Australia Energy Costs
by Y_K - 06/06/20 12:17 AM
Total Repair Costs over 200,000 miles
by Palut - 06/06/20 12:08 AM
Vredestein will start making American-market specific tires
by slacktide_bitog - 06/05/20 11:33 PM
Fried plantain question
by aquariuscsm - 06/05/20 11:08 PM
Castrol Edge LL IV 0w20, not majority PAO
by wemay - 06/05/20 09:08 PM
Fram Titanium 20k mile oil filters at AAP....
by bbhero - 06/05/20 09:04 PM
D-Day πŸ‡ΊπŸ‡Έ
by kstanf150 - 06/05/20 08:57 PM
Husqvarna 5.2 ounce 2 stroke oil .39 ymmv
by maintenanceMan - 06/05/20 08:53 PM
Mobil 1 Permazone
by maverickfhs - 06/05/20 07:47 PM
2 stroke oil
by opus - 06/05/20 06:19 PM
McKinney Falls State Park - Austin, TX
by wwillson - 06/05/20 05:22 PM
Gen 5 Rams (2019+)
by The Critic - 06/05/20 05:03 PM
CarQuest R95140 Cut Open
by HX520W - 06/05/20 04:47 PM
2012 Tacoma steering very stiff?
by wagsrk08 - 06/05/20 04:44 PM
"Quick change" sabotage episode
by Kira - 06/05/20 04:40 PM
Two Motorcraft FL400S Filters Cut Open
by HX520W - 06/05/20 04:36 PM
VIN character that designates engine
by grampi - 06/05/20 04:35 PM
Two WIX 57356XP Filters Cut Open
by HX520W - 06/05/20 04:17 PM
3Dperf, LouK2, Michael328i, tyman, Knot_A_Mekanik
71616 Registered Users
53 registered members (carlprop, blufeb95, 4WD, Bfrost99, bbhero, 5 invisible), 1,135 guests, and 54 spiders.
Topics306,274
Posts5,289,390
Members71,616
Is this an issue with cartridge filters (fitment) #5429112 05/14/20 12:37 PM
wemay Online Happy OP
OP Online Happy
The Passat is my first go around with a cartridge filter an i've never experienced fitment issues with spin on's. During my recent oil change i purchased a NapaGold 100024 (made by Mann Hummel). The filter looked well made, but when i tried to fit it over the valve in the bottom half of the housing after seating it in the cap, it wouldn't fit unless i applied excessive pressure. The factory filter was much easier. I removed the NG because it bothered me last night, and put in an OEM 06K-115-562
Is this a one-off or is this a real issue with aftermarket cartridge filters to some extent?
2019 Volkswagen Passat Wolfsburg TSI: M1 0W-20, PL21478 o.filter
2013 Hyundai Santa Fe Sport 2.0T: RGT 5W-30, OE o.filter
Re: Is this an issue with cartridge filters (fitment) [Re: wemay] #5429116 05/14/20 12:46 PM
drtyler Offline
Did you lube the o-rings on the inside top and bottom of the Wix?
Those O-rings make the seal, vs a pressure seal made with the housing and the top and bottom of the Mann. They are usually a little tight. I don't think there was any issue with your filter. I used that style on my BMW and GTI and results are similar. It's just a different way of making the seal, and I personally like it as it means there can be a bit of manufacturing variance in the total length of the filter and it will still seal the dirty oil from the filtered oil.
Re: Is this an issue with cartridge filters (fitment) [Re: wemay] #5429126 05/14/20 12:54 PM
O
odie Offline
O
We're put off by the plastic oil filter cartridge that's now used for 1.6 Ltr. Kia Rio and Hyundai Accent plus the Venue . The engine is redesigned . Hopefully , not for the worse .
Re: Is this an issue with cartridge filters (fitment) [Re: wemay] #5429139 05/14/20 01:10 PM
Quattro Pete Offline
Aftermarket filters for German cars have been a hit or miss in general. Too many horror stories for me to NEVER consider one. OEM only. Most OEM cartridge filters for German cars don't cost any more than aftermarket ones, so I see no good reason to use aftermarket ones.
✰ 2002 530i   ✰ 2015 Q5 3.0T   ✰ 2018 Charger SRT
Re: Is this an issue with cartridge filters (fitment) [Re: Quattro Pete] #5429149 05/14/20 01:24 PM
G
Gebo Offline
G
Agreed.
'98 LEX LS400 310K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 75K
Shell Gas and Truck 5w-30
Amsoil OE 10w-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: Is this an issue with cartridge filters (fitment) [Re: wemay] #5429155 05/14/20 01:36 PM
B
Barkleymut Offline
B
Never once had a problem with the cartridge in my 2009 Saturn 2.4L. I've probably used 3,4,5 brands?
09 Vue 2.4L 4spd AT/ 09 Flex 3.5L / 96 F150 5.0 5speed / 07 Mustang GT auto
Re: Is this an issue with cartridge filters (fitment) [Re: wemay] #5429186 05/14/20 02:24 PM
OP Online Happy
@drtyler - that may just be it. I did not lube the o-ring because well, i just never knew it needed to be.
@Quattro Pete - I may go this route.
Re: Is this an issue with cartridge filters (fitment) [Re: wemay] #5429237 05/14/20 03:52 PM
U
Ursatdx Offline
U
The Napa 100024 crosses to a Purolator L28161. Fits an 18 Passat 2.0.
The 19 Passat 2.0 uses a different part# . The best I can find is a Service Champ WP1078.
The NAPA filter lookup calls for the 100024 on the 19 Passat.
Purolator calls for the L28161 and L21478 for the 19 Passat.
Looks like a change of filter midway thru production.
"If there must be trouble, let it be in my day, that my child may have peace." --- Thomas Paine
Re: Is this an issue with cartridge filters (fitment) [Re: wemay] #5429308 05/14/20 05:33 PM
T
tig1 Offline
T
I had issues(filter twisting) with after market cartridge filters in my 2007 Fusion. I settled with MC filters for that engine and all have been well since.
2007 Ford Fusion 258,000 miles
M1 5-20HM
2017 Ford Fusion 91K
M1 0-20EP
M1 ATF and M1 LV HP ATF
M1 10-30 in all OPE
MC filters
Re: Is this an issue with cartridge filters (fitment) [Re: drtyler] #5429375 05/14/20 07:00 PM
T
tc1446 Offline
T
Good to know when I do my first change. Doubt I'd have thought to lube those 0-rings either. I do have a Mann filter, for what thats worth.
'14 Kia Soul, 2.0L (29K)
'13 Accord EX-L 2.4L (110K) M1 & FU
'00 Ford Ranger 4.0L {69K} M1 & FU
'18 Polaris Slingshot 2.4L GM (QS & Bosch Cart.)
'07 Kioti CK-30 (Delo & Wix)
Re: Is this an issue with cartridge filters (fitment) [Re: wemay] #5429745 05/15/20 09:29 AM
J
JeffKeryk Offline
J
I think there are 3 different size elements for the Toyota canister filters.
I mistakenly bought filters that will sit on my shelf for a loooong time.
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: Is this an issue with cartridge filters (fitment) [Re: Ursatdx] #5429779 05/15/20 10:18 AM
drtyler Offline
Those two filters are physically the same size. The difference is the media. Mann recently replaced the HU6002z with the HU6013z. The media in the newer filters is white and appears very similar to the Purolator Boss media. The VW filters I have purchased still use the older cellulose media, similar to the HU6002z.
And those two Purolator numbers are reboxed Mann. L28161 is the Mann HU6002z, and PL21478 is the newer HU6013z.
The Purolator lookup at their website shows both of the mentioned filter numbers as applicable for the 2019 Passat 2.0.
Re: Is this an issue with cartridge filters (fitment) [Re: wemay] #5429961 05/15/20 02:48 PM
53' Stude Offline
We use Auto Extra variant of NAPA gold and no issues. Did 3 VW Golf wagons and a Passat today; all used auto extra and no issues.
shrug
Re: Is this an issue with cartridge filters (fitment) [Re: wemay] #5430323 05/15/20 11:19 PM
OP Online Happy
Thanks 53'. I'll keep that in mind. It may have been a one off.
Re: Is this an issue with cartridge filters (fitment) [Re: wemay] #5430533 05/16/20 09:25 AM
53' Stude Offline
All good Wemay. I note the Auto Extra have plastic ends on them. Work well so far. We used to buy MANN in green and yellow box filters in huge bulk amounts. Worked well too
