KIA TYPE 4 (M) ATF
by flinter - 05/28/20 08:49 PM
My new Henry 22 Magnum rifle
by tig1 - 05/28/20 08:45 PM
Mobil 1 M-102 for 3 6000km oil changes?
by pktrkt - 05/28/20 08:33 PM
1/2 75W-90 1/2 75W-110 Can you mix equal parts
by jrommelt - 05/28/20 08:22 PM
Mazda b4000 to the junkyard
by HyundaiAbuser - 05/28/20 08:20 PM
2017 RAM 2500 6.4 Hemi AMSoil and PUP
by Gondul - 05/28/20 07:50 PM
Nail in tire, what would you do?
by Brybo86 - 05/28/20 07:44 PM
Any decent lap tops for $200.00 or less?
by BAJA_05 - 05/28/20 06:49 PM
New PW with Honda 190 engine - Ethanol treatment?
by DirtyApe - 05/28/20 06:38 PM
What size tube should a 110/50-6.5 Tire use?
by taztheman - 05/28/20 06:14 PM
C&P Allison Transmission Filter - 27k miles, 3 years
by shibby6600 - 05/28/20 05:51 PM
XG9100 - 7k miles - 9 months - filter magnet
by shibby6600 - 05/28/20 05:47 PM
2017 Audi A4 PCV Valve replacement
by dbias - 05/28/20 05:23 PM
Audi E-Tron Technik
by OVERKILL - 05/28/20 05:12 PM
Deer 1....My Avalon 0
by ZZman - 05/28/20 03:21 PM
Auto Dealers Supplies?
by cknight49090 - 05/28/20 03:09 PM
interesting video reg vs premium
by raaizin - 05/28/20 02:55 PM
Discount Tire Direct FLASH SALE
by Mr Nice - 05/28/20 02:42 PM
2021 Acura TLX Sports
by buster - 05/28/20 01:36 PM
Kboggs, oldcodger, cwllams1, Danwrig, DanielR
71558 Registered Users
96 registered members (830Lee, agarb, 4WD, aquariuscsm, AndyB, Alfred_B, 9 invisible), 2,157 guests, and 48 spiders.
Topics305,997
Posts5,284,338
Members71,558
Holy viscosity index #5430129 05/15/20 06:23 PM
J
Jimmy_Russells Offline OP
J
Oil change due on my sister's Mini. Local supplier recently started stocking Total Ineo Dynamics 0w20, LL-17FE+
[Linked Image from i.imgur.com]
http://catalog.lubricants.total.com/en/products/fs7-1/QUARTZ-INEO-DYNAMICS-0W-20
Re: Holy viscosity index [Re: Jimmy_Russells] #5430204 05/15/20 08:02 PM
R
Rand Online Content
Online Content
R
That is high but not abnormally so.. the question is what compromises(if any) were included to get it that high.
Re: Holy viscosity index [Re: Jimmy_Russells] #5430207 05/15/20 08:13 PM
Shannow Offline
There's a few 0W-20s in that park...
If it's the truth....it can handle the pressure !!!
Re: Holy viscosity index [Re: Jimmy_Russells] #5430294 05/15/20 10:01 PM
T
tundraotto Offline
T
highest I have seen.....not that I have actively searched...but seems a lot higher than the ones I have seen....What are the other ones over 200?
Re: Holy viscosity index [Re: Jimmy_Russells] #5430420 05/16/20 07:03 AM
G
Gokhan Offline
G
This is actually an interesting oil.
ACEA C5 oils tend to be low-VI oils, as opposed to Japanese-OEM oils, which tend to be ultra-high-VI oils, as wear protection (thick base oil) is the priority for the former and fuel economy (lower viscosity in a wider range of temperature and a wider range of temporary shear) for the latter.
Therefore, I ran my calculator to have an idea of what is going on.
>> Estimated base-oil viscosity @ 150 °C (BO DV150) and VII content of selected oils <<
It went nicely right above the TGMO 0W-20. wink
It turns out that this oil actually has only a moderate amount of VII content, and the ultra-high viscosity index (VI) is thanks to the very high VI of the base oil, which must be a Group III+ or Group III++ etc. base oil, as the MSDS shows an almost entirely Group III(+ etc.) base oil. Moreover, the way the definition of the VI works is that for thinner oils the VII increases the VI a lot more than for thicker oils. This is because the VII typically multiplies the KV40 and KV100 approximately by the same number. As a result you need less VII to make a 0W-20 with VI = 220 than, say a 5W-30 or less VII to make a 0W-20 than a 5W-30 of the same VI in general. This is another strength of thinner oils.
The base oil is still on the thin side for a 0W-20, but not as thin as what would be expected from the ultra-high VI.
It may probably use a small amount of ester as well, as they mention polar molecules for cleaning.
2020 Toyota Prius Prime XLE plug-in hybrid, 2ZR-FXE engine, ~ 65 mpg on regular gasoline, ~ 5,000 mi
TGMO 0W-16 SN/RC Japan
OEM spin-on oil filter Japan
Re: Holy viscosity index [Re: Jimmy_Russells] #5430531 05/16/20 09:21 AM
DrDanger Offline
Well, here is one with a VI of 244 (238 in spec sheet)
Mazda 0W20>
It is a Total oil, branded Mazda original. 900ppm of moly too.
Re: Holy viscosity index [Re: Jimmy_Russells] #5433258 05/19/20 11:53 AM
J
J
I like the bottom right: More languages, open here... There aren't enough on the label already?
grin2
Re: Holy viscosity index [Re: Jimmy_Russells] #5433405 05/19/20 02:37 PM
R
racin4ds Offline
R
Yea but How's the HTHS look?
Just say NO to thin oils and M1!
05 F350 Powerstroke
05 Hyundai Tucson
'13 Passat TDi SE+Nav
Re: Holy viscosity index [Re: racin4ds] #5433444 05/19/20 03:35 PM
J
J
Prolly 'bout 2.7 or so
Re: Holy viscosity index [Re: Jimmy_Russells] #5436451 05/23/20 06:59 AM
J
js1956 Offline
J
VI is a good measure and it's pretty high in Total. But what's more important I think is how viscosity changes relative to temperature range which has big influence on oil viscosity.
For example Castrol Edge 0W-20 has lower VI (172) then Total, but @40C (43.6) and @100C (8.4) is higher on both counts.
2015 VW Golf Mk7 2dr HB Man 1.8 TSI S
