GTX Ultraclean now in 0W-20
by wemay - 06/05/20 08:38 AM
Glassware for bevarages
by Duffyjr - 06/05/20 08:24 AM
New Permatex Orange Threadlocker
by Snagglefoot - 06/05/20 07:39 AM
Peak Blue 64oz Diesel Cetane Booster $14.49
by Bighorn2500 - 06/05/20 07:22 AM
OTC Stinger 3 Ton Jack Stands, no good
by michaelluscher - 06/05/20 06:44 AM
$900 + a lot of shipping/fees electric car
by madRiver - 06/05/20 06:44 AM
PUP SP
by Koncrete_Cam - 06/05/20 05:52 AM
Hailstorm Yesterday
by Delta - 06/05/20 04:47 AM
Date code on Mighty Engine Guard II? Air Filter
by blufeb95 - 06/05/20 01:01 AM
My poor Jetta can't catch a break.
by FordBroncoVWJeta - 06/05/20 12:22 AM
Bought a truck finally, warning no Ford content
by bdcardinal - 06/04/20 11:31 PM
Got a septoplasty today....
by daves66nova - 06/04/20 10:44 PM
2020 330i xDrive Loaner
by MCompact - 06/04/20 10:02 PM
Appliance repair?
by motor_oil_madman - 06/04/20 09:44 PM
Glad we got a seasonal RV site
by Pat in Speedway - 06/04/20 09:19 PM
Mobil 1 AP Clearance at Wal-Mart
by KeithS_NW_Ohio - 06/04/20 09:07 PM
Recent experience with a Michelin Defender
by FordSVTGuy - 06/04/20 08:46 PM
music quality of speakers in the 70's vs now
by raaizin - 06/04/20 08:15 PM
Jettero, TinyHouseTruck, stubby73, Polkaman, Ramboagain
71610 Registered Users
95 registered members (14Accent, amblerman, 440Magnum, 1911CHAMPION, ARCOgraphite, aquariuscsm, 8 invisible), 1,630 guests, and 56 spiders.
Topics306,238
Posts5,288,788
Members71,610
Yard Machines blade adapter #5431667 05/17/20 05:06 PM
9
97prizm Offline OP
9
High all,
I have a 7 year old or so yard machines push mower. The blade adapter works well for the Arnold 6-N-1 blade. I've managed to get the gator blade i purchased to work occasionally but since it's considerably heavier and the mounting holes aren't exact it tends to shear the teeth off of the adapter. Has anyone ever found a way around this? The adapter on my mower looks like this
Blade Adapter
The gator blade looks like this
https://www.agrisupply.com/mtd-bole...oh_S76QIVUNbACh0LSQaHEAQYBCABEgLFhfD_BwE
Not sure how to find the correct adapter.
If at first you don't succeed fail fail again. (Waldorf and Statler.)
1997 Geo Prizm...DEAD
1984 Mazda RX-7 Spec 7
2005 Dodge Neon
Re: Yard Machines blade adapter [Re: 97prizm] #5431736 05/17/20 06:04 PM
M
MParr Offline
M
You would probably be better off with MTD brand replacement mower blades. Even better would be to go to your local OPE dealer and get the correct replacement blade made by Rotary Corporation. I’m not a fan of the gator type blades. Growing grass holds a lot of water and gator type blades will cause a lot of buildup under the deck. They are okay for fall cleanup and that’s about it.
2019 VW Tiguan SE 2.0 TSI Now: Castrol Pro OE LL IV 0W20 & OE VW
2020 F-150 STX Super Cab 2WD 2.7 Ecoboost. FF & OE filter
Re: Yard Machines blade adapter [Re: 97prizm] #5431905 05/17/20 09:36 PM
M
mk378 Online Content
Online Content
M
That blade does not have side holes. It's not going to seat on the adapter properly since there are bosses for the side holes.
25 mm is a standard shaft size, look for an adapter that matches the blade.
Also check the bolt torque, it needs to be tight. Generally a lot tighter than you can get with a basic 3/8 ratchet. But this will not solve improper fit.
Re: Yard Machines blade adapter [Re: 97prizm] #5431919 05/17/20 10:05 PM
9
97prizm Offline OP
9
Actually the few times i used the gator blade it left almost no grass build up under the mower.
2005 Dodge Neon
Re: Yard Machines blade adapter [Re: 97prizm] #5432054 05/18/20 06:06 AM
M
MParr Offline
M
Re: Yard Machines blade adapter [Re: 97prizm] #5432066 05/18/20 06:37 AM
M
MParr Offline
M
I can’t get the links to work.
Anyway, you can go to the Rotary Corporation site or Oregon site and enter your mower blades dimensions and Six point Star Center hole and you will find the correct blades.
