Inside of new windshield fogs up
by mclasser - 06/06/20 02:51 PM
Oil considerations Duratec 3.0 V6, 85k miles
by 97tbird - 06/06/20 02:22 PM
Best way to charge and maintain a battery?
by Avery4 - 06/06/20 02:10 PM
HM oils vs HM oils
by aquariuscsm - 06/06/20 12:37 PM
Confusion: oil grades, yellow metal, vintage
by LouK2 - 06/06/20 12:21 PM
New Rad needed Nissens vs APDI
by Bluestream - 06/06/20 11:58 AM
Oil filter cap wrench suggestions.
by RichR - 06/06/20 11:55 AM
AC Woes
by artbuc - 06/06/20 11:44 AM
Part source Canada TOTAL QUARTZ 9000 50% no tax
by Bluestream - 06/06/20 11:18 AM
Pressure washer foam gun
by Donald - 06/06/20 10:50 AM
Pentastar oil changes
by 4WD - 06/06/20 10:25 AM
Oil Pan Plug Problem
by 2015_PSD - 06/06/20 10:14 AM
Continentals out of balance
by wolf_06 - 06/06/20 10:04 AM
2017 Toyota Sienna AWD
by 92saturnsl2 - 06/06/20 09:33 AM
Wix 57045
by electricmarquis - 06/06/20 08:42 AM
VW GTI
by greenjp - 06/06/20 08:25 AM
Mower Engine Got Drenched With Oil
by viscous - 06/06/20 08:19 AM
Mobil 1 versus Motul for a 2020 Camry 0w16
by Amkeer - 06/06/20 05:52 AM
Slowest lap ever...but legal...
by Shannow - 06/06/20 05:15 AM
viscous, Roamingtxn, 3Dperf, LouK2, Michael328i
71618 Registered Users
76 registered members (aquariuscsm, Atrocious, 2015_PSD, 4WD, Avery4, 5 invisible), 2,260 guests, and 74 spiders.
Topics306,299
Posts5,289,802
Members71,618
3/16 inch double flaring tool #5429944 05/15/20 02:20 PM
Snagglefoot Offline OP
I’ll hope to try out this flaring tool this weekend. Special purpose but it’s what I need. Anyone use one?
If you want the job done right......do it yourself.
Re: 3/16 inch double flaring tool [Re: Snagglefoot] #5429948 05/15/20 02:33 PM
K
Kestas Offline
Global Moderator
Global Moderator
K
40 years ago I bought my double flaring kit that does all the different sizes. For all the time I've had it and all the jobs I've done, I think I only used the two common sizes for brake lines and fuel lines.
Re: 3/16 inch double flaring tool [Re: Snagglefoot] #5430033 05/15/20 04:29 PM
E
eljefino Offline
E
Not that one in particular but a similar setup.
Make sure you get nice square cuts. Filing the end helps. I run a 1/8" drill bit down the inside of the line to clean them up.
And of course remember to slide the line nuts over before you make the flare, or you're stuck!
For a real set of giggles, do them under the car with the existing line while brake fluid slowly trickles out.
Re: 3/16 inch double flaring tool [Re: Snagglefoot] #5430155 05/15/20 06:58 PM
1
14Accent Offline
1
Off topic, but did anyone notice the sticker on the Die Lubricant? "Not safe for consumption". Um.... thanks?
Anyways, good luck on the job. I absolutely detest making lines, and I'm decently good at it. It's just a pain no matter what, especially on-car.
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
1980 Honda CB900C - 15k mile cream puff
Re: 3/16 inch double flaring tool [Re: 14Accent] #5430180 05/15/20 07:26 PM
Driz Offline
Quote
Brother you said a mouthful . Those things just plain SUCK.
Re: 3/16 inch double flaring tool [Re: Snagglefoot] #5430220 05/15/20 08:27 PM
CT8 Online Content
Online Content
Used them often at work. Don't for get the nut before you flare,,, I hate when that happens.
2015 F150 2.7
2018 F350 6.2
Re: 3/16 inch double flaring tool [Re: Snagglefoot] #5430305 05/15/20 10:40 PM
clinebarger Offline
3/16" is the toughest flare to get perfect. After cutting the line I file the tubing flush, Then run a Snap-on awl down it's throat. Then I oil the die before running it down.
I have Blue Point & Imperial double flare kits & both work well with the above prep.
Don't live in the rust belt, So bending & flaring lines isn't something we do on daily drivers. My experience comes from building cars from the ground up & doing disc brake conversions. I prefer doing single flare AN/JIC seamless stainless but it's so expensive only high-end jobs got that treatment.
2001 Chevy Camaro L92/4L80E
Re: 3/16 inch double flaring tool [Re: Snagglefoot] #5430427 05/16/20 07:20 AM
H
HangFire Offline
H
Before you start the job, make sure the vehicle has double flare ends, and not ISO "Bubble" end flares. Not many still use double flare.
Various musings: http://hangfire.net
