Tire Mobility Kits
by wings&wheels - 06/02/20 12:06 PM
Worst accident you've witnessed
by Dave Sherman - 06/02/20 12:04 PM
Shock Fluid
by splinter - 06/02/20 11:21 AM
Michelin X-Ice 4 North for Canada ...
by odie - 06/02/20 11:03 AM
Rockauto code expires 8/2
by gallydif - 06/02/20 08:19 AM
The worst job you ever had?
by Chris142 - 06/02/20 08:04 AM
P218F on my Ford PSD
by Donald - 06/02/20 06:34 AM
Kudos to Griot's
by Egg_Head - 06/02/20 05:43 AM
Exide Battery files for bankruptcy
by Randol - 06/02/20 04:34 AM
Just one more wax question.
by rrretiree7 - 06/02/20 01:49 AM
Removing stuck bolts- interesting technique
by rubberchicken - 06/02/20 12:47 AM
Unless it is a misprint?
by 340_Magnum - 06/01/20 10:25 PM
Raymond Weil 5590 Watch Battery Replacement
by maverickfhs - 06/01/20 09:22 PM
Echo SRM 230 idling high
by CDX825 - 06/01/20 08:40 PM
Walmart in Canada closing Lube and Tire Express
by Snagglefoot - 06/01/20 08:26 PM
2012 Sonic - LCA puck bushing
by Number_35 - 06/01/20 06:44 PM
Rotate mags?
by marine65 - 06/01/20 06:40 PM
NewMex, RandyN11049, bbrtuning, chapys, DaaBoss
71593 Registered Users
84 registered members (ABN_CBT_ENGR, 2015_PSD, 14Accent, 87sammy, 86cutlass307, 69GTX, 4 invisible), 2,269 guests, and 56 spiders.
Topics306,057
Posts5,286,600
Members71,593
AMSOIL 75w140 Require LS Additive? ๐Ÿค” #5430318 05/15/20 11:05 PM
SavagePatch Offline OP
Does Amsoil Severe Gear 75w140 require the addition of a Limited Slip additive?
Specifically asking for a 2015 Ram 1500 w/ LS rear diff.
Re: AMSOIL 75w140 Require LS Additive? ๐Ÿค” [Re: SavagePatch] #5430322 05/15/20 11:17 PM
Btw... is @Pablo still active?
I remember him saying in the past that it wasn't necessarily needed and to run it straight. Then, if you hear chatter to add some. But, in most cases a LS additive wasn't needed.
Re: AMSOIL 75w140 Require LS Additive? ๐Ÿค” [Re: SavagePatch] #5430327 05/15/20 11:35 PM
U
UG_Passat Offline
U
https://www.amsoil.com/p/slip-lock-adatb/
AMSOIL Slip Lock Differential Additive is formulated for use with both synthetic and petroleum gear lubricants and safely replaces manufacturer-recommended friction modifiers. Its convenient squeeze-tube packaging provides quick and easy application to the gear housing. One four-ounce tube of Slip Lock treats differential capacities of two to four quarts. It is not for use in automatic transmissions or other applications requiring automatic transmission fluid.
NOTE: AMSOIL synthetic gear lubes do not require this additive. However, not all differentials respond the same and the addition of AMSOIL Slip Lock will eliminate chatter in mechanically sound differentials.
https://www.amsoil.com/p/severe-gear-75w-140-svo/
AMSOIL SEVERE GEAR is compatible with most limited-slip differentials. For applications that require additional limited-slip friction modifier, add AMSOIL Slip Lockยฎ.
2016 VW Tiguan|APR Stage 1|Neuspeed P-Flo|Osram CBI|Redline 5w30
Re: AMSOIL 75w140 Require LS Additive? ๐Ÿค” [Re: UG_Passat] #5430330 05/15/20 11:49 PM
@UG_Passat Thanks! I looked at their site but didn't see that. ๐Ÿ˜‰
Re: AMSOIL 75w140 Require LS Additive? ๐Ÿค” [Re: SavagePatch] #5430473 05/16/20 08:21 AM
K
kstanf150 Offline
K
Used ASG 75W/140 in my Mustang and sonโ€™s F150
Both needed a small bottle of LS additive
Had more chatter in the F150 than the Mustang, but one bottle was the cure. So might was well add it from the beginning and youโ€™ll be good to go
Re: AMSOIL 75w140 Require LS Additive? ๐Ÿค” [Re: SavagePatch] #5431125 05/17/20 07:02 AM
cronk Offline
As others have posted, Severe gear has the additive in it, but some applications may require more than the standard amount that Amsoil blends in.
My F350 limited slip seems happy with Severe gear without any additional additive.
2008 Ford F350
2008 Kia Spectra
2011 Nissan Quest
1986 Pontiac Trans Am
1940 Ford 9N Tractor
Amsoil lubes and filters!
Re: AMSOIL 75w140 Require LS Additive? ๐Ÿค” [Re: SavagePatch] #5431715 05/17/20 05:49 PM
B
Bighorn2500 Offline
B
Iโ€™m running SG75w110 in my Ram 2500 diesel rear end with LSD and no additional additive. Runs fine no issues.
I used to run RP75w140 In my Ram 1500 with no additional additive either without issues.
Most FS gear oils have some sort of LS additive already in it, even Wally World Supertech FS contains it.
2012 Ram 2500 SLT 6.7L Cummins 4x4
2018 Dodge Durango GT 3.6L 4x4
Re: AMSOIL 75w140 Require LS Additive? ๐Ÿค” [Re: SavagePatch] #5432224 05/18/20 10:07 AM
I ended up buying a bottle of Redline Limited Slip additive and using the entire 4oz with 2.5qts of the Amsoil Severe Gear 75w140.
I would have used the Amsoil LS additive if I could have found it locally and not only online. I'm sure mixing is fine but I prefer to keep things the same.
Re: AMSOIL 75w140 Require LS Additive? ๐Ÿค” [Re: SavagePatch] #5432257 05/18/20 10:44 AM
Amsoil says to use a Limited Slip additive for my specific vehicle.
Re: AMSOIL 75w140 Require LS Additive? ๐Ÿค” [Re: SavagePatch] #5432300 05/18/20 11:55 AM
K
kstanf150 Offline
K
Mixing is perfectly ok
I used Ford Racing LS additive, both vehicles working just fine
Re: AMSOIL 75w140 Require LS Additive? ๐Ÿค” [Re: SavagePatch] #5432846 05/18/20 09:26 PM
GumbyJarvis Offline
I switched out FF on my Ram 1500 at 15k miles to Synpower 75w140. Didnt need an additive and has worked fine for me
2018 Ram 1500 5.7L SLT
Group 7 V2222 - Mobil 1 Truck & SUV 5w30
Re: AMSOIL 75w140 Require LS Additive? ๐Ÿค” [Re: GumbyJarvis] #5432849 05/18/20 09:29 PM
4WD Online Confused
Online Confused
I put that Valvoline in the Charger โ€ฆ it was $12/quart whereas M1 was $20
(big price spread between M1 90 & 140)
Re: AMSOIL 75w140 Require LS Additive? ๐Ÿค” [Re: SavagePatch] #5433692 05/19/20 08:42 PM
Response from Amsoil after inquiring about LS addives:
Re: AMSOIL 75w140 Require LS Additive? ๐Ÿค” [Re: SavagePatch] #5433702 05/19/20 08:56 PM
K
kstanf150 Offline
K
Not so for everyone
Iโ€™ve bought Amsoil Gear Oil
Always needed FM
But to each there own
