ATF Flush vs Drain and Fill
by diyjake - 06/01/20 11:24 AM
Is Your Vehicle Deadly?
by SubLGT - 06/01/20 11:02 AM
Question on the bottom of bottle with Penz Platinum
by babyivan - 06/01/20 10:55 AM
Used Mitsubishi Lancer prices
by 97prizm - 06/01/20 10:32 AM
Which oil is the better quality
by galaxy333 - 06/01/20 09:57 AM
"Boutique" Brands
by buster - 06/01/20 09:15 AM
CASTROL Edge 5w20 or EP 5w20
by 53' Stude - 06/01/20 09:09 AM
BT Oil
by js1956 - 06/01/20 09:00 AM
How to Properly Read a Dipstick
by Gebo - 06/01/20 07:59 AM
Why did some older cars have + grounded systems?
by JLawrence08648 - 06/01/20 07:39 AM
Goodwood Racing
by AZjeff - 05/31/20 10:23 PM
Blackstone Lab Question
by klt1986 - 05/31/20 08:19 PM
Fram oil filters at Advance Auto
by Electromotive - 05/31/20 08:02 PM
The Last Coat 2?
by tbm5690 - 05/31/20 07:33 PM
Can a car have too much battery?
by wings&wheels - 05/31/20 07:13 PM
Oil Extractor Pump Problem
by tc1446 - 05/31/20 07:11 PM
Tacoma fuel filter cut open
by funflyer - 05/31/20 06:53 PM
C6H8O7, Jcvjr, Haywood, ToOliwer, AbbeyRoad
71588 Registered Users
110 registered members (Arcoril, aquariuscsm, ABN_CBT_ENGR, 830Lee, Al, 2015_PSD, 11 invisible), 2,303 guests, and 40 spiders.
Topics306,121
Posts5,286,869
Members71,588
Can the coolant in the reservoir fluctuate from day to day? #5429240 05/14/20 03:55 PM
J
Jeep_Riot Offline OP
J
2015 Subaru Crosstrek
A week ago I checked the coolant first thing in the morning and it sat between the cold and hot indicators in the reservoir tank. Today I checked it first thing in the morning and it’s sitting right above the cold line indicator. There are no visible leaks anywhere and no white smoke coming from the exhaust. Thanks.
Re: Can the coolant in the reservoir fluctuate from day to day? [Re: Jeep_Riot] #5429245 05/14/20 03:57 PM
supton Online Content
Online Content
Thermal expansion. It'll be lower in cold weather, and higher when the engine is hot. That is why it has hot and cold marks on the bottle.
2011 Toyota Camry, base, 2.5L/6MT, 205k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 159k, ours
1999 Toyota Camry LE, 2.2L/4AT, 225k, his
Re: Can the coolant in the reservoir fluctuate from day to day? [Re: Jeep_Riot] #5429270 05/14/20 04:27 PM
M
motor_oil_madman Offline
M
It should be at the same spot every time when it's dead cold. Unless the outside temp changes drastically from the last time you checked it. Went through this with my truck.
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
Re: Can the coolant in the reservoir fluctuate from day to day? [Re: Jeep_Riot] #5429275 05/14/20 04:32 PM
A
Alfred_B Offline
A
[Linked Image from i.kym-cdn.com]
Re: Can the coolant in the reservoir fluctuate from day to day? [Re: Jeep_Riot] #5429277 05/14/20 04:33 PM
R
Reddy45 Offline
R
There should also be a overflow tube where excess fluid will drain if the level gets too high. But in your case it sounds like the fluid level is just reflective of a temp change.
Re: Can the coolant in the reservoir fluctuate from day to day? [Re: Jeep_Riot] #5429281 05/14/20 04:34 PM
sloinker Online Shocked
Online Shocked
Subaru and coolant loss? Never heard of such a thing.
'16 Tiguan TSI Vaico 5W40
'15 VW Golf TDI Red Line 5W30 Euro
'15 VW Golf Sportwagen TDI M1 ESP 5W30
'14 Dodge Grand Caravan 3.6 Valvoline 5W20 Semi Synthetic
'64 Plymouth Fury440 Pending
Re: Can the coolant in the reservoir fluctuate from day to day? [Re: Jeep_Riot] #5429369 05/14/20 06:54 PM
E
eljefino Offline
E
Some variance is normal. Remember also the radiator cap is spring loaded so you need to build up a bunch of pressure then a bunch burps out (or in) at once.
https://en.wikipedia.org/wiki/Hysteresis
Re: Can the coolant in the reservoir fluctuate from day to day? [Re: Jeep_Riot] #5429396 05/14/20 07:31 PM
2
2010Civic Offline
2
As long as it doesn't continue to drop I wouldn't be worried. You should be able to go nearly forever without adding coolant if it doesn't leak out.
2010 Honda Civic LX
Valvoline SynPower 5w-20 - Napa Gold oil filter
59,992 miles
Re: Can the coolant in the reservoir fluctuate from day to day? [Re: Jeep_Riot] #5429418 05/14/20 08:03 PM
super20dan Offline
well it is a Subaru
99 silverado 5.3
2003 tundra v6
1981 toyota cressida wagon
2003 kia sorento
04 toyota highlander 4cyl 2013 toyota rav4
