Rockauto code expires 8/2
by gallydif - 06/02/20 08:19 AM
The worst job you ever had?
by Chris142 - 06/02/20 08:04 AM
P218F on my Ford PSD
by Donald - 06/02/20 06:34 AM
Kudos to Griot's
by Egg_Head - 06/02/20 05:43 AM
Exide Battery files for bankruptcy
by Randol - 06/02/20 04:34 AM
Just one more wax question.
by rrretiree7 - 06/02/20 01:49 AM
Removing stuck bolts- interesting technique
by rubberchicken - 06/02/20 12:47 AM
Unless it is a misprint?
by 340_Magnum - 06/01/20 10:25 PM
Raymond Weil 5590 Watch Battery Replacement
by maverickfhs - 06/01/20 09:22 PM
Echo SRM 230 idling high
by CDX825 - 06/01/20 08:40 PM
Walmart in Canada closing Lube and Tire Express
by Snagglefoot - 06/01/20 08:26 PM
2012 Sonic - LCA puck bushing
by Number_35 - 06/01/20 06:44 PM
Rotate mags?
by marine65 - 06/01/20 06:40 PM
Re-using good coolant?
by Jarpin - 06/01/20 06:21 PM
Best entry level riding mower
by UncleDave - 06/01/20 03:02 PM
2015 Pilot LX
by madRiver - 06/01/20 03:01 PM
NewMex, RandyN11049, bbrtuning, chapys, DaaBoss
71593 Registered Users
78 registered members (830Lee, 4WD, 55hambone, 555, Al, andyd, 7 invisible), 2,129 guests, and 27 spiders.
Topics306,053
Posts5,286,514
Members71,593
grease gun problems #5429319 05/14/20 05:48 PM
E
edwardh1 Offline OP
E
what next- another weird problem?
my grease gun (a big lever operated one) does not this year want to suck the grease into the pump piston. seems the grease is too thick or too viscous or maybe too dry, . kept in grage been 55 degrees at night, not used in a year.
its almost like the grease has semi solidifies.
Its evinrude johnson tripple guard grease stuff that the yamaha dealer uses on motors and on trailer wheel bearings (they were a johnson dealer since the 50s) and they use only this grease, which is a little sttiff I agree but not like this .
does grease dry out? I was sick a while back maybe grease is older than I think.
I may let the gun lay in the sun tomorrow to see if it "melts" just a little. Failing that- what- replace the "slide in cartridge?) that goes in the gun. or try to switch to a softer grease. First time this problem in 10 years
These products are all new every year?? They are a revolution!!! Razor blades, mens shirts, TVs, wiper blades, gutter guards, hearing aids... according to the ads. But also all new last year
Re: grease gun problems [Re: edwardh1] #5429325 05/14/20 05:52 PM
E
Eddie Offline
E
Mine gets air locked and the spring loaded piston won't move. I slooooooly unscrew the cap and try to get the trapped air out.
2014 CX5 Touring 2.5L :-)
Re: grease gun problems [Re: edwardh1] #5429337 05/14/20 06:10 PM
T
tc1446 Online Content
Online Content
T
I've had this trouble for years but recently, while trying to make it work with a new tube, I took a big gob of grease and put it top of head. Of course when I screwed it on quite a bit squeezed out but the gun worked! Used this tube up and did same with a new tube and that one works. Maybe this method prevents the air lock...at least I hope so.
'14 Kia Soul, 2.0L (29K)
'13 Accord EX-L 2.4L (110K) M1 & FU
'00 Ford Ranger 4.0L {69K} M1 & FU
'18 Polaris Slingshot 2.4L GM (QS & Bosch Cart.)
'07 Kioti CK-30 (Delo & Wix)
Re: grease gun problems [Re: edwardh1] #5429353 05/14/20 06:39 PM
Z
zfasts03 Online Content
Online Content
Z
I say the grease is either COLD or OLD.
I have had this happen also.
Might have to toss it and get a new tube. Been there done that!
- 03 Corvette Z06
Amsoil 5w-30 SS
- 07 Honda Accord 2.4L
Amsoil 5w-20 SS
- 16 Suburban 5.3L
Amsoil 0w-20 SS, XG10575(16-28 by-pass)
- 18 4Runner TRD Off Road
Amsoil 0w-30 SS, TRD filter
Re: grease gun problems [Re: edwardh1] #5429408 05/14/20 07:47 PM
A
alcyon Offline
A
Not meaning to hijack this thread, is there a small grease gun you guys could recommend ? I dont want those big ones.
Kyosho Optima Mid SWB, LWB and Lazer ZX
1991 Proton Saga 1.3S SOLD
1989 Toyota Soarer GT Twin Turbo L
1985 Kuwahara Survivor
1992 Robinson Pro
Re: grease gun problems [Re: edwardh1] #5429582 05/15/20 03:16 AM
F
FT92 Offline
F
had the same trouble with my grease gun I had for years...started acting up ..I tried everything to get it to work again...got so frustrated that I went to my local Walmart and bought the cheapest gun they had, the kind you put a grease cartridge in...has been working fantastic for several years now....maybe cheap is the way to go ….lol
Re: grease gun problems [Re: edwardh1] #5429623 05/15/20 06:38 AM
M
mattwithcats Offline
M
Grease guns usually come in 14 ounce or 3 ounce cartridge sizes...
The problem with the 3 ounce ones is only a few types of cartridges are available...
http://www.wilmarcorp.com/item.aspx?iid=273
2009 Smart Pure
Pennzoil Platinum Euro 0W-40, Wix XP 51356 filter, 45 mpg...
185/55R15 General HP tires, "H" speed rated, 44 psi (300 kpa)
Re: grease gun problems [Re: edwardh1] #5429666 05/15/20 07:48 AM
Snagglefoot Offline
Mystic markets the small tubes in several grades of grease.
If you want the job done right......do it yourself.
Re: grease gun problems [Re: edwardh1] #5430154 05/15/20 06:56 PM
E
edwardh1 Offline OP
E
thanks. I let it sit in warm sun and its fine now. problem was grease- several years old. I will clean it out this summer , get a new cartridge and if needed buy a new gun.
Re: grease gun problems [Re: Snagglefoot] #5431054 05/17/20 01:06 AM
Snagglefoot Offline
Re: grease gun problems [Re: Snagglefoot] #5431159 05/17/20 08:08 AM
4WD Online Confused
Online Confused
Yes … have purchased Mystik JT6 in 3 ounce three packs to carry in a truck box …
It has never separated in hot storage like that …
