Left Hand Drillbits
by Snagglefoot - 05/25/20 10:32 PM
Turtle Wax Ice Spray Wax use tips.
by JimPghPA - 05/25/20 08:53 PM
Best oil on the market?
by sloinker - 05/25/20 08:47 PM
Xfinity Race in Charlotte
by kstanf150 - 05/25/20 08:12 PM
Purolator PBL14610 C&P
by FordBroncoVWJeta - 05/25/20 08:00 PM
Carquest Blue 85522 C&P
by FordBroncoVWJeta - 05/25/20 07:52 PM
2020 RAV4 Hybrid - oil options
by CELICA_XX - 05/25/20 07:44 PM
any battery charger/repair that can fix sulfation?
by apollo18 - 05/25/20 07:28 PM
Need Mice Advice
by Mr_Luke - 05/25/20 07:01 PM
pressure washer air compressor oil
by bedwards - 05/25/20 06:49 PM
2014 Elantra delayed shift 4th to 5th
by Propflux01 - 05/25/20 05:51 PM
2002 Ranger Electrical Weirdness (GEM, RAP?)
by DuckRyder - 05/25/20 05:47 PM
Oil change problems
by philipp10 - 05/25/20 05:41 PM
Denso 150 3024
by thrace - 05/25/20 04:58 PM
does ac delco warranty the replacement battery?
by apollo18 - 05/25/20 04:39 PM
Water drainage issue
by Paul_Siu - 05/25/20 04:39 PM
13 Corolla PCV
by AJB0009 - 05/25/20 04:24 PM
SpaceX Launch - Wednesday
by MasterSolenoid - 05/25/20 04:15 PM
mikespine, Typerguy, showtyme1958, rickyradit, YogiTheCat
71528 Registered Users
32 registered members (bachman, ABCarr, ammolab, AndyB, Avery4, 3 invisible), 1,459 guests, and 55 spiders.
Topics305,878
Posts5,281,953
Members71,528
Page 1 of 4 1 2 3 4
Another wheel hub assembly brand. #5430413 05/16/20 06:50 AM
M
Micahmcmeen Offline OP
M
I was reccomend Timken a few months back. I bought to and replaced both my front bearings. After a month one of them went bad. Out of good faith a bought another and this one didn't even wait a full day to start sounding like a jet. Any other decent brands out there? I was thinking about moog or mevotech. (Side note: both were made in China.)
Re: Another wheel hub assembly brand. [Re: Micahmcmeen] #5430416 05/16/20 06:55 AM
I
Imp4 Offline
I
I've had good luck with Timken and SKF over the years and I've never had to re-replace a bearing.
Have you ever considered that it might be your installation technique?
Re: Another wheel hub assembly brand. [Re: Micahmcmeen] #5430417 05/16/20 06:57 AM
DuckRyder Offline
Agree SKF if Timken not good.
What car? What is the OE?
Robert
  • 2019 Volkswagen Jetta R-Line
  • 1972 F100 Ranger XLT (445FE/C6/9” 3.50 Truetrac)
  • 2002 Ford Ranger XLT 4D Supercab 3.0L
Re: Another wheel hub assembly brand. [Re: Micahmcmeen] #5430421 05/16/20 07:04 AM
M
M
this is a 2010 jeep commander 3.7. I severely doubt i am putting it on wrong. Other side works just fine. Everything is in place correctly and torqued to spec.
Re: Another wheel hub assembly brand. [Re: Micahmcmeen] #5430426 05/16/20 07:18 AM
H
HangFire Offline
H
I put a Timken hub on my 01 Dakota a year ago, no problems yet. It had the same markings as the hub I took off, supposedly they are/were the OEM.
Are you sure it's the hub, and not brakes?
Various musings: http://hangfire.net
Re: Another wheel hub assembly brand. [Re: HangFire] #5430432 05/16/20 07:30 AM
M
M
I just replaced the caliper mounting bracket and pins a few months before that. The pins are still freely moving so I doubt it. When I put the new one on it was quieter for a short time. Definitely the hub.
Re: Another wheel hub assembly brand. [Re: Micahmcmeen] #5430433 05/16/20 07:33 AM
cronk Offline
Timken, SKF (also sold as napas premium line) or oem are going to be the best you are going to get.
I know the Autovalue stores sell Moog as their better line, I believe with a 3 year warranty, they are still made in china, so I'm not really confident enough to try them.
Mevotech is usually low end china stuff, so id scratch that off your list.
It does seem strange that you had 2 timkens fail so quickly. Are you sure you have tge proper torque spec on the axle nut?
I typically get similar life from a Timken bearing as oem.
2008 Ford F350
2008 Kia Spectra
2011 Nissan Quest
1986 Pontiac Trans Am
1940 Ford 9N Tractor
Amsoil lubes and filters!
Re: Another wheel hub assembly brand. [Re: Micahmcmeen] #5430436 05/16/20 07:39 AM
Delta Offline
I'll also chime in it's odd the Timken failed real quick. The Timken rear wheel bearing assembly that I bought for my Tacoma even has the OEM Koyo bearing in it. The rest of the assembly is supposedly USA made. Where did you get your bearing? Possibly a China knock-off? That said, you might have to go with SKF's or possibly even a Mopar unit.
'17 VW GTI 2.0T - 6MT - 21K - Motul X-Cess 5w40
'15 Camry SE - 2.5 - 26K - Edge 0w20
'09 Tacoma TRD Offroad 4x4 - 4.0 - 141K - RGT 5w30
Re: Another wheel hub assembly brand. [Re: Micahmcmeen] #5430440 05/16/20 07:45 AM
V
vwmaniaman Offline
V
I bought a Timken hub assembly for a Chrysler T&C and it failed in less than a month. Made in China. From AAp, took it back and got refund. Ordered one off RA that was China too, but worked fine. Very spotty quality from China it seems.
Don't waste your time on a slipshod repair.
Re: Another wheel hub assembly brand. [Re: Micahmcmeen] #5430452 05/16/20 07:58 AM
P
pbm Offline
P
I put Mevotach 'Supreme' sway end links on my daughters Elantra and now have to replace them after a couple of years due to clunking...
They were made in China. I was very happy to see that the Moog's that I just purchased from RA are made in Mexico. I think that most
Chinese products are J-U-N-K but I do realize that it's all about money....
'Journalism is Dead'
Re: Another wheel hub assembly brand. [Re: Micahmcmeen] #5430508 05/16/20 08:54 AM
M
M
It was torqued to 100ft pounds. The timken i put on that still works wasn't from China. I can't remember were it was from but I do remember noticing that they were both from different countries. Another side note: I'm not one that believes all Chinese stuff is junk. I have received a good amount of stuff from there that I would deem as quality. However in this case it seems to be junk.
Re: Another wheel hub assembly brand. [Re: Micahmcmeen] #5430550 05/16/20 09:48 AM
Dave9 Offline
What vehicle? 100 ft-lbs seems a bit lower than ?? the average vehicle, and a lot lower than some. I mean for the axle nut.
I've had acceptable life from some Chinese parts, but don't want Chinese bearings. Throw a good bearing in a Chinese hub and maybe it'll be okay.
Re: Another wheel hub assembly brand. [Re: Dave9] #5430565 05/16/20 10:07 AM
L
Lubener Offline
L
Torque does seem very low. I have had 180 ft lbs on a Chrysler to 250 ft lbs on a Mercury.
The "thinking" man's friend.
Re: Another wheel hub assembly brand. [Re: Micahmcmeen] #5430600 05/16/20 10:58 AM
slacktide_bitog Offline
Rock Auto has the Mopar hubs smile
Re: Another wheel hub assembly brand. [Re: Lubener] #5430608 05/16/20 11:16 AM
M
M
You're more than welcome to look it up. Vehicle is stated above.
Page 1 of 4 1 2 3 4
