Moving up to 5w30. How thick is too thick?
by BTLew81 - 06/03/20 11:15 PM
Renting UHaul Truck to Tow Your Own Trailer?
by Miller88 - 06/03/20 09:40 PM
First Oil Change Recommendation
by gtpimp - 06/03/20 09:20 PM
GM 10L80 Issues
by shimps1 - 06/03/20 08:26 PM
Brake/Carb cleaner issue.
by Jarpin - 06/03/20 07:27 PM
sharp oil pressure drop-off > 130C
by bbrtuning - 06/03/20 06:48 PM
Warranty work
by t1snwrbrdr12 - 06/03/20 06:10 PM
AC Flashing Light
by artbuc - 06/03/20 05:13 PM
Watches
by Passport1 - 06/03/20 03:57 PM
best budget tire
by VQLT - 06/03/20 03:33 PM
Castrol EDGE turns black/red FAST
by Silver - 06/03/20 03:20 PM
Our van feels "Darty" or twitchy" on the highway
by 1911CHAMPION - 06/03/20 02:55 PM
You guys who pile the miles up weekly on your ride
by Speak2Mountain - 06/03/20 02:22 PM
'19 + '20 Kicks w/C.V.T. : Any owners or know
by odie - 06/03/20 01:38 PM
Securing rubber hose to metal tubing?
by joshuawesl - 06/03/20 01:15 PM
Extremely rare Honda
by wings&wheels - 06/03/20 12:36 PM
Shuffle Dancing
by BlueOvalFitter - 06/03/20 12:19 PM
Do you practice a vegan-keto diet?
by Ed_Flecko - 06/03/20 12:08 PM
Digitizing Photos and Slides
by Snagglefoot - 06/03/20 12:04 PM
rorty, Ghosty, zmann96, yetti96, weekendwally
71602 Registered Users
55 registered members (Ag76, 10WSmuckers, bdcardinal, BlakeB, Aero540T, 3 invisible), 1,367 guests, and 28 spiders.
Topics306,113
Posts5,287,769
Members71,602
Page 1 of 5 1 2 5
Oil changed,,, wrong oil installed? #5429280 05/14/20 04:34 PM
W
widetrax Offline OP
W
Went to Mobile and got it changed there,,, last week.. in a 2019 VW Beetle convertible. The manual says to use 508 oil,, asked them about this,, they ''did not know''. However,, I did let them change it,, they said,, ''we use the same oil as a Jetta'' and a few more--- it doesn't look green at all-- neither did what came in when new. In the meantime, I have bought 6 quarts of VW 508/509 oil, plus an extractor, so I CAN swap it out-- if needed. I really don't know whether to or not,, what do y'all think? I really wonder about NOT using the 508 oil, what might happen to the motor? Will the motor blow up? Got any thoughts on this?
2019 Volkswagen convertible
2018 RX 350
2010 Nissan Frontier
Re: Oil changed,,, wrong oil installed? [Re: widetrax] #5429285 05/14/20 04:44 PM
The Critic Offline
Well, what does the receipt say?
2011 Toyota Prius 1.8L - 207K - Valvoline Premium Blue Restore 10W-30
2007 Honda Accord 2.4L - 146K - Valvoline Premium Blue Restore 10W-30
Re: Oil changed,,, wrong oil installed? [Re: widetrax] #5429290 05/14/20 04:53 PM
B
Boomer Offline
B
For warranty purposes you definitely want the 508 oil in there. There is a tracer in the oil (there may be a metal compound used as well as a dye) so the oil can be checked if there are ever any engine problems. Was this a VW dealer that changed the oil? If so, run far away from them. If it is just an oil change place, find someone else. They are incompetent. I drive two VWs, one being a 2019 Passat. I let the dealer service it as they are close by, competent and thorough. I am also too old to do it myself.
2019 VW Passat 2.0 liter gasoline DI engine, DI, 2,700 miles, Castrol Professional VW 508 0W-20
2017 VW Golf All Track 1.8 liter gas engine DI, 25,500 miles Castrol Professional VW 505 5W-40
Re: Oil changed,,, wrong oil installed? [Re: widetrax] #5429303 05/14/20 05:30 PM
H
hallstevenson Offline
H
Originally Posted by widetrax
The manual says to use 508 oil....
What is the exact wording in the manual ? Does it require this 508 spec oil or recommend it ?
Mobil 1 recommends "ESP X2 0W-20" for your car and it meets VW 508.
Not sure why you didn't walk away when they said they didn't know..... if it's really that much of a concern.
Re: Oil changed,,, wrong oil installed? [Re: widetrax] #5429304 05/14/20 05:30 PM
T
tig1 Offline
T
M1 oils will lubricate your engine very well for hundreds of thousands of miles. However the warranty may be a problem is an internal engine problem showed up. Frankly, if it were me I would leave the M1 in.
2007 Ford Fusion 258,000 miles
M1 5-20HM
2017 Ford Fusion 91K
M1 0-20EP
M1 ATF and M1 LV HP ATF
M1 10-30 in all OPE
MC filters
Re: Oil changed,,, wrong oil installed? [Re: hallstevenson] #5429309 05/14/20 05:35 PM
B
blufeb95 Offline
B
Requires, says that non 508 can only be used for upto half a quart of make up oil.
Manual
[Linked Image]
Re: Oil changed,,, wrong oil installed? [Re: widetrax] #5429314 05/14/20 05:43 PM
DuckRyder Offline
We have been over this ad nauseam...
If you went to a Mobil (the oil company) oil change facility and they did not know to use 508 you should call corporate because that facility is incompetent. It you went to Mobile (the city) where did you go, they are still incompetent.
Robert
  • 2019 Volkswagen Jetta R-Line
  • 1972 F100 Ranger XLT (445FE/C6/9” 3.50 Truetrac)
  • 2002 Ford Ranger XLT 4D Supercab 3.0L
Re: Oil changed,,, wrong oil installed? [Re: DuckRyder] #5429355 05/14/20 06:42 PM
W
widetrax Offline OP
W
The dealer is in Mobile, Ala, and a ''Porsche'', ''Audi'', and a ''Volvo'' dealer also. I had hoped they put the right stuff in there,, but,, the paperwork only says, '' We changed the oil and filter''. [ plus all the other stuff they do there ] I guess it's OK,, just questionable,, I really want to change it,,, but,,,maybe it's all right. I've already put 200 miles on it since, I guess time will tell. Anyone know what will happen if I run the wrong type of oil?
2018 RX 350
Re: Oil changed,,, wrong oil installed? [Re: widetrax] #5429363 05/14/20 06:46 PM
DuckRyder Offline
So what part number oil did they bill out... I can see a service advisor being clueless, but the tech probably isn’t... it if was a VW dealer chances are good they put the right oil in it.
Robert
Re: Oil changed,,, wrong oil installed? [Re: DuckRyder] #5429365 05/14/20 06:49 PM
T
tc1446 Offline
T
Widetrax,I have a motor in a recently purchased Audi, which also requires 508 rated oil. Until then, had never heard of 508.
Personally I would run the oil for the next 5K or so and then put in 508 0-20. Might want to double check a VW/Audi dealer to make sure they even have it in stock. The Audi Svc Tech , when I asked if they had the 508 a couple weeks ago when I bought the Audi, said they did not have it in bulk, that it was something I'd have to inquire about at Parts Dept! When it comes time for the first 10K service I'll be doing some serious inquiries.
Meanwhile, I bought some of the below and plan on doing the first change myself, around 5K or less. I have an oil evacuator (thats what the Audi dealer uses) and the filter sits on top and looks real easy to change.
You can find Castrol Edge 508 from ESC at about $8.00 qt. Not many vendors stock this oil, and even less the Mobil 1 508 that VW/Audi now recommend.
https://www.ecstuning.com/b-genuine-volkswagen-audi-parts/oil-service-kit/g052577m2kt1/
https://www.amazon.com/slp/best-oil-extractor/chagxfusm5sz83f
'14 Kia Soul, 2.0L (29K)
'13 Accord EX-L 2.4L (110K) M1 & FU
'00 Ford Ranger 4.0L {69K} M1 & FU
'18 Polaris Slingshot 2.4L GM (QS & Bosch Cart.)
'07 Kioti CK-30 (Delo & Wix)
Re: Oil changed,,, wrong oil installed? [Re: widetrax] #5429370 05/14/20 06:56 PM
Propflux01 Offline
Can someone really quick tell me what kind of fairy dust is in these oils that required their usage rather than just a recommendation? Would these oils be overkill in an 'ordinary' engine?
2014 Hyundai Elantra
2014 Hyundai Elantra GT
Re: Oil changed,,, wrong oil installed? [Re: Propflux01] #5429380 05/14/20 07:10 PM
W
widetrax Offline OP
W
That's a proper question,,, anybody know??
2018 RX 350
Re: Oil changed,,, wrong oil installed? [Re: widetrax] #5429383 05/14/20 07:15 PM
wemay Offline
It's also approved for VW/Audi/Porsche diesels.
2019 Volkswagen Passat Wolfsburg TSI: VW OE 0W-20, OE o.filter
2013 Hyundai Santa Fe Sport 2.0T: RGT 5W-30, OE o.filter
Re: Oil changed,,, wrong oil installed? [Re: widetrax] #5429386 05/14/20 07:17 PM
W
widetrax Offline OP
W
tc1446,, is that oil ''Edge'',, it is what i bought also. [ not sure, but I thought it was Mobile 1 ] I also ordered one of the extractors from Amazon too,,
2018 RX 350
Re: Oil changed,,, wrong oil installed? [Re: widetrax] #5429392 05/14/20 07:25 PM
T
tig1 Offline
T
Nothing to the engine
M1 5-20HM
M1 0-20EP
M1 10-30 in all OPE
MC filters
Page 1 of 5 1 2 5
