e-bike conversion kit
by OilUzer - 06/06/20 03:49 PM
Computer - Hypervisor - Increase I/O Performance
by brueggma1 - 06/06/20 03:30 PM
Inside of new windshield fogs up
by mclasser - 06/06/20 02:51 PM
Oil considerations Duratec 3.0 V6, 85k miles
by 97tbird - 06/06/20 02:22 PM
Best way to charge and maintain a battery?
by Avery4 - 06/06/20 02:10 PM
HM oils vs HM oils
by aquariuscsm - 06/06/20 12:37 PM
Confusion: oil grades, yellow metal, vintage
by LouK2 - 06/06/20 12:21 PM
New Rad needed Nissens vs APDI
by Bluestream - 06/06/20 11:58 AM
Oil filter cap wrench suggestions.
by RichR - 06/06/20 11:55 AM
AC Woes
by artbuc - 06/06/20 11:44 AM
Part source Canada TOTAL QUARTZ 9000 50% no tax
by Bluestream - 06/06/20 11:18 AM
Pressure washer foam gun
by Donald - 06/06/20 10:50 AM
Pentastar oil changes
by 4WD - 06/06/20 10:25 AM
Oil Pan Plug Problem
by 2015_PSD - 06/06/20 10:14 AM
Continentals out of balance
by wolf_06 - 06/06/20 10:04 AM
2017 Toyota Sienna AWD
by 92saturnsl2 - 06/06/20 09:33 AM
Wix 57045
by electricmarquis - 06/06/20 08:42 AM
VW GTI
by greenjp - 06/06/20 08:25 AM
Mower Engine Got Drenched With Oil
by viscous - 06/06/20 08:19 AM
viscous, Roamingtxn, 3Dperf, LouK2, Michael328i
71618 Registered Users
87 registered members (2015_PSD, 2010Civic, 4WD, ArrestMeRedZ, Atrocious, 11 invisible), 2,243 guests, and 103 spiders.
Topics306,301
Posts5,289,827
Members71,618
Trailer tongue "jack" question #5430448 05/16/20 07:56 AM
E
edwardh1 Offline OP
E
I did not use the trailer much last year. The trailer has a tongue jack, 1200 pound fixed fulton type (labelled cequent company ) bolt on mount. The up down movement works well, just turn the crank, no rust on the up down tube. And the wheel that is on the ground rolls fair- I think I can knock the bolt out and loosen this foot wheel up.
but
what does not work well is the swiveling left right and round and round of the forked wheel holder. It wont swivel but maybe 15 degrees. I dont think the tube that moves up and down is supposed to rotate at all- maybe the fork piece that hold the wheel is supposed to swivel. on the end of the tube? Anyone know? will a lot of de rust solution help on the foot fork that holds the wheel?
__________________
These products are all new every year?? They are a revolution!!! Razor blades, mens shirts, TVs, wiper blades, gutter guards, hearing aids... according to the ads. But also all new last year
Re: Trailer tongue "jack" question [Re: edwardh1] #5430455 05/16/20 08:01 AM
K
krismoriah72 Offline
K
hook it up to the ball, then raise the jack where you can spin the wheel freely.. it should rotate 360 (mine does).
Perhaps the bearings in the swivel are rusty? If so Perhaps lube them.
Re: Trailer tongue "jack" question [Re: edwardh1] #5430462 05/16/20 08:09 AM
B
BigCahuna Offline
B
I have a 4x8 landscape trailer that didn't have a tongue jack on it when I bought it. I went to Harbor freight and picked one up for about $20. I can push it around now with 1 finger. Best $20 I ever spent.,,
Re: Trailer tongue "jack" question [Re: edwardh1] #5430757 05/16/20 03:24 PM
Driz Offline
Somethings snagging in there. Jack it up and see. It’s a simple plastic wheel I would think with a bolt for an axle nothing more. If it’s funky or you can’t figure out or get at it to fix the issue just grab a new one......they’re cheap
Re: Trailer tongue "jack" question [Re: edwardh1] #5430797 05/16/20 04:30 PM
E
edwardh1 Offline OP
E
thanks- the wheel will rotate on its own (bolt) axle.
But should you also be able to rotate the "fork" that holds the wheel- so that the wheel points in another direction?? allowing you to move the tongue sideways??
Re: Trailer tongue "jack" question [Re: edwardh1] #5431220 05/17/20 09:20 AM
P
philipp10 Offline
P
yes the wheel should rotate. Probably rusted. Jack it up, break it loose, then lube it up.
