New Permatex Orange Threadlocker
by Snagglefoot - 06/05/20 07:39 AM
Peak Blue 64oz Diesel Cetane Booster $14.49
by Bighorn2500 - 06/05/20 07:22 AM
OTC Stinger 3 Ton Jack Stands, no good
by michaelluscher - 06/05/20 06:44 AM
$900 + a lot of shipping/fees electric car
by madRiver - 06/05/20 06:44 AM
PUP SP
by Koncrete_Cam - 06/05/20 05:52 AM
Hailstorm Yesterday
by Delta - 06/05/20 04:47 AM
Date code on Mighty Engine Guard II? Air Filter
by blufeb95 - 06/05/20 01:01 AM
My poor Jetta can't catch a break.
by FordBroncoVWJeta - 06/05/20 12:22 AM
Bought a truck finally, warning no Ford content
by bdcardinal - 06/04/20 11:31 PM
Got a septoplasty today....
by daves66nova - 06/04/20 10:44 PM
2020 330i xDrive Loaner
by MCompact - 06/04/20 10:02 PM
Appliance repair?
by motor_oil_madman - 06/04/20 09:44 PM
Glad we got a seasonal RV site
by Pat in Speedway - 06/04/20 09:19 PM
Mobil 1 AP Clearance at Wal-Mart
by KeithS_NW_Ohio - 06/04/20 09:07 PM
Recent experience with a Michelin Defender
by FordSVTGuy - 06/04/20 08:46 PM
music quality of speakers in the 70's vs now
by raaizin - 06/04/20 08:15 PM
pressure washer care
by raaizin - 06/04/20 08:06 PM
Watch Forums?
by maverickfhs - 06/04/20 07:53 PM
Jettero, TinyHouseTruck, stubby73, Polkaman, Ramboagain
71610 Registered Users
116 registered members (2015_PSD, 2004tdigls, 77GrandPrix, 1911CHAMPION, 46Harry, 4WD, 10 invisible), 1,555 guests, and 80 spiders.
Topics306,235
Posts5,288,757
Members71,610
Thermostat gasket cut too small #5430875 05/16/20 07:00 PM
M
motor_oil_madman Online Content OP
OP Online Content
M
I had a buddy change out the thermostat gasket on my boat and when he cut out the gasket he cut the inside hole slightly smaller, like maybe 1/4'' smaller. It's not interfering with the thermostat operating, but it does overlap it a tad. I'm irritated he didn't take more time to cut it out better. I was going to take the boat out today, but decided not too cause i'm paranoid that that portion of the gasket will break off and get into the coolant system. I'm like really?? and he's like it's fine it's fine I do these all the time. He got it to stop leaking better than it ever has, so is it okay temporarily for a couple boat rides until I fix it again using rtv and Teflon sealant on the bolts like people here suggested?
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
Re: Thermostat gasket cut too small [Re: motor_oil_madman] #5430922 05/16/20 07:54 PM
M
OP Online Content
M
I know. How dumb can you get huh?
Re: Thermostat gasket cut too small [Re: motor_oil_madman] #5430952 05/16/20 08:51 PM
Nick1994 Offline
It overlaps on the side where the thermostat meets the engine, or where it meets the housing?
If the housing side, I’d just keep an eye on it. Being a boat on the water, if it started leaking, it’s not going to overheat, right? Since it won’t ever run out of coolant. I could be wrong, I don’t know boats lol.
2015 Hyundai Genesis 5.0L 61k Dealer Bulk SynBlend 5w20 & OEM
2000 Toyota Camry 2.2L 239k Mobil Delvac 15w40 & Fram Ultra
1996 Jeep Cherokee 4.0L 150k Rotella Gas Truck 5w30 & Wix
Re: Thermostat gasket cut too small [Re: motor_oil_madman] #5430995 05/16/20 10:08 PM
R
rubberchicken Offline
R
What boat engine ? If its a GM based engine, make sure you use the gasket with the brass eyes- they are required for proper corrosion protection and continuity of the thermostat sender.
Re: Thermostat gasket cut too small [Re: motor_oil_madman] #5431004 05/16/20 10:28 PM
M
OP Online Content
M
Yes it is covering the bypass hole, but I don't think it would block the flow.
Re: Thermostat gasket cut too small [Re: motor_oil_madman] #5431006 05/16/20 10:30 PM
Chris142 Online Content
Online Content
Run it. You are way overthinking it. The extra gasket wont go anywhere. Years ago we bought thermostats that came with a universal gasket. It hung out in several places.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Thermostat gasket cut too small [Re: motor_oil_madman] #5431089 05/17/20 05:57 AM
N
nobb Offline
N
If you're OCD like most people here, just change it for the peace of mind. Better to do it sooner too because as that gasket hardens from the heat cycles it'll be more work to change out later (I hate scraping gaskets).
Also next time you do it, you shouldn't need RTV. Almost every gasket maker recommends a clean surface with the gasket installed dry. RTV just increases the chance that chunks will break off and enter the cooling system.
Re: Thermostat gasket cut too small [Re: motor_oil_madman] #5431143 05/17/20 07:45 AM
E
eljefino Offline
E
If it's been leaking you have a not-flat surface. Corrosion?
As long as you're seeking out universal gasket material, I'd find something a little more rubbery and spongy.
Re: Thermostat gasket cut too small [Re: motor_oil_madman] #5431232 05/17/20 09:32 AM
M
OP Online Content
M
I think it leaks through the bolts holes. It goes through to the coolant. So really I just need to add some thread sealant.
Re: Thermostat gasket cut too small [Re: motor_oil_madman] #5432072 05/18/20 06:46 AM
L
Lubener Offline
L
Giiligan did the same thing before they set out on their last cruise.
The "thinking" man's friend.
