Replacing PCV question
GA
2015 Subaru Crosstrek with 60K miles
Subaru manual calls for Three Bond 1324 or equivalent. I'm confused; the equivalent is coming up as either a thread locker or a high temp liquid gasket. What do I need for this application? The Subaru part number is coming up as no longer available (004403042).
Thanks!
Should be able to just give that a solvent spray if there is some gum in there
. What is going to happen to a PCV vent in 60k miles?
It just an aperture with some having a spring and anti backfire pellet shuttle valve.
Do not use ANY RTV anywhere near a the intake plumbing on a modern car.
It's for the threaded portion of the valve, No different than using RTV to seal an engine cover or oil pan. Both RTV's I mentioned are "Sensor Safe"
I'm going to be changing the front differential gear oil and will fill it up through the air breather tube (fill plugs are a [censored] to loosen). To do so I'm removing the air intake. It's a good time and cheap enough part to replace while I'm doing this. I see it as preventative maintenance, but better yet, it makes me feel good.
