Valvoline NG oil in a Diesel
by Aerojoe - 06/04/20 05:35 AM
bathroom toilet leaking help
by FirstNissan - 06/04/20 02:52 AM
Scored some NOS old dogs
by GMguy84 - 06/04/20 01:56 AM
Chevy Positraction 1057721
by rorty - 06/04/20 12:42 AM
Moving up to 5w30. How thick is too thick?
by BTLew81 - 06/03/20 11:15 PM
Renting UHaul Truck to Tow Your Own Trailer?
by Miller88 - 06/03/20 09:40 PM
First Oil Change Recommendation
by gtpimp - 06/03/20 09:20 PM
GM 10L80 Issues
by shimps1 - 06/03/20 08:26 PM
Brake/Carb cleaner issue.
by Jarpin - 06/03/20 07:27 PM
sharp oil pressure drop-off > 130C
by bbrtuning - 06/03/20 06:48 PM
Warranty work
by t1snwrbrdr12 - 06/03/20 06:10 PM
AC Flashing Light
by artbuc - 06/03/20 05:13 PM
Watches
by Passport1 - 06/03/20 03:57 PM
best budget tire
by VQLT - 06/03/20 03:33 PM
Castrol EDGE turns black/red FAST
by Silver - 06/03/20 03:20 PM
Our van feels "Darty" or twitchy" on the highway
by 1911CHAMPION - 06/03/20 02:55 PM
You guys who pile the miles up weekly on your ride
by Speak2Mountain - 06/03/20 02:22 PM
'19 + '20 Kicks w/C.V.T. : Any owners or know
by odie - 06/03/20 01:38 PM
Securing rubber hose to metal tubing?
by joshuawesl - 06/03/20 01:15 PM
Kernal, AB_Indian, rorty, Ghosty, zmann96
71604 Registered Users
42 registered members (BigGeo, Amkeer, Aerojoe, 87sammy, 53' Stude, 3 invisible), 924 guests, and 57 spiders.
Topics306,117
Posts5,287,830
Members71,604
Replacing PCV question #5431009 05/16/20 10:33 PM
J
Jeep_Riot Offline OP
J
2015 Subaru Crosstrek with 60K miles
Subaru manual calls for Three Bond 1324 or equivalent. I'm confused; the equivalent is coming up as either a thread locker or a high temp liquid gasket. What do I need for this application? The Subaru part number is coming up as no longer available (004403042).
Thanks!
Re: Replacing PCV question [Re: Jeep_Riot] #5431031 05/16/20 11:34 PM
clinebarger Offline
PTFE thread sealant or Ultra Black/Ultra Grey RTV will work fine. I'd use Hylomar M...But thats me.
2001 Chevy Camaro L92/4L80E
Re: Replacing PCV question [Re: Jeep_Riot] #5431039 05/17/20 12:01 AM
M
mimelio Offline
M
Re: Replacing PCV question [Re: Jeep_Riot] #5431247 05/17/20 09:48 AM
A
ARCOgraphite Offline
A
Should be able to just give that a solvent spray if there is some gum in there
. What is going to happen to a PCV vent in 60k miles?
It just an aperture with some having a spring and anti backfire pellet shuttle valve.
Do not use ANY RTV anywhere near a the intake plumbing on a modern car.
2019 VW Jetta S 6MT OCI#2 7378mi-MOTUL Specific VW508.00+VW Service Filter; '17 Subaru Crosstrek CVT OC#9 70254mi-Rotella
Gas Truck 5W20 + Fram Ultra 7317 Filter
Re: Replacing PCV question [Re: Jeep_Riot] #5431798 05/17/20 07:38 PM
T
Timmastertech Offline
T
Teflon thread sealant is fine. Subaru NA part number for three bond 1324 is SOA868V9630
Re: Replacing PCV question [Re: ARCOgraphite] #5431904 05/17/20 09:33 PM
clinebarger Offline
It's for the threaded portion of the valve, No different than using RTV to seal an engine cover or oil pan. Both RTV's I mentioned are "Sensor Safe"
Re: Replacing PCV question [Re: Jeep_Riot] #5432182 05/18/20 09:09 AM
A
A
Shouldnt require replacement in the first place.
Unless its "broken"
Re: Replacing PCV question [Re: ARCOgraphite] #5432238 05/18/20 10:21 AM
J
J
I'm going to be changing the front differential gear oil and will fill it up through the air breather tube (fill plugs are a [censored] to loosen). To do so I'm removing the air intake. It's a good time and cheap enough part to replace while I'm doing this. I see it as preventative maintenance, but better yet, it makes me feel good.
