I need your help picking out fireworks for a show.
by joegreen - 05/30/20 12:13 AM
Best off the shelf oil for the price
by samiamz - 05/30/20 12:09 AM
I upgrade my car
by miden851 - 05/30/20 12:00 AM
Ford PVD Wheels Defects
by kstanf150 - 05/29/20 07:48 PM
General thoughts on high milage oils.
by tblt44 - 05/29/20 07:09 PM
Jeep Wrangler JL
by dishdude - 05/29/20 06:43 PM
Valvoline MaxLife 5W-20
by Jackson_Slugger - 05/29/20 06:33 PM
Yamaha dry sump PWC and oil level sensitivity.
by ledslinger - 05/29/20 06:30 PM
WSS-M2C946-B1 vs WSS-M2C961-A1
by W9HDG - 05/29/20 06:16 PM
Waterfall Eco Dynamic tires
by Saabist - 05/29/20 05:55 PM
O’reilly clearance
by Gonz - 05/29/20 04:56 PM
2016 Overland Jeep Wrangler Oil/Filter
by Since1941 - 05/29/20 04:24 PM
Next Pistol Opinions
by Gebo - 05/29/20 03:28 PM
Briggs and Stratton valve clearance
by supton - 05/29/20 02:38 PM
50 cal. shell
by Donald - 05/29/20 01:52 PM
Fleet Farm Rotella T6 Sale + Shell Rebate
by shibby6600 - 05/29/20 01:26 PM
QS Ultimate Durability 5W-30
by js1956 - 05/29/20 12:51 PM
KPVD Eerily Deserted
by wings&wheels - 05/29/20 12:24 PM
dieselworks, suburbandoom, alltogether, Vig03, dstocker
71566 Registered Users
42 registered members (carlprop, ArrestMeRedZ, Blkstanger, Arcoril, blufeb95, 928, 5 invisible), 1,344 guests, and 33 spiders.
Topics306,032
Posts5,285,230
Members71,566
Sae 40 in my tractor? Why not? #5430583 05/16/20 10:30 AM
Chris142 Online Content OP
OP Online Content
My 1956-7 Case. It did not sound good on multi viscosity oil. I am sure that it's 3 main bearings are worn down to the copper. It only has a bypass oil filter.It runs well on Sae30.
I have some sae40. Why not use it?
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Sae 40 in my tractor? Why not? [Re: Chris142] #5430586 05/16/20 10:34 AM
4WD Offline
I did not look up the numbers … but when pouring some Super Tech SAE HD30, boy did that oil look thick on an 80F day.
It’s SN plus oddly enough …
Both of these are all oil …
Re: Sae 40 in my tractor? Why not? [Re: Chris142] #5430599 05/16/20 10:57 AM
Carbon12 Offline
Probably won’t hurt during warm weather. Have you tried any 15w40 HDEO?
Re: Sae 40 in my tractor? Why not? [Re: Carbon12] #5430602 05/16/20 11:04 AM
OP Online Content
Yes. The bottom end knocked and rattled.
Re: Sae 40 in my tractor? Why not? [Re: Chris142] #5430631 05/16/20 11:44 AM
4WD Offline
Well, if SAE 40 does not calm it (climbing in flame suit now) … can of thick oil additive might help you rule out or validate the viscosity theory
Re: Sae 40 in my tractor? Why not? [Re: 4WD] #5430678 05/16/20 12:57 PM
OP Online Content
Sae 30 is good in it too. I have the 40 and need a reason to use it.
Re: Sae 40 in my tractor? Why not? [Re: Chris142] #5430694 05/16/20 01:22 PM
Z
Zaedock Offline
Z
I used Traveler HD40 in my old '50 8N, even when it was a bit cool out, no issues.
Is your Case a 300?
2019 Escape EB AWD/2016 KIA Optima SXL 2.0L Turbo/2012 F150 Ex-cab 5.0L
1992 YJ "The Heep"/2015 Chrysler 200 Limited
1975 Ford Bronco/1959 Willys CJ5/Tube Rock crawler
Re: Sae 40 in my tractor? Why not? [Re: Zaedock] #5430725 05/16/20 02:23 PM
OP Online Content
Is your Case a 300?
Yes. The tag is gone but it is a 56-57 case roundnose i was told that its a 311
Re: Sae 40 in my tractor? Why not? [Re: Chris142] #5430729 05/16/20 02:27 PM
R
ripcord Offline
R
As long as you're not trying to start in sub zero temps, I wouldn't give 40 weight a second thought.
Re: Sae 40 in my tractor? Why not? [Re: Chris142] #5430758 05/16/20 03:27 PM
W
walterjay Offline
W
No problem with 40 in this kind of weather.
Re: Sae 40 in my tractor? Why not? [Re: Chris142] #5430764 05/16/20 03:39 PM
Z
Zaedock Offline
Z
Is your Case a 300?
That's a row crop. I believe those engines are serviceable in frame. I don't think it would take much to replace the bearings. Kind of a hack job, but better than copper bashing.
Re: Sae 40 in my tractor? Why not? [Re: Zaedock] #5430771 05/16/20 03:45 PM
OP Online Content
Is your Case a 300?
Looks like the whole front suspension has to come off to get the oil pan off. It has the HD adjustable front axle.
Re: Sae 40 in my tractor? Why not? [Re: Chris142] #5430776 05/16/20 03:53 PM
OP Online Content
Pics
Re: Sae 40 in my tractor? Why not? [Re: Chris142] #5430791 05/16/20 04:21 PM
Z
Zaedock Offline
Z
[censored] that would be a lot of work.
Go with the 40. I would. I don't remember how cold I've started engines with it, but I want to say around freezing. I think you'll be fine for the season.
Re: Sae 40 in my tractor? Why not? [Re: Zaedock] #5430835 05/16/20 06:02 PM
OP Online Content
Ya we do not normally get below 25f. I wont be using it on a day like that anyway.
