Briggs and Stratton valve clearance
by supton - 05/29/20 02:38 PM
50 cal. shell
by Donald - 05/29/20 01:52 PM
Fleet Farm Rotella T6 Sale + Shell Rebate
by shibby6600 - 05/29/20 01:26 PM
QS Ultimate Durability 5W-30
by js1956 - 05/29/20 12:51 PM
KPVD Eerily Deserted
by wings&wheels - 05/29/20 12:24 PM
BMW N55 Recommendations
by BSchmidt25 - 05/29/20 10:21 AM
Castrol / Mobil 1 blend?
by mbres2000 - 05/29/20 09:40 AM
My Henry 22 Magnum Rifle (pics)
by tig1 - 05/29/20 09:04 AM
overfilled my crankcase by 3/10 of a liter - problem?
by tom in boise - 05/29/20 08:49 AM
Espresso
by buster - 05/29/20 08:34 AM
I didn't believe there were fake spark plugs.
by JustinH - 05/29/20 08:14 AM
New Tire Selection
by artbuc - 05/29/20 07:44 AM
Well question
by supton - 05/29/20 07:11 AM
Cable Modem Thoughts/Recommendat
ions?
by alarmguy - 05/29/20 07:10 AM
Tire choice 2016 Lexus es 350
by Toros - 05/29/20 06:20 AM
Infineum trends: Passenger vehicles (2019)
by Gokhan - 05/29/20 05:11 AM
Another story from the service bay
by clinebarger - 05/29/20 12:11 AM
KIA TYPE 4 (M) ATF
by flinter - 05/28/20 08:49 PM
My new Henry 22 Magnum rifle
by tig1 - 05/28/20 08:45 PM
Kboggs, oldcodger, cwllams1, Danwrig, DanielR
71558 Registered Users
88 registered members (Al, 4WD, AlienBug, 1978elcamino, 2004tdigls, 53' Stude, 10 invisible), 2,273 guests, and 34 spiders.
Topics306,015
Posts5,284,859
Members71,558
New bathtub-not as hot as I’d like #5429166 05/14/20 01:54 PM
R
RhondaHonda Offline OP
R
The water heater is set so that water from the taps is 130 degrees, except on the tub. It’s a freestanding tub with separate hot and cold levers and I only get 106 out of the tub with it turned on full hot. I’m assuming there’s a weird safety valve or something but am curious if it can be adjusted. Any plumbers have a guess?
2019 Ford Raptor
2017 Corvette Grand Sport
2017 Yukon XL Denali
Re: New bathtub-not as hot as I’d like [Re: RhondaHonda] #5429170 05/14/20 02:06 PM
B
Barkleymut Offline
B
I would suspect the water line run is further and possibly near an area that has some air movement that is cooling the water. I am not a plumber, or expert at all in this kind of stuff but my 1st house had a similar situation and it was the best theory I could come up with.
09 Vue 2.4L 4spd AT/ 09 Flex 3.5L / 96 F150 5.0 5speed / 07 Mustang GT auto
Re: New bathtub-not as hot as I’d like [Re: RhondaHonda] #5429183 05/14/20 02:20 PM
I
Imp4 Offline
I
Likely a safety mixing valve to prevent burns.
Have you read the entire plumbing fixture owner's manual from cover to cover?
Re: New bathtub-not as hot as I’d like [Re: RhondaHonda] #5429187 05/14/20 02:25 PM
B
BigCahuna Offline
B
I just found this code spec for where you live. It states that you should have a minimum tub temp of 110F and a max of 120f, if the tub has a mixing valve somewhere in the plumbing.,, https://inspectapedia.com/plumbing/Hot_Water_Temperature_Laws.php
Re: New bathtub-not as hot as I’d like [Re: RhondaHonda] #5429188 05/14/20 02:27 PM
M
mk378 Offline
M
It's called a tempering valve. Follow the pipe from the tub "hot" faucet back to the water heater. 106 is a very conservative setting, 115 would be safe for most people.
Re: New bathtub-not as hot as I’d like [Re: RhondaHonda] #5429190 05/14/20 02:31 PM
R
R
It’s definitely not the distance of the plumbing run. This is new construction, well sealed and the tub is maybe 8 feet from the sink I measured 130 at. I’ll have to pull the panel off the back of the tub and check for an owners manual/manufacturer. I measured the cold to see if maybe the water gets mixed both ways but it’s the same as the cold at the sink. 110 would be an improvement if I could even adjust it up to that. Maybe cranking the water heater up another 5-10 degrees would give me a few more degrees at the tub.
2019 Ford Raptor
Re: New bathtub-not as hot as I’d like [Re: RhondaHonda] #5429196 05/14/20 02:37 PM
2
2004tdigls Online Content
Online Content
2
this should help, you need a couple allen keys
https://www.youtube.com/watch?v=lZN_pK0CCYo
Re: New bathtub-not as hot as I’d like [Re: RhondaHonda] #5429204 05/14/20 02:58 PM
Donald Online Content
Online Content
Our problem is our 50-60 gallon gas water heater does not have enough hot water to fill the tub. Its a jetted whirlpool. There are solutions, but none cheap.
2015 Ford F-250 w/Powerstroke
Re: New bathtub-not as hot as I’d like [Re: RhondaHonda] #5429213 05/14/20 03:11 PM
M
mk378 Offline
M
Turning the water heater up won't make the bath water any hotter, since the valve regulates the outflow temperature, adjusting itself for incoming temperature. You need to find the valve and adjust it.
If the plumbing is "home run" PEX, there is a separate line for each fixture to the utility room, so the valve would be there, not in the bathroom.
Bathroom sinks should also be connected to tempered water to reduce the risk of burns. Only the kitchen should get water hotter than 120.
Re: New bathtub-not as hot as I’d like [Re: RhondaHonda] #5429214 05/14/20 03:12 PM
Skippy722 Offline
I had to adjust the valve on my shower because it never got hot enough.
2019 Ram 1500 Classic
2018 Dodge Grand Caravan GT
Slight Mopar obsession
Re: New bathtub-not as hot as I’d like [Re: Donald] #5429228 05/14/20 03:40 PM
R
Rob_Roy Offline
R
How close is it to doing the job? If not too far off, adding a mixing valve and setting the water heater @ 145F or so may be enough.
2016 Ford Expedition EL Platinum
2016 Ford Expedition XLT
1999 Ford F350, V10
Re: New bathtub-not as hot as I’d like [Re: RhondaHonda] #5429257 05/14/20 04:07 PM
W
walterjay Offline
W
We have sometimes located the tempering valve in a seemingly unusual place such as under a vanity in the cabinet.
Re: New bathtub-not as hot as I’d like [Re: RhondaHonda] #5429340 05/14/20 06:18 PM
R
R
Took the access panel off and don’t see any adjustment. It’s a Delta tub filler if that matters. I wonder if there’s some adjustment under the handles. Thanks for the replies so far. There’s an Allen screw in the faucet but I’m not sure if that’s an adjustment or a set screw to hold it on. [Linked Image]
[Linked Image]
[Linked Image]
2019 Ford Raptor
Re: New bathtub-not as hot as I’d like [Re: RhondaHonda] #5429377 05/14/20 07:04 PM
R
R
Cheers2
Found the mixing valve under one of the bathroom sinks. Thanks for your help everyone. My MIL can bathe in comfort. No pics, you are welcome.
2019 Ford Raptor
