Castrol Edge LL IV 0w20, not majority PAO
by wemay - 06/05/20 09:08 PM
Fram Titanium 20k mile oil filters at AAP....
by bbhero - 06/05/20 09:04 PM
D-Day 🇺🇸
by kstanf150 - 06/05/20 08:57 PM
Husqvarna 5.2 ounce 2 stroke oil .39 ymmv
by maintenanceMan - 06/05/20 08:53 PM
Mobil 1 Permazone
by maverickfhs - 06/05/20 07:47 PM
2 stroke oil
by opus - 06/05/20 06:19 PM
McKinney Falls State Park - Austin, TX
by wwillson - 06/05/20 05:22 PM
Gen 5 Rams (2019+)
by The Critic - 06/05/20 05:03 PM
CarQuest R95140 Cut Open
by HX520W - 06/05/20 04:47 PM
2012 Tacoma steering very stiff?
by wagsrk08 - 06/05/20 04:44 PM
"Quick change" sabotage episode
by Kira - 06/05/20 04:40 PM
Two Motorcraft FL400S Filters Cut Open
by HX520W - 06/05/20 04:36 PM
VIN character that designates engine
by grampi - 06/05/20 04:35 PM
Two WIX 57356XP Filters Cut Open
by HX520W - 06/05/20 04:17 PM
Blue lights on Uber vehicles
by John_Conrad - 06/05/20 04:08 PM
2015 RAM EcoDiesel 3.0L, 5,354mi, M1 TDT 5w40
by SavagePatch - 06/05/20 03:18 PM
2014 5.7 Charger UOA
by Bob D - 06/05/20 02:42 PM
Mazda 3 1.6 DV6C UOA Low TBN Qeustion
by mossietheno1 - 06/05/20 01:59 PM
CRJ-550
by dja4260 - 06/05/20 01:46 PM
3Dperf, LouK2, Michael328i, tyman, Knot_A_Mekanik
71616 Registered Users
86 registered members (bbhero, ArrestMeRedZ, BigCahuna, 2009Caraman, alchargo, aquariuscsm, 11 invisible), 1,616 guests, and 25 spiders.
Topics306,269
Posts5,289,349
Members71,616
Bad pressure switch? #5431671 05/17/20 05:08 PM
W
wallyuwl Offline OP
W
I have a well system. I noticed the pressure gauge is reading 85 psi. The pressure switch is a 40/60. The pump does not run when it shouldn't. Water pressure in the house fixtures seems mostly fine, but last few days the kitchen faucet will at times have low pressure.
This probably the switch? It isn't that old.
The thermopile on the water heater also just went bad today. Maybe related, or just coincidence.
Re: Bad pressure switch? [Re: wallyuwl] #5431683 05/17/20 05:17 PM
ABN_CBT_ENGR Offline
have you adjusted the differential?
Re: Bad pressure switch? [Re: wallyuwl] #5431730 05/17/20 05:59 PM
L
Lou_Boyle Offline
L
Or checked with another gauge?
Re: Bad pressure switch? [Re: wallyuwl] #5431754 05/17/20 06:32 PM
W
walterjay Offline
W
Do you have a jet or submersible pump?
Re: Bad pressure switch? [Re: wallyuwl] #5431763 05/17/20 06:50 PM
W
wallyuwl Offline OP
W
Submersible I think. Haven't been in this house long.
Re: Bad pressure switch? [Re: wallyuwl] #5431771 05/17/20 07:00 PM
W
walterjay Offline
W
If you are handy just replace both the pressure switch and the guage. Cost about $30.00 Do them both.
Take note of the switch wiring and be sure to put it back exactly the same way.
Re: Bad pressure switch? [Re: wallyuwl] #5431825 05/17/20 08:17 PM
Donald Offline
You can get a gauge that has a fitting for a garden hose. Screw that in and see if it exactly matches the one that is part of the pump control.
My guess is its the gauge.
Something is amiss. The gauge reads 85 but the water pressure in the kitchen is sometimes low.
If you drain the system to replace either, good time to check the pressure on the pump tank. It should be a certain pressure, probably marked on the tank. If its zero with the system opened up, the bladder is shot and you need a new tank.
Any well problem short of replacing the actual pump is a good day.
2015 Ford F-250 w/Powerstroke
Re: Bad pressure switch? [Re: wallyuwl] #5431833 05/17/20 08:23 PM
Chris142 Online Content
Online Content
I made a gizmo that I can plug an air chuck into. Screwed into that chuck is a tire valve stem. I can check my pressure with a tire gauge.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Bad pressure switch? [Re: wallyuwl] #5431857 05/17/20 08:47 PM
W
walterjay Offline
W
If the water pressure is sometime low that is a telltale sign that the pressure switch is sticking. It will delay coming on and delay going off. Replace switch and guage and sleep well. And while you have the system drained, check the pressure in the well tank. Set it 2-4 lbs. below the cut in for the new pressure switch.
Re: Bad pressure switch? [Re: wallyuwl] #5431895 05/17/20 09:26 PM
Dinoburner Online Content
Online Content
If you have a pressure trol (bladder style) tank it may be water logged, that is a failed bladder that cannot maintain an air cushion resulting in a pressure spike before the switch can shut off the pump, The failed switch mentioned is also probable,
77 Chev stepside 454 Casteroil syn
95 GMC 4wd mobil syn
2016 Equinox LTZ V6 dealer
Kubota L5030 T6
Re: Bad pressure switch? [Re: wallyuwl] #5431938 05/17/20 10:34 PM
M
MNgopher Offline
M
Check with another guage. The lifespan of those guages seems to be measured months, not years... Agree with checking the bladder air pressure in the well tank after that. Throwing another pressure switch is shotgunning parts at it wihout diagnosing the rest of the system... The pressure switch is only as good as the rest of the system...
Re: Bad pressure switch? [Re: Chris142] #5432097 05/18/20 07:11 AM
Donald Offline
Does it get water into the tire gauge?
Re: Bad pressure switch? [Re: wallyuwl] #5432354 05/18/20 12:47 PM
M
mk378 Offline
M
Only problem I've seen with those "Pumptrol" switches, and it will eventually happen to all of them, is one of the contact point assemblies will break off of the moving arm. Then the pump doesn't run at all.
Re: Bad pressure switch? [Re: wallyuwl] #5432694 05/18/20 06:33 PM
W
wallyuwl Offline OP
W
It was the pressure gauge. I replaced that and it is reading normal and the pump is working fine. I don't know how I'd replace the switch without water going all over. I shut off the pump, closed all the valves, drained the tank, and still water was coming out like crazy when I replaced the gauge. I did it quick so not much water came out in total. I don't know where the water was coming from since I drained the tank. There wold be a lot longer time for water to come out in replacing the switch.
The thermopile low voltage light on the water heater I fixed, too. I replaced the thermopile last night, and it still had the error. I got the whole burner assembly replaced under warranty today (water heater is a 2016), was able to get it at a local plumber, and changed it in about ten minute (very easy to do the whole assembly). Works like a charm now, so far.
