Environmentally friendly gas can rant
by IMSA_Racing_Fan - 05/26/20 12:58 AM
Left Hand Drillbits
by Snagglefoot - 05/25/20 10:32 PM
Turtle Wax Ice Spray Wax use tips.
by JimPghPA - 05/25/20 08:53 PM
Best oil on the market?
by sloinker - 05/25/20 08:47 PM
Xfinity Race in Charlotte
by kstanf150 - 05/25/20 08:12 PM
Purolator PBL14610 C&P
by FordBroncoVWJeta - 05/25/20 08:00 PM
Carquest Blue 85522 C&P
by FordBroncoVWJeta - 05/25/20 07:52 PM
2020 RAV4 Hybrid - oil options
by CELICA_XX - 05/25/20 07:44 PM
any battery charger/repair that can fix sulfation?
by apollo18 - 05/25/20 07:28 PM
Need Mice Advice
by Mr_Luke - 05/25/20 07:01 PM
pressure washer air compressor oil
by bedwards - 05/25/20 06:49 PM
2014 Elantra delayed shift 4th to 5th
by Propflux01 - 05/25/20 05:51 PM
2002 Ranger Electrical Weirdness (GEM, RAP?)
by DuckRyder - 05/25/20 05:47 PM
Oil change problems
by philipp10 - 05/25/20 05:41 PM
Denso 150 3024
by thrace - 05/25/20 04:58 PM
does ac delco warranty the replacement battery?
by apollo18 - 05/25/20 04:39 PM
Water drainage issue
by Paul_Siu - 05/25/20 04:39 PM
13 Corolla PCV
by AJB0009 - 05/25/20 04:24 PM
mikespine, Typerguy, showtyme1958, rickyradit, YogiTheCat
71528 Registered Users
31 registered members (ajchien, ArrestMeRedZ, bachman, BlakeB, blufeb95, bworley, 2 invisible), 1,307 guests, and 17 spiders.
Topics305,879
Posts5,281,957
Members71,528
Honda GCV190 motor oil #5430481 05/16/20 08:26 AM
O
Oey12 Offline OP
O
I have a Honda GCV190 motor on my HRX Honda push mower. The manual calls for 10w30 but I have a ton of Mobil 1 5w30 EP. Has anyone else done this? I don’t know enough about the motor to know if it picky about changes to the oil... I live in the northeast...lower NY area. Thanks!
Re: Honda GCV190 motor oil [Re: Oey12] #5430485 05/16/20 08:33 AM
Char Baby Offline
Yes! All I have ever used in my Honda 160-190 mowers(or any B&S, Tecumseh) is 5w30 conventional or synthetic, it doesn't matter.
Retired 6 yrs now & lovin' it
'15 Nissan Altima 2.5 SV
'15 Honda Civic 1.8 LX
Re: Honda GCV190 motor oil [Re: Oey12] #5430490 05/16/20 08:41 AM
caprice_2nv Offline
Same here with my Briggs and Stratton engines, my newest a 99 and my old 81 both worked perfectly fine on 5w30 synthetic (what I usually had around) or anything else. No difference between them. The 81 only failed from a catastrophic sudden stop (hit a large bolt in concrete under the weeds). It didn't smoke at that point and had about 25 years of heavy use (left unused for about 10 years in between). Originally it ran probably straight 30 changed every few years at best. I switched to synthetic twice a year changes to help extend its life. It didn't seem like it would ever wear out until I hit that bolt.
I don't know the history on my 99 but it smokes on every cold start and immediately clears up. The oil stays looking like new for a full year of use now.
Anything xw30 or xw40 would be fine in these.
84 Olds Cutlass - 350 Olds
83 Chevy Caprice - 305 Sbc
05 Silverado 1500 4wd - 4.8/4L60E
79 Honda CX500
Re: Honda GCV190 motor oil [Re: Oey12] #5430504 05/16/20 08:50 AM
O
Oey12 Offline OP
O
Great thanks...appreciate all the info. All my current vehicles use 0w20 and I would hate to waste perfectly good oil.
Re: Honda GCV190 motor oil [Re: Oey12] #5430522 05/16/20 09:06 AM
A
alex_at Offline
A
my old Briggs and Stratton ran fine on straight 30, 5W40, 5W50, 10W40, 10W50, 15W50 - not a real difference noticeable.
My new Honda GCVx 145 had Delvac conventional HDEO 15W40 for the first hour, then changed to Fuchs 15W40 conventional and will change back to Mobil HDEO 15W40. Maybe I'll try Delvac 1 5W40. Superb mower engine so far!
Re: Honda GCV190 motor oil [Re: alex_at] #5430530 05/16/20 09:21 AM
4WD Offline
Have 4000w to 7500w gens on the Delvac 1 5w40 … find them easier to pull start with 5w …
Re: Honda GCV190 motor oil [Re: Oey12] #5430535 05/16/20 09:28 AM
I
Imp4 Offline
I
It seems that with small OPE, the viscosity is nearly meaningless.
Just keep it reasonably PM'd and don't let it run low and they tend to last nearly forever.
Re: Honda GCV190 motor oil [Re: Oey12] #5430540 05/16/20 09:40 AM
H
Hombre909 Offline
H
I have a Honda GVC160 mower running Redline 5w-40.
Re: Honda GCV190 motor oil [Re: Hombre909] #5430555 05/16/20 09:56 AM
A
alex_at Offline
A
I was thinking about Motul 300V 15W50 - but then on the other hand why?
1.) It's a Honda
2.) It's not overly stressed running at 2800 or 2900 rpm mowing for 1-2 hours at the time
3.) HDEO 15W40 with enough zinc even in that aircooled engine is more than enough protection, to step it up maybe I'll use Delvac 1 5w40.
I find no difference in starting the Honda GCV at all with different oil weights, Honda's easystart one (max 2) slight pulls and it runs.
Re: Honda GCV190 motor oil [Re: Oey12] #5430620 05/16/20 11:32 AM
B
BAJA_05 Offline
B
Just went from T6 MV 5W30 to Super Tech HD SAE 30 weight in my GVC160. First pull as ALWAYS purring!!! wink
2017 VW Jetta SE TSI 1.4L Turbo (hers)
PP Euro 0W40 & FU (42K)
2008 Acura TL 3.2L PPHM 0W20 & FU (117K)
2005 Subaru Baja AWD 2.5L N/A 5spd.
T6 MV 5W30 & FU (103K)
2000 Ram 4X4 5.2L (93K) T6 MV 5W30 & FU
Re: Honda GCV190 motor oil [Re: Oey12] #5430624 05/16/20 11:40 AM
DuckRyder Offline
I’ve run 5-30EP extensively in my HRX...
It is pretty old, pretty well used and hasn’t blown up, so I wouldn’t worry about it.
Robert
  • 2019 Volkswagen Jetta R-Line
  • 1972 F100 Ranger XLT (445FE/C6/9” 3.50 Truetrac)
  • 2002 Ford Ranger XLT 4D Supercab 3.0L
Re: Honda GCV190 motor oil [Re: Oey12] #5430636 05/16/20 11:57 AM
dwendt44 Offline
Being air cooled and splash lubricated I prefer a
HDEO oil. I run Rotella 5W-40 in the push mower and
just this week got some of the new Rotella 15W-40.
Both synthetic.
My 2¢
There's no such thing as:
Too big of a battery,
Too large of a gas tank,
or too loud of a horn,
or too bright headlights.
Re: Honda GCV190 motor oil [Re: dwendt44] #5430680 05/16/20 12:59 PM
A
alex_at Offline
A
HDEO oil. ......
The GCV series isn't only splash lubricated, the internal rubber timing belt also ditributes oil. That's why they - at least unofficially told by a shop - are suitable for steep mowing without engine damage.
Re: Honda GCV190 motor oil [Re: alex_at] #5430682 05/16/20 01:02 PM
E
eljefino Offline
E
Awesome! I learned something today. Those clever engineers...
Re: Honda GCV190 motor oil [Re: Oey12] #5430750 05/16/20 03:10 PM
CT Rob Offline
Ive been running T6 5-40 in my gc160 Honda for a few years now.No issues
2017 Toyota Tundra SR5 Crewmax 4x4 Trd offroad.Inferno Orange.All stock for now....
