuperTech Syn 5w-30/Motorcraft
Re: Do timing chain engines have cam and crank seals? [Re: ka9mnx] #5431750 05/17/20 06:25 PM
J
Jeff8820 Offline OP
J
Thanks, that's kind of what I was thinking, so a modern overhead Cam (chain) 4cyl engine would have both cam and crank seals, if I'm visualizing correctly, the crank seal could in theory be part of the timing chain cover since its only purpose is to keep oil from dripping out of the chain cover, also... In theory could the crank pulley be eliminated if there were no belt driven accessories?
Re: Do timing chain engines have cam and crank seals? [Re: Jeff8820] #5431772 05/17/20 07:01 PM
V
vw7674 Offline
V
The near-modern 4cyl engines with overhead cams usually feature half-moon cut outs in the cylinder head casting / valve cover gasket seal to allow camshaft removal
and timing chain replacement. There's usually a chain 'tunnel' in the interior of the engine front for the tensioner & guides. Only one vertical circular seal at the crankshaft seal.
Re: Do timing chain engines have cam and crank seals? [Re: Jeff8820] #5431892 05/17/20 09:24 PM
bdcardinal Offline
Not every DOHC engine has cam seals. You don't really need to worry about keeping oil off of a chain.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: Do timing chain engines have cam and crank seals? [Re: vw7674] #5431926 05/17/20 10:18 PM
clinebarger Offline
The half moon cutouts are there for/from line boring the cam journals
2001 Chevy Camaro L92/4L80E
Re: Do timing chain engines have cam and crank seals? [Re: clinebarger] #5431985 05/18/20 12:50 AM
V
vw7674 Offline
V
No. They are there for ready access with a socket & torque wrench to torque the camshaft sprockets to the shafts.
The builders could easily of blanked the boring holes off with affordable plugs otherwise, just like the backside of 20th century american V-8s.
But they thought of repair service while they engineered their DOHC wonders.
You say potahtoe, I utter potato..........
Re: Do timing chain engines have cam and crank seals? [Re: vw7674] #5431989 05/18/20 01:37 AM
T
Trav Offline
T
What? Of course they are there for line boring, how else are they getting the boring bar in there without through access. It would be a good idea if you knew what you were talking about before calling one of the best mechanics on the board out.
Re: Do timing chain engines have cam and crank seals? [Re: ka9mnx] #5432006 05/18/20 03:42 AM
Z
ZeeOSix Offline
Z
Not if they are chain driven cams.
Re: Do timing chain engines have cam and crank seals? [Re: ZeeOSix] #5432090 05/18/20 07:03 AM
K
ka9mnx Offline
K
Not at the rear of the head opposite of the chain?
Re: Do timing chain engines have cam and crank seals? [Re: ka9mnx] #5432716 05/18/20 06:57 PM
CR94 Offline
My SOHC Mazda had the distributor there in-line with the camshaft, but no camshaft seal as such. At the other end, a semi-circular cut-out in the timing-chain cover for access to the sprocket nut.
2011 Toyota Prius now at 110K
Re: Do timing chain engines have cam and crank seals? [Re: Jeff8820] #5432723 05/18/20 07:04 PM
supton Offline
Probably engine family dependent? I mean, I think my engine has a seal for the distributor that it used to have--over the years it was designed out, but there's still a hole on the end of the head for it. Probably used for line boring for one of the camshafts, but I think the seal is still considered "for the distributor". Now that I think about it, it probably depends on if the cam bearings are above or below the valve cover mating surface--below and they probably need seals, above and no need need.
2011 Toyota Camry, base, 2.5L/6MT, 205k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 159k, ours
1999 Toyota Camry LE, 2.2L/4AT, 225k, his
Re: Do timing chain engines have cam and crank seals? [Re: Jeff8820] #5432931 05/19/20 12:15 AM
O
oilboy123 Offline
O
The 2005 Ford Escape Duratech V-6 has a timing seal for an external pulley riding off the cam. Can't remember if it is intake cam, or exhaust? Anywho, it runs a belt for the water pump. So there are some funky set ups as well.
“Loyalty to country ALWAYS. Loyalty to government, when it deserves it.”
― Mark Twain
Re: Do timing chain engines have cam and crank seals? [Re: Jeff8820] #5432951 05/19/20 01:28 AM
M
mahanddeem Offline
M
Originally Posted by Jeff8820
...since a timing chain cover is bathed in oil..
Does timing change get inside the oil pan?
Re: Do timing chain engines have cam and crank seals? [Re: oilboy123] #5432959 05/19/20 02:09 AM
sdude2k2000 Online Content
Online Content
It sure does... and it also has an additional flat seal underneath that extended part of the valve cover as well. You can’t see it from the top down, but it’s there... and when it leaks it drips right on to the front catalytic converter’s heat shield. It smells wonderful at a stop light. Ask me how I know.... coffee
The duratec v6 is DOHC with a timing chain... it has both a cam seal and a crank seal. I had to have the timing cover gasket replaced on my Fusion... so they went ahead and did the crank seal at the same time since they were already there. Then they did the cam seal and that flat gasket as well. Good news - no leaks! Bad news - $2k lighter wallet.
'08 Ford Fusion SEL 3.0L
'15 Toyota Prius 1.8L
