Forums Migration
Please read this thread
2002 Silverado sold in less than 24hrs
by Rat407 - 07/08/20 05:18 AM
2017 CR-V Next Oil
by Ruby2013Elantra - 07/08/20 02:31 AM
Silver Windshield Sun Shades
by rrretiree7 - 07/08/20 02:04 AM
Castrol Edge PIck-Up
by Gene K - 07/08/20 01:51 AM
Safety kleen seals.
by Chris142 - 07/07/20 10:58 PM
I do a full detail everything 2 or 3 years.
by SLO_Town - 07/07/20 09:59 PM
Oil Recommendation 2020 GR Supra
by afree - 07/07/20 09:51 PM
I need to drive it more...
by SLO_Town - 07/07/20 09:43 PM
Pennzoil
by BlueOvalFitter - 07/07/20 09:07 PM
100k 06 Fusion 2.3
by Aichiguy - 07/07/20 08:13 PM
CHINA
by buster - 07/07/20 07:52 PM
Darker varnish spot on rocker arm
by Spetz - 07/07/20 07:29 PM
AC Delco Dexron VI $18.76 a Gallon Amazon
by Matt1980 - 07/07/20 07:17 PM
ALS labs change in fuel dilution test
by LotI - 07/07/20 06:50 PM
Archery high tech
by CourierDriver - 07/07/20 06:42 PM
Odd filter issue
by fatrap314 - 07/07/20 06:33 PM
Lexus IS 350 AWD 2016 0W-20
by hotp4nts182 - 07/07/20 06:14 PM
Duh-- Didn't know there was a SIM card.
by csandste - 07/07/20 03:54 PM
fatrap314, hotp4nts182, LeslieX, Mayuraj, thexeve
71876 Registered Users
44 registered members (AZjeff, alarmguy, 1960Elco, 4WD, 53' Stude, 5 invisible), 741 guests, and 36 spiders.
Topics307,585
Posts5,313,600
Members71,876
Red Grease? #5429747 05/15/20 09:30 AM
R
RichardZ Offline OP
R
Hi - I recently bought a new utility trailer. When I popped off the rubber hub covers, I noticed they had grease fittings and were loaded with red grease. All the grease I have used in the past were a tan or black color.
Does the red color signify anything? Should I keep using red grease ? Or is it OK to mix and match greases? Who make the best red grease?
Also, how often would you recommend greasing the hubs?
Thanks in advance!
Re: Red Grease? [Re: RichardZ] #5429751 05/15/20 09:40 AM
B
Blkstanger Offline
B
Lucas makes a red tacky wheel bearing grease. It's pretty good stuff.
99 Jeep WJ 4.7 205,000mi. Maxlife 10w30, Fram Ultra.
15 Ford Escape S 2.5, 81,000mi. Castrol Edge 5w30 Fram Ultra.
Re: Red Grease? [Re: RichardZ] #5429758 05/15/20 09:49 AM
ABN_CBT_ENGR Offline
Thanks in advance!
Red (the dye) is chosen by the manufacturer and is meaningless unless you happen to be colorblind
Mixing is OK provided you follow the tables ( all over the net and here) and don't mix certain types of thickeners and additives. Its always "best practice" to mechanically clean but not mandatory
No such thing as "best" grease- just volumes of individual opinions. Any grease that meets the requirements of your specific application is "best"
How often depends on your individual driving and loads for the trailer but in general low payload use under say 500 miles and not immersing- an annual repack should be more than adequate for a homeowner.
Re: Red Grease? [Re: RichardZ] #5429769 05/15/20 10:03 AM
6
64bawagon Offline
6
I have used Lucas Red N tacky and an #2 lithium based EP general purpose from Lubrication engineers that were both "red"
64 Chevy wagon, 10 Jeep Wrangler, 18 Silverado 1/2 ton
Re: Red Grease? [Re: RichardZ] #5429791 05/15/20 10:42 AM
K
Kira Offline
K
I'm on a tube of MOTUL high tech red grease and I did notice it was usefully sticky.
Never knew stickiness was a feature.
Re: Red Grease? [Re: RichardZ] #5429807 05/15/20 11:09 AM
P
prs Offline
P
If all of the oil has sperated out of it and is seeping out of the seals, it is probably Mobile One Synthetic. If it looks like healthy red grease, Lucas Red'n Tacky is a common good bet. Your black grease is probably moly doped and not the best choice for wheel bearing if that theory really is true. I would use the Red'nTacky as it is available and relatively inepensive and works.
prs
Even a fish can stay out of trouble if he keeps his mouth shut.
Re: Red Grease? [Re: RichardZ] #5429937 05/15/20 02:01 PM
A
askani79705 Offline
A
Mystik JT6 High temp multi purpose
2019 Ford F150 NAPA syn 5w20 Motorcraft Filter
2000 Chevy 2500 Silverado NAPA conv 5w30 AC Delco Filter
2012 Impala MileSYN 5w30 AC Delco Filter
Re: Red Grease? [Re: askani79705] #5429946 05/15/20 02:23 PM
R
RichardZ Offline OP
R
Thanks for all the responses...I appreciate it! Ordered some Lucas Red'n Tacky and a new grease gun. smile
Re: Red Grease? [Re: RichardZ] #5430032 05/15/20 04:28 PM
V
vavavroom Offline
V
Thanks in advance!
It could be a red moly grease like Red Line Extreme Pressure Grease. It's red.
Re: Red Grease? [Re: RichardZ] #5430297 05/15/20 10:19 PM
N
njohnson Offline
N
I noticed some brands use the red color to signify high temperature grease, instead of general multi-purpose grease. The red high temperature can be used in wheel bearings with disc brakes, whereas general purpose grease is not to be used in brake disc wheel bearings. It is not made to take the heat.
Examples are Mystik JT-6 high temperature grease is red, Pennzoil had a high temperature grease, and Peak has a high temperature grease.
Re: Red Grease? [Re: RichardZ] #5430836 05/16/20 06:03 PM
O
Oildudeny Offline
O
Grease is grease.. Unless it's marine rated than its marine grease.
