Ignition Wire Suggestions?
by GemStater - 05/26/20 02:22 AM
DTD Frustrating Website Change
by ctechbob - 05/26/20 02:17 AM
Calling Prius Owners
by rrretiree7 - 05/26/20 02:12 AM
Environmentally friendly gas can rant
by IMSA_Racing_Fan - 05/26/20 12:58 AM
Left Hand Drillbits
by Snagglefoot - 05/25/20 10:32 PM
Turtle Wax Ice Spray Wax use tips.
by JimPghPA - 05/25/20 08:53 PM
Best oil on the market?
by sloinker - 05/25/20 08:47 PM
Xfinity Race in Charlotte
by kstanf150 - 05/25/20 08:12 PM
Purolator PBL14610 C&P
by FordBroncoVWJeta - 05/25/20 08:00 PM
Carquest Blue 85522 C&P
by FordBroncoVWJeta - 05/25/20 07:52 PM
2020 RAV4 Hybrid - oil options
by CELICA_XX - 05/25/20 07:44 PM
any battery charger/repair that can fix sulfation?
by apollo18 - 05/25/20 07:28 PM
Need Mice Advice
by Mr_Luke - 05/25/20 07:01 PM
pressure washer air compressor oil
by bedwards - 05/25/20 06:49 PM
2014 Elantra delayed shift 4th to 5th
by Propflux01 - 05/25/20 05:51 PM
2002 Ranger Electrical Weirdness (GEM, RAP?)
by DuckRyder - 05/25/20 05:47 PM
Oil change problems
by philipp10 - 05/25/20 05:41 PM
Denso 150 3024
by thrace - 05/25/20 04:58 PM
mikespine, Typerguy, showtyme1958, rickyradit, YogiTheCat
71528 Registered Users
19 registered members (Bjornviken, bworley, bachman, CaspianM, 2 invisible), 1,203 guests, and 39 spiders.
Topics305,882
Posts5,281,968
Members71,528
Fuel consumption..... #5429259 05/14/20 04:13 PM
2
2K2AcuraTL Offline OP
2
Colleagues... if anyone has taken any kind of data,
I wish to compare notes in regards to how much fuel you burn for 20-30 mins of run time..
Specs.... bought second hand - 2015 Husq YTH24K48 - with a Kholer 7000 series K735 twin... as of today, it has a total of 60 hours on the meter.
The carb on this unit already has issues.. i suspect float / needle problems, as i have serious gas in the crankcase issues. ive done 3 OCI just to try and clear the crankcase.
I have installed a extra fuel valve before the fuel pump as a band-air solution for the time being. I am unable to find aftermarket carbs for this engine ..yet. and again after today the oil smells like fuel. The engine starts just fine and runs just dandy...... no smoke.. etc
I plan to do just a simple carb swap and fix the gas flowing to crankcase issue, as soon as I can find one......
now.. this aside... i used the tractor today for say.... 20 mins in total .. did 4 trips to back of the property to dispose of spring lawn raking. - blades were not engaged at anytime..
I burned 2 full liters [ or half a gallon if you like..] ... of fuel..!!!! im running 91 octane - E0 gas.
to me that seems excessive...!?!?!??!?!?
any input appreciated
Cheers
J
2002 Acura TL-P --- 2013 Acura MDX-Elite --- 2008 Civic
ALL on PP and PP Ultra & Petro-Can Duradrive synth ATF
2007 Chev Trailblazer LT
1998 Pontiac Transsport
1984 Firebird SE
Re: Fuel consumption..... [Re: 2K2AcuraTL] #5429318 05/14/20 05:46 PM
J
JTK Offline
J
From what I've experienced with OHV V-twins is they burn about a gallon of fuel per hour under light use. More under moderate/heavy usage.
Your usage does seem excessive. I'd see if it repeats.
2019 Nissan Pathfinder SV
2017 Ram 1500 4x4, 3.6L.
2015 Nissan Versa 1.6 S
Re: Fuel consumption..... [Re: 2K2AcuraTL] #5429330 05/14/20 05:58 PM
E
Eddie Offline
E
My B&S 20HP twin uses approximately one gallon during a 45 minute mowing at full throttle. I would suspect a stuck or sticking carburetor float. Buy a new carb on line. Ed
2014 CX5 Touring 2.5L :-)
Re: Fuel consumption..... [Re: 2K2AcuraTL] #5429343 05/14/20 06:21 PM
I
IndyIan Offline
I
Do you have a shut off valve? My very used rider wouldn't stop the carb from overfilling and running quite rich, but I just crack open the shut off valve and it seems to meter closer to the right amount of gas. The odd time I'll be in heavy heavy grass and it will let the mower run lean but that doesn't seem to matter much.
06 Focus ZXW, 5spd manual, 220km
18 Outback 2.5 CVT 35km 0W20
Re: Fuel consumption..... [Re: JTK] #5429433 05/14/20 08:21 PM
2
2
hmmm ok or half a gallon on 30 mins...for -light use-... ok im a little above that... thx
1984 Firebird SE
Re: Fuel consumption..... [Re: Eddie] #5429435 05/14/20 08:23 PM
2
2
right ..or half a gallon for 20-25 minutes... that puts me on par with you...
yes.. thats my plan... but the dealer sells OEM carbs for $250+.... nope not going there... need an amazon solution.. LOL
1984 Firebird SE
Re: Fuel consumption..... [Re: IndyIan] #5429436 05/14/20 08:26 PM
2
2
yes.. shut off valve installed... thx
i dont have a rich mixture issue i dont believe...... the engine runs fine... will monitor the performance.. thx
1984 Firebird SE
Re: Fuel consumption..... [Re: 2K2AcuraTL] #5429490 05/14/20 09:54 PM
A
Astro_Guy Offline
A
My 22 HP 724 cc Briggs V-Twin burns about a gallon an hour with the blades engaged in moderately heavy grass. This year we are off to a cool start, mowing perhaps the top inch at a time, and fuel consumption is lower. Both your time and fuel consumption will be lowered by mowing more often. That may seem counter-intuitive, but try it and see.
'01 Volvo V70XC, 253k, 5W-30 M1 EP
'16 Accord, 50k, 0W-20 M1 EP
Re: Fuel consumption..... [Re: 2K2AcuraTL] #5429604 05/15/20 05:55 AM
R
Rob_Roy Offline
R
See if there is a rebuild kit available for that carb. It probably only needs a good cleaning and new needle/seat.
My 30hp Kawi burns about 1.6 gallons per hour mowing with a 72" deck.
2016 Ford Expedition EL Platinum
2016 Ford Expedition XLT
1999 Ford F350, V10
Re: Fuel consumption..... [Re: Astro_Guy] #5429844 05/15/20 11:56 AM
2
2
yes.. i can see your logic here... I may not be able to put this to the test if we get another hot.dry summer..
thx
1984 Firebird SE
Re: Fuel consumption..... [Re: Rob_Roy] #5429849 05/15/20 11:58 AM
2
2
Indeed.. it maybe something simple, but i havent found any carbs or repair kits..
and I forgot to mention at the beginning .. its 24hp on a 48" deck
1984 Firebird SE
