Hi - I recently bought a new utility trailer. When I popped off the rubber hub covers, I noticed they had grease fittings and were loaded with red grease. All the grease I have used in the past were a tan or black color.
Does the red color signify anything? Should I keep using red grease ? Or is it OK to mix and match greases? Who make the best red grease?
Also, how often would you recommend greasing the hubs?
Thanks in advance!
Thanks in advance!
