Rockauto code expires 8/2
by gallydif - 06/02/20 08:19 AM
The worst job you ever had?
by Chris142 - 06/02/20 08:04 AM
P218F on my Ford PSD
by Donald - 06/02/20 06:34 AM
Kudos to Griot's
by Egg_Head - 06/02/20 05:43 AM
Exide Battery files for bankruptcy
by Randol - 06/02/20 04:34 AM
Just one more wax question.
by rrretiree7 - 06/02/20 01:49 AM
Removing stuck bolts- interesting technique
by rubberchicken - 06/02/20 12:47 AM
Unless it is a misprint?
by 340_Magnum - 06/01/20 10:25 PM
Raymond Weil 5590 Watch Battery Replacement
by maverickfhs - 06/01/20 09:22 PM
Echo SRM 230 idling high
by CDX825 - 06/01/20 08:40 PM
Walmart in Canada closing Lube and Tire Express
by Snagglefoot - 06/01/20 08:26 PM
2012 Sonic - LCA puck bushing
by Number_35 - 06/01/20 06:44 PM
Rotate mags?
by marine65 - 06/01/20 06:40 PM
Re-using good coolant?
by Jarpin - 06/01/20 06:21 PM
Best entry level riding mower
by UncleDave - 06/01/20 03:02 PM
2015 Pilot LX
by madRiver - 06/01/20 03:01 PM
NewMex, RandyN11049, bbrtuning, chapys, DaaBoss
71593 Registered Users
80 registered members (1978elcamino, ARCOgraphite, akh, 53' Stude, Asterix, 1foxracing, 9 invisible), 1,885 guests, and 49 spiders.
Topics306,053
Posts5,286,471
Members71,593
Marine cranking/starting or deep cycle? #5430796 05/16/20 04:26 PM
I
irv Offline OP
I
I am currently in the need of a cranking battery for my 07 90 H/P Merc 4 stroke and I am unsure if I should just get a dedicated automotivr starting battery, a Marine starting battery or just go with a deep cycle dual battery??
My boat has 2 batteries, one for trolling and accessories and the other which I just use strictly for starting, which is what I need now.
I was/am thinking of just buying a regular cranking/starting car type battery but will it last and be able to withstand occasional rough conditions at times?
I just seen a dedicated Marine Starting battery from Interstate and I am currently leaning that way as well but I obviously need some advice.
Also, around what amount of CC amps will I need? I don't use this boat/engine in the cold weather intentionally, only spring/summer/fall with the majority being summer. June, July and August.
Thanks in advance. cheers
2017 Chevy Impala 3.6 L.
2013 Ram 5.7 L Hemi Bighorn QC 4x4
2008 Chevy Malibu 2.4 L Ecotec
Pennzoil Platinum and/or Pennzoil Ultra Platinum in all 3.
Re: Marine cranking/starting or deep cycle? [Re: irv] #5430806 05/16/20 04:53 PM
R
ripcord Offline
R
Marine starting batteries supposedly have thicker plates and are better able to withstand deeper discharging with less damage. Since boats tend to sit much longer than cars this is an advantage. They are not true deep cycle batteries, though. Their design trades peak cranking amps for deeper cycling ability, but they will still be damaged by deep discharges.
True deep cycle batteries on the other hand will not last long under the high power draws starting an engine requires. They are designed with entirely different parameters.
Costco sells Interstate group 27 and 24 marine starting batteries for about the same price as regular automotive batteries and that's what I would probably go with.
Re: Marine cranking/starting or deep cycle? [Re: ripcord] #5430826 05/16/20 05:32 PM
I
irv Offline OP
I
That's what I was thinking, they are just somewhat tougher for marine applications.
My prior/dead, no longer good battery was a deep cycle and it lasted quite a few years and I believe at that time, the marina told me it is good for both cranking and deep cycle/accessory use? I am not sure if I was fed a line or not, however?
I checked our Costco up here (Canada) and all I could see is their Kirkland brand and Optima batteries, no Interstate? I'll look again.
Thanks for the info, I appreciate it. cheers
Re: Marine cranking/starting or deep cycle? [Re: irv] #5430832 05/16/20 05:46 PM
spasm3 Offline
Are you limited on battery physical size? Do you have any accessories that run off the starting battery side? If just for starting, I would get the biggest physical battery that will fit, with the lowest CCA that meets your needs.
( theory here is that higher CCA batteries have more plates in a give space, so they are thinner I.E more susceptible to vibration/damage).
Can't guess at required amps, look for the model manual online, or call a boat shop. Perhaps look at what battery model is in it now, and check those specs.
13 elantra 84k 5w30 synpwr
17 mazda cx-5 19000 miles m1 0w30
Re: Marine cranking/starting or deep cycle? [Re: spasm3] #5430848 05/16/20 06:27 PM
I
irv Offline OP
I
I am somewhat limited in size as both batteries fit in a prefabricated tray and are hidden from view in a compartment.
Nothing else runs off my starting battery, but it does allow for trim and tilt functions. My other deep cycle battery runs my radio, fish finder, and accessory lights when needed.
My engine requires: (copy and paste): 350 CCA (750 MCA) ABOVE 32°F ABOVE 32°F ABOVE 32°F ABOVE 32°F
above 32ºF 24M5 24M5, 24M6, 24M7, 8A24M 9A34M, 9A31 141,
750 CCA below 32ºF
So with that being said, I am not strongly leaning towards this Interstate 24M-HD dedicated starting battery, which has 500 CCA and 625 CA https://www.interstatebatteries.com...ubcategoryKey=&ignorecategoryid=true
Thoughts? shrug
Re: Marine cranking/starting or deep cycle? [Re: irv] #5430857 05/16/20 06:41 PM
spasm3 Offline
I like deka/east penn batteries. I have used several deep cycle on my travel trailers with good service. Others can chime in but i think this one is made by east penn.
https://www.oreillyauto.com/detail/...chevrolet/avalanche-1500?q=24m&pos=3
Re: Marine cranking/starting or deep cycle? [Re: spasm3] #5430871 05/16/20 06:58 PM
I
irv Offline OP
I
I'm unsure what is all available up here compared to the U.S. but I am currently using 1 Interstate and 1 Car Quest battery in my trailer (soon to be 2 CQ's)
So far I have had good luck with both brands but I do know the Interstates hold their charge better than the CQ's. I can get CQ's at the mechanics rate as my bud practically runs a store, but they no longer carry Interstates either. I have also noticed, even with his discount, I can now find parts, etc sometimes cheaper at other places. There is only so much he can do as they don't offer price match, especially when its from a different supplier/manu, and he knows this and doesn't blame me for shopping elsewhere at times.
Re: Marine cranking/starting or deep cycle? [Re: irv] #5430951 05/16/20 08:50 PM
M
meadows Offline
M
Go to sams for deka/East Penn
Re: Marine cranking/starting or deep cycle? [Re: irv] #5430955 05/16/20 08:55 PM
R
ripcord Offline
R
Thoughts? shrug
That looks suspiciously like the battery they sell at my local Costco for $80.
[Linked Image]
Re: Marine cranking/starting or deep cycle? [Re: irv] #5430956 05/16/20 08:56 PM
G
GSCJR Offline
G
I have never seen Interstate around here at Costco. As you said irv, it's either Optima or Kirkland. Check out Costco.ca, they also have marine/AGM batteries there.
07 3.5L VQ35DE NAPA FS 5w-20 ProSelect 21358 158KM
10 3.5L 2GR-FE NAPA FS 5w-20 ProSelect 27047 180KM
Re: Marine cranking/starting or deep cycle? [Re: irv] #5430965 05/16/20 09:13 PM
Snagglefoot Online Content
Online Content
I’m running a Walmart Everstart Marine/RV deep cycle with 550 CCA and 120 minute reserve capacity. Never missed a start. Since it’s a single battery I like the idea and having a deep cycle to power the stereo or the fish finder.
If you want the job done right......do it yourself.
Re: Marine cranking/starting or deep cycle? [Re: irv] #5431059 05/17/20 01:25 AM
Online Content
Walmart Everstart:
Re: Marine cranking/starting or deep cycle? [Re: irv] #5431099 05/17/20 06:19 AM
N
NYEngineer Online Content
Online Content
N
Ive been around boats since Im a kid. Start the engine with a starting battery. Run your electronics and such with a deep cycle.
I cannot remember why but my friend ran a battery store for thirty years on Long Island. I know he didnt push combination deep cycle and starting batteries. Ill ask him why and post back.
Re: Marine cranking/starting or deep cycle? [Re: irv] #5431186 05/17/20 08:43 AM
K
kc8adu Offline
K
a marine starting is a regular starting battery with the stud/nuts terminals along with posts.
if you dont need the studs/nuts just buy a cheaper starting battery.
no difference i could see looking inside 2 of the same brand/cca.
a real deep cycle has fewer but thicker plates.
and almost always has caps so you can add water.
they are antimony rather than calcium and will use water.
Re: Marine cranking/starting or deep cycle? [Re: ripcord] #5431401 05/17/20 01:19 PM
Driz Offline
Thoughts? shrug
[Linked Image]
I saw those at Wallymart. The just don’t look anything like the I interstates I Have. They remind me of the cheapo lawn mower batteries that never seem to last. Then I saw the label , 12 months....🥴..no thanks. My usual interstates last 6-7 years even in intermittent service.
