I need your help picking out fireworks for a show.
by joegreen - 05/30/20 12:13 AM
Best off the shelf oil for the price
by samiamz - 05/30/20 12:09 AM
I upgrade my car
by miden851 - 05/30/20 12:00 AM
Ford PVD Wheels Defects
by kstanf150 - 05/29/20 07:48 PM
General thoughts on high milage oils.
by tblt44 - 05/29/20 07:09 PM
Jeep Wrangler JL
by dishdude - 05/29/20 06:43 PM
Valvoline MaxLife 5W-20
by Jackson_Slugger - 05/29/20 06:33 PM
Yamaha dry sump PWC and oil level sensitivity.
by ledslinger - 05/29/20 06:30 PM
WSS-M2C946-B1 vs WSS-M2C961-A1
by W9HDG - 05/29/20 06:16 PM
Waterfall Eco Dynamic tires
by Saabist - 05/29/20 05:55 PM
O’reilly clearance
by Gonz - 05/29/20 04:56 PM
2016 Overland Jeep Wrangler Oil/Filter
by Since1941 - 05/29/20 04:24 PM
Next Pistol Opinions
by Gebo - 05/29/20 03:28 PM
Briggs and Stratton valve clearance
by supton - 05/29/20 02:38 PM
50 cal. shell
by Donald - 05/29/20 01:52 PM
Fleet Farm Rotella T6 Sale + Shell Rebate
by shibby6600 - 05/29/20 01:26 PM
QS Ultimate Durability 5W-30
by js1956 - 05/29/20 12:51 PM
KPVD Eerily Deserted
by wings&wheels - 05/29/20 12:24 PM
dieselworks, suburbandoom, alltogether, Vig03, dstocker
71566 Registered Users
40 registered members (2009Caraman, Blkstanger, ArrestMeRedZ, AZjeff, blufeb95, Arcoril, 3 invisible), 1,325 guests, and 31 spiders.
Topics306,032
Posts5,285,230
Members71,566
Mobil 1 AFE 0W16 API SP #5429517 05/14/20 10:44 PM
P
painfx Offline OP
P
Mobil 1 0W16
So I believe Mobil 1 0W16 is now API SL? Looks like they changed the formula by adding additional things to it.
Buster had mention Mobil will now include Noack specs IIRC, but it does not seem like it.
Re: Mobil 1 AFE 0W16 API SP [Re: painfx] #5429520 05/14/20 11:01 PM
slacktide_bitog Online Content
Online Content
Was 0w16 even listed in the SL standards? crzy
but it does still show SN+, SN-RC, SP-RC, GF-6B, so there is no problem smile
Re: Mobil 1 AFE 0W16 API SP [Re: slacktide_bitog] #5429524 05/14/20 11:07 PM
4WD Offline
I might buy a quart of 0w16 just to see and feel it. Guess I could fill my squirt cans …
be great on hinges and bushings.
Re: Mobil 1 AFE 0W16 API SP [Re: 4WD] #5429543 05/14/20 11:41 PM
P
painfx Offline OP
P
If your vehicle does not spec for 0W16, there is no benefit in using it. Currently, some Toyotas and Hondas are spec'd for 0W16.
Re: Mobil 1 AFE 0W16 API SP [Re: slacktide_bitog] #5429544 05/14/20 11:42 PM
P
painfx Offline OP
P
API SP just came about. I have been following and looks like it just got updated to SP.
Re: Mobil 1 AFE 0W16 API SP [Re: painfx] #5429546 05/14/20 11:45 PM
4WD Offline
Oh I will not be putting it in an engine … just curious enough to want to see and touch … and then just use for misc lube.
I actually like to use motor oil for misc lube over aerosols …
Re: Mobil 1 AFE 0W16 API SP [Re: painfx] #5429547 05/14/20 11:48 PM
G
Gokhan Offline
G
Originally Posted by painfx
API SL just came about. I have been following and looks like it just got updated to SL.
All SM, SN, SN PLUS, and SP oils are automatically SL. That's because API specs are backward compatible.
However, the important thing is that it has not been updated to SP yet.
2020 Toyota Prius Prime XLE plug-in hybrid, 2ZR-FXE engine, ~ 65 mpg on regular gasoline, ~ 5,000 mi
TGMO 0W-16 SN/RC Japan
OEM spin-on oil filter Japan
Re: Mobil 1 AFE 0W16 API SP [Re: painfx] #5429548 05/14/20 11:48 PM
P
painfx Offline OP
P
Mobil 1 0W16
So I believe Mobil 1 0W16 is now API SP? Looks like they changed the formula by adding additional things to it.
Edit: Please changed title to API "SP"
Re: Mobil 1 AFE 0W16 API SP [Re: painfx] #5429551 05/14/20 11:50 PM
G
Gokhan Offline
G
Where do you see that? I don't see SP anywhere.
Re: Mobil 1 AFE 0W16 API SP [Re: painfx] #5429552 05/14/20 11:54 PM
2015_PSD Offline
Look at the PDS in the OP's link. SP is there.
2019 o)|||||(o Rubicon Wrangler Unlimited 3.6L V6 [Castrol Edge + Ultra]
2018 Mercedes Benz C300 2.0L Turbo [Pennzoil Platinum + Mann filter]
Re: Mobil 1 AFE 0W16 API SP [Re: Gokhan] #5429553 05/14/20 11:54 PM
P
painfx Offline OP
P
In this link
It is API SP certified and ILSAC GF-6B.
The formula they added additional additives/what not to it. Before the SDS would show up to 80% PAO & up to 20% GTL. Now they had 2 more additional components to the brew. You can check the SDS for more information.
Re: Mobil 1 AFE 0W16 API SP [Re: painfx] #5429559 05/15/20 12:09 AM
G
Gokhan Offline
G
In this link
OK, I see it now—they put the SP at the bottom.
Neither KV100 nor the density has changed within the given precision. The only way to know if there is a formulation change is to compare the four-digit revision numbers on the back labels of the bottles.
Those two additional components in the MSDS are nothing but the good old ZDDP. They are actually giving the exact types of the ZDDP (alcohols used in the making—pentanol, isopropanol, etc.), which is nice.
Re: Mobil 1 AFE 0W16 API SP [Re: painfx] #5429567 05/15/20 01:08 AM
B
blufeb95 Online Content
Online Content
B
Looking around it looks like most Mobil1 range has been updated to be SP but not the Euro oil, nor the high mileage oil,
Re: Mobil 1 AFE 0W16 API SP [Re: painfx] #5429568 05/15/20 01:15 AM
U
UG_Passat Offline
U
In this link
On API's database for licenses, the 0w-16 is does not have a license that is SP approved. Still SN-Plus.
But Mobil does have a bunch of products that has the SP license from API.
2016 VW Tiguan|APR Stage 1|Neuspeed P-Flo|Osram CBI|Redline 5w30
Re: Mobil 1 AFE 0W16 API SP [Re: painfx] #5429607 05/15/20 06:07 AM
B
buster Offline
B
Looks like they are in the middle of updating the EP oils. They now say 20,000 miles. Data sheets are incomplete. Their data sheets look a lot like Driven now. Very basic.
https://www.mobil.com/en/lubricants...ucts/mobil-1-extended-performance-0w-20/
*The top still says 15k but in the Features and Benefits section it now says 20,000.
So they're in the middle of updating it.
