e-bike conversion kit
by OilUzer - 06/06/20 03:49 PM
Computer - Hypervisor - Increase I/O Performance
by brueggma1 - 06/06/20 03:30 PM
Inside of new windshield fogs up
by mclasser - 06/06/20 02:51 PM
Oil considerations Duratec 3.0 V6, 85k miles
by 97tbird - 06/06/20 02:22 PM
Best way to charge and maintain a battery?
by Avery4 - 06/06/20 02:10 PM
HM oils vs HM oils
by aquariuscsm - 06/06/20 12:37 PM
Confusion: oil grades, yellow metal, vintage
by LouK2 - 06/06/20 12:21 PM
New Rad needed Nissens vs APDI
by Bluestream - 06/06/20 11:58 AM
Oil filter cap wrench suggestions.
by RichR - 06/06/20 11:55 AM
AC Woes
by artbuc - 06/06/20 11:44 AM
Part source Canada TOTAL QUARTZ 9000 50% no tax
by Bluestream - 06/06/20 11:18 AM
Pressure washer foam gun
by Donald - 06/06/20 10:50 AM
Pentastar oil changes
by 4WD - 06/06/20 10:25 AM
Oil Pan Plug Problem
by 2015_PSD - 06/06/20 10:14 AM
Continentals out of balance
by wolf_06 - 06/06/20 10:04 AM
2017 Toyota Sienna AWD
by 92saturnsl2 - 06/06/20 09:33 AM
Wix 57045
by electricmarquis - 06/06/20 08:42 AM
VW GTI
by greenjp - 06/06/20 08:25 AM
Mower Engine Got Drenched With Oil
by viscous - 06/06/20 08:19 AM
viscous, Roamingtxn, 3Dperf, LouK2, Michael328i
71618 Registered Users
82 registered members (2010Civic, 4WD, ArrestMeRedZ, Atrocious, Audios, 11 invisible), 2,272 guests, and 92 spiders.
Topics306,300
Posts5,289,820
Members71,618
Pennzoil ATF #5429731 05/15/20 09:13 AM
A
Averroes Offline OP
A
Hope you’re all well. Have a 370z and it asked for Dexron VI ATF for the power steering fluid. Would this be usable? I do not see the Dexron VI label and it’s making me wonder.
Synthetic or bust.
Re: Pennzoil ATF [Re: Averroes] #5429735 05/15/20 09:17 AM
J
Jimzz Offline
J
It will work fine. Its just a higher viscosity synthetic fluid. So think Dex3 viscosity but with Dex6 additives/synthetic base.
Steering systems for most cars are not that picky. Yours is a not picky one.
yup
Re: Pennzoil ATF [Re: Averroes] #5429736 05/15/20 09:18 AM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
it says on the back Dexron IIIH (which is obsolete and not licensed). That will start as a higher viscosity but may shear down.
Id get a Dex VI fluid if possible...
Re: Pennzoil ATF [Re: Jimzz] #5429738 05/15/20 09:23 AM
G
GSCJR Online Content
Online Content
G
+1
07 3.5L VQ35DE NAPA FS 5w-20 ProSelect 21358 158KM
10 3.5L 2GR-FE NAPA FS 5w-20 ProSelect 27047 180KM
Re: Pennzoil ATF [Re: Jimzz] #5429786 05/15/20 10:27 AM
A
Averroes Offline OP
A
Thanks for getting back quick I appreciate it, was in a pinch sitting in the parking lot wondering if this was good enough or not. Also, thank you to everyone else as well. I returned it none the less. It was bottled in 2015, though it wouldn’t be spoiled I wanted peace of mind on something more “fresh”.
Synthetic or bust.
Re: Pennzoil ATF [Re: Averroes] #5429857 05/15/20 12:07 PM
G
Online Content
G
I figured you were sitting at a fuel station waiting for a response because it's the only place I've seen this stuff around here. Shell?
Re: Pennzoil ATF [Re: Averroes] #5429862 05/15/20 12:13 PM
B
bbhero Offline
B
My car uses Dexron VI in the power steering pump....
I put Dexron VI in it...
I guess Dexron III could be ok??....
But I don't like playing around with stuff like this.
Nissan Altima 3.5 Coupe
Cam2 SuperproMax 5w30 Wix Gold 57356
"Treat your family like your friends and treat your friends like your family."
Re: Pennzoil ATF [Re: Averroes] #5429925 05/15/20 01:52 PM
W
WobblyElvis Offline
W
I buy and use cheap oil but it meets the spec the manufacturer calls for. I do not use a transmission fluid that does not meet spec. There is more to ATF than just viscosity and it only cost maybe another $5 to get the correct fluid and it last for years.
Re: Pennzoil ATF [Re: WobblyElvis] #5430006 05/15/20 03:41 PM
A
Averroes Offline OP
A
Actually ordered it from NAPA online, went to pick it up and got this old outdated bottle, did not match the picture or meet Dexron VI. I said [censored] no to the no and gave it back. I posted here to make sure, this site has great members and info.
I feel ya. Went and got the correct spec after returning it.
Got the correct spec shortly after returning it, went to Canadian Tire after.
Synthetic or bust.
Re: Pennzoil ATF [Re: Averroes] #5430673 05/16/20 12:50 PM
dave1251 Offline
Pennzoil actually blends a LV fluid which is MERCON LV and DEXRON VI licensed. You did right returning this.
don't use.
