Just one more wax question.
by rrretiree7 - 06/02/20 01:49 AM
Removing stuck bolts- interesting technique
by rubberchicken - 06/02/20 12:47 AM
Unless it is a misprint?
by 340_Magnum - 06/01/20 10:25 PM
Raymond Weil 5590 Watch Battery Replacement
by maverickfhs - 06/01/20 09:22 PM
Echo SRM 230 idling high
by CDX825 - 06/01/20 08:40 PM
Walmart in Canada closing Lube and Tire Express
by Snagglefoot - 06/01/20 08:26 PM
2012 Sonic - LCA puck bushing
by Number_35 - 06/01/20 06:44 PM
Rotate mags?
by marine65 - 06/01/20 06:40 PM
Re-using good coolant?
by Jarpin - 06/01/20 06:21 PM
Best entry level riding mower
by UncleDave - 06/01/20 03:02 PM
2015 Pilot LX
by madRiver - 06/01/20 03:01 PM
charge 12v truck battery with more or less amps?
by apollo18 - 06/01/20 02:10 PM
Wash and wax in one
by rrretiree7 - 06/01/20 02:08 PM
$99 fair for wheel balance & front alignment?
by mclasser - 06/01/20 01:34 PM
Help me fix this 2001 YZF 600R
by Kurtatron - 06/01/20 12:29 PM
Super Auto filter
by cknight49090 - 06/01/20 12:20 PM
Shopping for New Generator
by doolah02 - 06/01/20 12:02 PM
NewMex, RandyN11049, bbrtuning, chapys, DaaBoss
71593 Registered Users
24 registered members (E365, blufeb95, bachman, brslds, bourne, Doktor_Bert, 1 invisible), 1,275 guests, and 78 spiders.
Topics306,045
Posts5,286,348
Members71,593
2020 Subaru Forester 1st oil change question #5429194 05/14/20 02:36 PM
W
wagsrk08 Offline OP
W
My new to me 2020 Subaru Forester is just a few miles shy of Subaru's 1,000 mile break in period (basically no fast stop/starts, stay under 4000 rpm, etc). I plan on changing the oil next weekend myself with a little over 1150/1200 miles on the new engine. Is this a little premature sending an OCA to Blackstone with such a low mileage engine?Subaru recommends 6 month or 6,000 mile OCI. My first 6,000 mile service will be at the dealership since I'm curious on what they all check on all servicing. Then I'll take over from there HOPING I can score a Subaru service manual for better maintenance info. Thx!
2020 Subaru Forester Premium 2.5L AWD CVT
2012 Toyota Tacoma 2.7L 5-Speed Manual 4WD
2016 Harley-Davidson FLHTK Ultra LImited
Re: 2020 Subaru Forester 1st oil change question [Re: wagsrk08] #5429198 05/14/20 02:45 PM
I
Imp4 Offline
I
There are too many assembly contaminants to achieve meaningful UOA data on the first few oil changes.
Run 15k-20k miles (2-3 oil changes) and then take a first sample in order to establish a useful baseline.
Good luck!!!
cheers
Re: 2020 Subaru Forester 1st oil change question [Re: wagsrk08] #5429199 05/14/20 02:47 PM
T
TrainingPolicy Offline
T
It's totally a personal call, the additive in the oil isn't used up on it in 1k miles, you will see elevated wear metals due to the break-in process, but it'll give you a great baseline for future analysis. If you are going to do routine Blackstone reports, I would probably do it. But if you are doing it sporadically then I would do it the next oil change once all the wear metals are mostly flushed out. Although they say technically the engine doesn't break in until 20k miles, who really knows.
2003 Infiniti G35 6MT 104k
2005 Honda Accord 235k
2010 Hyundai Santa Fe 110k
Re: 2020 Subaru Forester 1st oil change question [Re: wagsrk08] #5429200 05/14/20 02:55 PM
Donald Offline
Wait until the starting mileage is 20K or more for first UOA.
Better yet, drive car in a reasonable manner, 6000 to 7500 OCI and remember it requires a 0W20 synthetic and save the UOA for more exotic vehicles. . I buy NAPA synthetic on sale, Subaru OEM filters on Amazon by 6-pack and have a Fumoto value.
I have done many many UOAs over the years. None on either Subaru vehicles.
I would suggest on a yearly basis to pull the brake off and clean and lube them. Seem more prone to a little rust screwing things up than most cars. (Rust belt statement.)
2015 Ford F-250 w/Powerstroke
Re: 2020 Subaru Forester 1st oil change question [Re: wagsrk08] #5429205 05/14/20 03:00 PM
PimTac Offline
Nothing wrong with a early oil change out. That’s one of those things that gets a 50/50 pro or con opinion here. As for the analysis, save your money. The suggestions above are good.
2017 Mazda CX5
Mobil 1 Annual Protection 0w20
Roki OEM filter.
Re: 2020 Subaru Forester 1st oil change question [Re: wagsrk08] #5429208 05/14/20 03:06 PM
E
electricmarquis Offline
E
I have owned 7 Subaru's from 2 dealers. Both dealers offered the first oil change free at half of the manuals OCI. All of the N/A Subaru's I have had were very easy on oil. The EJ turbos on the other hand were rough on oil. I have had 5 EJ N/A engines, 1 FA20DIT, and 1 EJ257. The FA20DIT always had higher fuel deposit UOAs. I have yet to do the EJ257 UOA. It has 2k miles on it and its on its 2nd oil change. Both Subaru Syn (free).
I would not even start UOAs till 15k + miles. Liked mentioned above, the break-in readings do not tell you the real story like tests done from 15k-300k.
2020 Subaru STI EJ257
2019 Subaru Impreza Sport FB20
2014 Dodge Durango 3.6 Pentastar
Re: 2020 Subaru Forester 1st oil change question [Re: wagsrk08] #5429391 05/14/20 07:24 PM
I
IveBeenRued Offline
I
I dumped my factory oil at 1K in my 2012 Impreza (known high risk of oil burning year) and then did two 4.5K intervals and then switched to 6K intervals at the 10K mark. Factory OCI was 7.5K but I always stuck with the 6K intervals through the power train warranty. Ironically, Subaru changed the same engine (FB20) from 7.5K to 6.5K intervals in later model years. I started running 13K intervals with AMSOIL and later M1EP after several UOAs and the engine has been rock solid. No oil burning or any other issues for 137K and counting.
2020 Toyota RAV4 Limited Hybrid 5,000 miles
Super Tech 0W-16|Fram Ultra
2012 Subaru Impreza Sport Limited 137,000 miles
Pennzoil Platinum HM 0W-20|Fram Ultra
Re: 2020 Subaru Forester 1st oil change question [Re: wagsrk08] #5429468 05/14/20 09:28 PM
J
jqgz Offline
J
Subie owner here. Change it with the cheapest 0w20 you can find, and I recommend the wix filter as it has a high bypass setting. In my opinion the key to keeping a Subaru engine from consuming oil is shorter oci in the first 15k miles.
Re: 2020 Subaru Forester 1st oil change question [Re: wagsrk08] #5429583 05/15/20 03:16 AM
W
wagsrk08 Offline OP
W
I appreciate the feedback. I'll be holding off on the UOA until I build up some miles on this new engine. Thx!
Re: 2020 Subaru Forester 1st oil change question [Re: wagsrk08] #5429660 05/15/20 07:31 AM
Superbuick96 Offline
I think the first oil change in my 18 Forester 2.5 Premium was around 1,200 miles,dumped the factory fill. I change it out every 6 monthly putting 13k miles on it in 2 years. I still dump the oil every 6 months rather than 6 k miles. I usually use M1 afe but recently stocked up on 0w-20 5qt. hugs of QSUD for $17.77 at Menards
07 Saturn Vue 3.5 AWD M1 5w-20
18 Subaru Forester 2.5 M1 AFE 0w-20
Re: 2020 Subaru Forester 1st oil change question [Re: electricmarquis] #5430424 05/16/20 07:15 AM
E
E
I must have been drinking.
1 FA20DIT
1 EJ257
1 EJ22
1 FB20D
3 EJ253 SOHC
Currently own and driving the EJ257 and FB20D. I have yet to do a test on either. The first test will be on my impreza, it’s about to hit 20k.
