I upgrade my car
by miden851 - 05/30/20 12:00 AM
Ford PVD Wheels Defects
by kstanf150 - 05/29/20 07:48 PM
General thoughts on high milage oils.
by tblt44 - 05/29/20 07:09 PM
Jeep Wrangler JL
by dishdude - 05/29/20 06:43 PM
Valvoline MaxLife 5W-20
by Jackson_Slugger - 05/29/20 06:33 PM
Yamaha dry sump PWC and oil level sensitivity.
by ledslinger - 05/29/20 06:30 PM
WSS-M2C946-B1 vs WSS-M2C961-A1
by W9HDG - 05/29/20 06:16 PM
Waterfall Eco Dynamic tires
by Saabist - 05/29/20 05:55 PM
O’reilly clearance
by Gonz - 05/29/20 04:56 PM
2016 Overland Jeep Wrangler Oil/Filter
by Since1941 - 05/29/20 04:24 PM
Next Pistol Opinions
by Gebo - 05/29/20 03:28 PM
Briggs and Stratton valve clearance
by supton - 05/29/20 02:38 PM
50 cal. shell
by Donald - 05/29/20 01:52 PM
Fleet Farm Rotella T6 Sale + Shell Rebate
by shibby6600 - 05/29/20 01:26 PM
QS Ultimate Durability 5W-30
by js1956 - 05/29/20 12:51 PM
KPVD Eerily Deserted
by wings&wheels - 05/29/20 12:24 PM
BMW N55 Recommendations
by BSchmidt25 - 05/29/20 10:21 AM
dieselworks, suburbandoom, alltogether, Vig03, dstocker
71566 Registered Users
52 registered members (ArrestMeRedZ, Arcoril, 928, Black_Thunder, AZjeff, 77GrandPrix, 7 invisible), 1,473 guests, and 42 spiders.
Topics306,029
Posts5,285,221
Members71,566
Tundra Owners Chime In #5430439 05/16/20 07:43 AM
Speak2Mountain Offline OP
Q: Have you, will you have your "sealed" ATF changed out?
Just bought a 14 Tundra with 103XXX on the odo, Im ready to do it...just not sure if I NEED TO
Re: Tundra Owners Chime In [Re: Speak2Mountain] #5430447 05/16/20 07:54 AM
supton Offline
Well, how long do you want it to last? You don't NEED to if all you need is say 50k before you trade. But if you want more than that... or plan to tow heavy... it's probably way advised.
It's a pain but there are (were?) threads on Tundra forums on how to do it. I've been putting off doing the second one on mine but it wasn't that bad, just have to get enough PVC tubing (5/8"?) to feed fluid to it.
I did drop the pan on mine, and I think the worst fluid was in the bottom, where it wouldn't drain out. But the filter is a strainer and I don't think it needs replacing--if it does, or you find chunks in the pan, well, you've got other problems. I'm not sure if it's worth dropping the pan and disturbing the gasket on these trucks at all. If the magnets are fuzzy, what good is it to clean them--isn't the damage already done?
2011 Toyota Camry, base, 2.5L/6MT, 205k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 159k, ours
1999 Toyota Camry LE, 2.2L/4AT, 225k, his
Re: Tundra Owners Chime In [Re: Speak2Mountain] #5430449 05/16/20 07:57 AM
dave123 Offline
125k on my Tundra don’t know if it’s ever been done bought used. Will be doing drain and fills this spring summer spaced out. Thinking Max Life going in
Re: Tundra Owners Chime In [Re: dave123] #5430453 05/16/20 07:59 AM
supton Offline
I did Maxlife in mine. I don't think it made a difference. If the OP isn't aware, there are umpteen million pages about OEM fluids vs do-all (or universal) fluids. The OP might be well off reviewing those threads and seeing if they have enough aspirin to sort through it all--if they can hadle that, they can handle the fluid change.
Re: Tundra Owners Chime In [Re: supton] #5430461 05/16/20 08:08 AM
dave123 Offline
Right! Have done the same procedures on my 06 Tacoma always done drain fills I pump fluid in as I fined it easier.
Re: Tundra Owners Chime In [Re: Speak2Mountain] #5430484 05/16/20 08:33 AM
CT8 Offline
Sealed?
2015 F150 2.7
2018 F350 6.2
Re: Tundra Owners Chime In [Re: CT8] #5430489 05/16/20 08:38 AM
dave123 Offline
Originally Posted by CT8
Sealed?
yes sealed do you understand the definition
Re: Tundra Owners Chime In [Re: Speak2Mountain] #5430553 05/16/20 09:55 AM
cronk Offline
I don't know why people call it a "sealed" transmission.
There is a drain plug in the pan, a check plug with a standpipe in the pan, and a pull plug.
It is no more "sealed" than any other transmission. just no dipstick to check the fluid level.
I do a drain and fill every 30k in all my automatics.
2008 Ford F350
2008 Kia Spectra
2011 Nissan Quest
1986 Pontiac Trans Am
1940 Ford 9N Tractor
Amsoil lubes and filters!
Re: Tundra Owners Chime In [Re: Speak2Mountain] #5430557 05/16/20 09:57 AM
J
JeffKeryk Offline
J
Service that tranny.
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: Tundra Owners Chime In [Re: JeffKeryk] #5430563 05/16/20 10:07 AM
4WD Offline
Jeff … whilst I agree … might want to just go with trans if you don’t use the long word 😜
Re: Tundra Owners Chime In [Re: 4WD] #5430576 05/16/20 10:23 AM
J
JeffKeryk Offline
J
You don't live in the Bay Area...
2018 Lexus RX450h
2006 Acura TSX
Re: Tundra Owners Chime In [Re: Speak2Mountain] #5430625 05/16/20 11:40 AM
RW1 Offline
Owners manual recommends changing at 100K. I took my Tundra to the dealership and had them do it at 80K. Early but they had a service special at a very good price.
In the big scheme of things, it's cheap. Do it!
Re: Tundra Owners Chime In [Re: JeffKeryk] #5430670 05/16/20 12:44 PM
L
Lolvoguy Offline
L
eek
06 Lexus IS350- Wife
88 BMW 325is- Mistress
Say "no" to Turbo!
Re: Tundra Owners Chime In [Re: Speak2Mountain] #5430672 05/16/20 12:46 PM
dave1251 Offline
Do it. YouTube is your friend it's a easy job.
don't use.
Re: Tundra Owners Chime In [Re: Speak2Mountain] #5430697 05/16/20 01:25 PM
P
PowerSurge Offline
P
I’ve changed it on several. Just measure exactly what comes out and replace that amount since there is no dipstick obviously. I change it first thing in the morning when the transmission has cold soaked.
1993 Porsche 964, 2001 Ford SVT F-150 Lightning, 2004 Chevrolet Corvette, 2018 Toyota Tundra and a few others
