Vehicle sighting - 1968 AMC Javelin
by Number_35 - 05/27/20 04:22 PM
Looking for help on an old tiller
by BarryBl - 05/27/20 03:28 PM
is a larger alternator a no brainer?
by apollo18 - 05/27/20 03:02 PM
Rock Auto Code
by BAJA_05 - 05/27/20 01:42 PM
Considering 2019 VW Jetta
by KrisZ - 05/27/20 01:34 PM
Scheaffers moly worth it?
by mpgo4th - 05/27/20 10:50 AM
Flare wrenches
by hallstevenson - 05/27/20 10:43 AM
2000 Volvo S80 T6 Oil Recommendations
by MattV922 - 05/27/20 10:07 AM
2012 Mustang V6, 75w-140?
by RDY4WAR - 05/27/20 09:46 AM
03 WRX 203k miles P.P. 5w40 Euro
by TurboJW - 05/27/20 09:28 AM
13 Corolla U341E Filter
by AJB0009 - 05/27/20 09:19 AM
Brakes Pulsate when Hot
by artbuc - 05/27/20 08:57 AM
Castrol Magnatec Lexus DI application
by AzFireGuy79 - 05/27/20 08:31 AM
Wearing Mask Reinforced
by madRiver - 05/27/20 07:34 AM
2017 Nissan Titan SV 5.6
by ThrowinRocks - 05/26/20 11:30 PM
Need Some People to Do a Ping Test
by ZeeOSix - 05/26/20 10:22 PM
Dumb parking question.
by PhuongFU - 05/26/20 09:38 PM
spin on fuel filter
by mobilaltima - 05/26/20 09:36 PM
Peak Cool Orange no longer GM DEXCOOL Approved?
by Matt1980 - 05/26/20 08:10 PM
heikie, BarryBl, MattV922, Bruce_S, Rwogs
71540 Registered Users
86 registered members (2009Edge, 2015_PSD, 69Torino, 4WD, AlienBug, b1amgm47, 4 invisible), 2,402 guests, and 26 spiders.
Topics305,939
Posts5,283,349
Members71,540
2006 LS430 4th ATF drain and fill--Still dirty #5429215 05/14/20 03:12 PM
O
OldEuroCarLover Offline OP
O
I just drained the ATF for the 4th time and the fluid is still dirty. Cleaner than the last time, but still significantly darker than the new red stuff. (Using Valvoline Maxlife Synthetic.)
Is this normal for this trans? The car has 125k miles on it, and this is probably the first time the ATF has been changed. Roughly 3 quarts per drain.
Re: 2006 LS430 4th ATF drain and fill--Still dirty [Re: OldEuroCarLover] #5429220 05/14/20 03:24 PM
spiderbypass Offline
I have a 2000 Lexus LS400 that I bought close to two years ago it had 134,000 miles on it now it has 202,000. I got the transmission filter and fluid change when I first got the car. I also have a pump extractor that I’ve used at least four or five times it takes about 2 quarts out and he just put 2 quarts back in through the dipstick if your car has the same set up. Very clean looking now
Insecurity with overcompensation are the root of evil deeds.
Re: 2006 LS430 4th ATF drain and fill--Still dirty [Re: OldEuroCarLover] #5429225 05/14/20 03:37 PM
Z
ZZman Offline
Z
Can you not pull a trans line hose on that at the radiator like I can on my Avalon and pump it all out at one time?
2005 Toyota Avalon XLS 3.5 motor
2014 Ford Fusion 2.5 motor
Re: 2006 LS430 4th ATF drain and fill--Still dirty [Re: OldEuroCarLover] #5429230 05/14/20 03:42 PM
O
O
This model has a "sealed" transmission, so no dipstick. Drain plug, overflow plug, and fill plug.
I've done the radiator line method on other cars, but I leaned slightly toward the drain and fill being easier with the sealed trans. Radiator line probably would have been easier, honestly. But here I am.
Re: 2006 LS430 4th ATF drain and fill--Still dirty [Re: OldEuroCarLover] #5429233 05/14/20 03:45 PM
J
JeffKeryk Online Content
Online Content
J
I am about to service our 2013 GS. I started a thread yesterday.
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: 2006 LS430 4th ATF drain and fill--Still dirty [Re: OldEuroCarLover] #5429253 05/14/20 04:03 PM
B
blufeb95 Offline
B
It holds 11.5qt total apparently so you're only exchanging about a quarter of the fluid each time, that means each time you fill 75% of the fluid is left. So the first fill leaves 75%, second leaves 56%, third leaves 42%, the fourth leaves 31%, the fifth leaves 23%, the sixth leaves 17%, the seventh leaves 13%, ect... So where you're currently at you've got about a third of the old fluid mixed with 2/3 of new fluid.
Re: 2006 LS430 4th ATF drain and fill--Still dirty [Re: OldEuroCarLover] #5429263 05/14/20 04:17 PM
Mr Nice Offline
I’d do 3 drain / refills within a few days to get rid of most of the old ATF.
Re: 2006 LS430 4th ATF drain and fill--Still dirty [Re: OldEuroCarLover] #5429307 05/14/20 05:33 PM
H
hallstevenson Offline
H
4 drain and fills, I presume within a reasonably short period of time (how long?) - it's fine. What's in there now is better than 100% of the fluid having 125k miles on it.
Re: 2006 LS430 4th ATF drain and fill--Still dirty [Re: OldEuroCarLover] #5429887 05/15/20 12:57 PM
H
HyundaiAbuser Offline
H
If this is the first time it’s being changed then the fluid you’re putting in could be cleaning the debris and gunk from the last 125k miles. On top of that you aren’t getting a full fluid swap and that’d definitely contribute to the color.
If color is a huge concern at this point is do a cooler line fluid exchange after driving another 1k miles or so but either way you have refreshed the fluid pretty well at this point.
03 Hyundai Tiburon:
PP High Mileage 5w30
Amsoil MTG
94 Mazda B4000
Supertech 10w40 High Mileage
Valvoline Dex/Merc
